Catastrophic Failure in a rebuilt 1971 Super Beetle 1600?
NachoCar
NachoCar is offline
PostPosted: Tue Aug 05, 2025 6:42 am    Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? Reply with quote
Any progress? I had my cam gear strip... gl
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Thu Jul 24, 2025 8:18 am    Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? Reply with quote
veedubcrazy wrote:
earthquake wrote:
Did someone say " Catastrophic Failure"?
eQ
OMG! Shocked Shocked Shocked
That should buff right out!
OP - camshaft snap. Gear strip. Especially on rebound units. You might want to ask if that was the case.
Jimbo
TDCTDI wrote:
67rustavenger wrote:
veedubcrazy
veedubcrazy is offline
PostPosted: Thu Jul 24, 2025 8:02 am    Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? Reply with quote
eQ
1967 Deluxe Sedan
1971 Squareback - "The Silver Surfer"
nsracing
nsracing is offline
PostPosted: Thu Jul 24, 2025 6:21 am    Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? Reply with quote
Spowers wrote:
It was rebuilt in a shop but the 12 month warranty is expired. I guess I'll tear it down to see what happened. This will be my first time into the crank case of a VW. First time for everything...Wish me luck...Thanks for the feedback...
Over 12 mos and only 500 miles?
well- time for you to learn the hard way. As I always say to people - if you will be w/ this VW have 2 motors. Always.
Enjoy.
earthquake
earthquake is offline
PostPosted: Mon Jul 21, 2025 3:38 pm    Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? Reply with quote
eQ
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
NJ John
NJ John is offline
PostPosted: Tue Jul 15, 2025 7:15 pm    Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? Reply with quote
Broken cam bolts? Please report what you find.
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
Cusser
Cusser is offline
PostPosted: Tue Jul 15, 2025 5:46 pm    Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? Reply with quote
If it does turn out to be camshaft-related, I just want to throw in that I have stock VW camshafts and gear in both my 1835cc and 1600cc rebuilt engines. 1835cc was built by me in 1986, and the 1600cc in 2017.
mcmscott
mcmscott is offline
PostPosted: Tue Jul 15, 2025 5:19 pm    Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? Reply with quote
BFB wrote:
Spowers wrote:
I pop off the valve covers to have a look and as my friend is cranking the engine, the cylinders seem to move freely but there is no intake/exhaust valve movement on either side.
… Any advice would be much appreciated. Thanks![/b]
If the cylinders are moving , that there may be your problem.
Joking aside, and assuming you meant the pistons seem to move freely, how’d you determine that?
Start with this
There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Tue Jul 15, 2025 4:50 pm    Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? Reply with quote
Spowers good luck on the teardown, tough break but you may be able to salvage some parts of your engine. If you do not already have a copy, I suggest you get How to rebuild your Volkswagen engine by Tom Wilson. It will help you with the proper sequence with the disassembly to try to salvage what you can. Good luck-Bob
BFB
BFB is offline
PostPosted: Tue Jul 15, 2025 4:18 pm    Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? Reply with quote
Most experts aren't.
raygreenwood
raygreenwood is online now
PostPosted: Tue Jul 15, 2025 2:52 pm    Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? Reply with quote
I am betting the cam broke. I have had a cam gear on type 4 strip the teeth off from a nut that came loose from the oil pump.
No matter what strips all the teeth off, it will not be a silent stoppage when it happens.
Ray
Brian_e Premium Member
Brian_e is offline
PostPosted: Tue Jul 15, 2025 2:23 pm    Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? Reply with quote
I had a core engine that broke the cam right behind the flange for the gear.
Brian
So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts
DerrickfromNC1
DerrickfromNC1 is offline
PostPosted: Tue Jul 15, 2025 2:20 pm    Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? Reply with quote
Back in the late 70s or early 80s I had to go help a friend tow his bug back home that had suddenly quit running for no apparent reason. Similar to the op…no valve train movement while cranking engine over. When we opened the case we found the camshaft broken in 2 places. Cam was an AP2 which was produced by Resolit of Brazil back in the 70s.
Spowers
Spowers is offline
PostPosted: Tue Jul 15, 2025 2:16 pm    Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? Reply with quote
Cusser
Cusser is offline
PostPosted: Tue Jul 15, 2025 2:03 pm    Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? Reply with quote
Spowers wrote:
Only about 500 miles on a 1971 rebuilt 1600cc.
Did a shop rebuild this?
Did you?
What's the experience level of the rebuilder?
busdaddy
busdaddy is offline
PostPosted: Tue Jul 15, 2025 11:41 am    Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? Reply with quote
I'm betting the oil has a silvery sheen.
Слава Україні!
mikedjames
mikedjames is offline
PostPosted: Tue Jul 15, 2025 11:29 am    Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? Reply with quote
Maybe somebody left out the Woodruff key on the camshaft drive gear on the crank and it took a bit of heat to let go and start spinning.
Ancient vehicles and vessels
Alstrup
Alstrup is offline
PostPosted: Tue Jul 15, 2025 11:02 am    Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? Reply with quote
Lemme guess. Empi cam gear. Its stripped. Seen that more times than I care to remember.
https://www.thesamba.com/vw/forum/viewtopic.php?t=435993
67rustavenger
67rustavenger is offline
PostPosted: Tue Jul 15, 2025 10:58 am    Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? Reply with quote
Never heard of this happening but, I guess anything is possible.
Pistons moving and camshaft not moving may indicate a broken crankshaft.
It happens. I don't recall seeing a crank broken on the cam gear end. The ones I have seen usually break near the #2 main bearing.
OP, grab the crankshaft pulley and see it it turns rather freely, like it's not connected to anything inside the engine.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Bobs67vwagen
PostPosted: Tue Jul 15, 2025 10:42 am    Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? Reply with quote
If none of the valves are moving when you rotate the engine it would seem that the camshaft gear is either stripped or broken. That would be my guess. Good luck-Bob
