THE KESZTHELY KID Samba Member
Joined: August 24, 2022 Posts: 68 Location: West Yorkshire
Posted: Tue Aug 05, 2025 5:14 am Post subject: Re: 1980 Euro 1.6L Gas carbureted need carb & vacuum diagram |
Wowsa!
That has to be the Bestest and Cleanest 1600 CT engine I have ever seen in a T25/T3.
Here in Blighty they are a 'Marmite' kind of engine ..
https://club8090.co.uk/forum/viewtopic.php?t=73080 _________________ Current owner of 1980 T25 Westphalia Joker.
1973 Karmann Ghia Coupe - Semi-automatic!!
1983 Trabant 601S Sedan
Daily Driver - 2024 Dacia Duster Journey - Automatic |
Posted: Mon Aug 04, 2025 3:52 pm Post subject: Re: 1980 Euro 1.6L Gas carbureted need carb & vacuum diagram |
borninabus wrote: |
the PICT4 can be replaced with a PICT3 and vacuum diagram from a car the uses similar configuration can be used. |
Don't know much about the PICT4. What is their advantage/disadvantage? |
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6543 Location: Northern Illinois
Posted: Mon Aug 04, 2025 7:59 am Post subject: Re: 1980 Euro 1.6L Gas carbureted need carb & vacuum diagram |
I was thinking of doing that and just eliminating the gazillion vacuum hoses etc. I have to take a better look at the carb top when it gets back here as I swear the fuel hose has two fittings and passes right thru the top and goes to the pump. I could probably just use the PICT-4's top on the -3 carb _________________ Midwest Autosavers, Inc. Crystal Lake, IL |
borninabus  Samba R&D Dept.
Joined: May 18, 2006 Posts: 4729 Location: Arizona Highways
Posted: Mon Aug 04, 2025 7:38 am Post subject: Re: 1980 Euro 1.6L Gas carbureted need carb & vacuum diagram |
the PICT4 can be replaced with a PICT3 and vacuum diagram from a car the uses similar configuration can be used. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Mon Aug 04, 2025 6:49 am Post subject: 1980 Euro 1.6L Gas carbureted need carb & vacuum diagram |
We've got a 1980 Euro spec Vanagon here with a 1600 dual port engine from the factory. I need a vacuum line diagram and would like to source a new carburetor for it. Carb is a 34-PICT-4 similar to the 1974 California Autostick Beetle. Any sources? Thanks
