Schepp Samba Member
Posted: Wed Nov 12, 2025 11:38 am Post subject: Re: my first vw |
I experienced the Pertronix SVDA failure first hand this Past weekend. It lasted a total of 1376 miles. _________________ Bandit #19
1972 Baja Rallycross Bug |
Posted: Wed Nov 12, 2025 9:58 am Post subject: Re: my first vw |
| thanks for info |
oprn Samba Member
Joined: November 13, 2016 Posts: 15210 Location: Western Canada
Posted: Wed Nov 12, 2025 9:15 am Post subject: Re: my first vw |
^^^This!^^^
Or clean up the stock distributor if it's not a 009 and matches the carb you will be using.
I have not had good results with the Chinese replacement carbs at all! Find an original one to clean up and use. _________________ Our cars get old, we get old but driving an old VW never gets old! |
oprn Samba Member
Posted: Wed Nov 12, 2025 9:12 am Post subject: Re: my first vw |
| Cusser wrote: |
| Bobs67vwagen wrote: |
| Stock carb for a 1600 dual port would be the 34PICT-3 and probably the simplest choice. They run best with a SVDA distributor. Get an original German carb if you can as the current Chinese copies are hit and miss on quality. There is a carb rebuilder on the samba who has very good reviews. |
This. Second choice might be a 30/31 PICT on an adapter like I use on my own 1600cc DP engine.
| [email protected] wrote: |
| it will be driven in a lot of parades in Florida heat. Don't want it to run hot |
Parades in Florida is nowhere like highway running in summer here in Arizona !!! VWs rarely overheat or run hot at low speeds or idle situations.
I personally recommend and use distributors with contact points. |
It is a common misconception that air cooled engines overheat in slow traffic. They do not. That is a water cooled air flow through the rad thing. If in fact it does then there is something seriously wrong with your cooling system and/or state of tune and it will overheat 10 times worse on the open road ie. mouse nests in the cylinders/heads, rags sucked into the cooling fan, bad timing setting, extreme lean/plugged jets, that sort of thing. _________________ Our cars get old, we get old but driving an old VW never gets old!
vamram  Samba Member
Posted: Wed Nov 12, 2025 8:48 am Post subject: Re: my first vw |
I've had good luck w/the chinese carbs. The Pertronix SVDA distributor is a piece of junk, however, and I have personally experienced its failure and poor build quality. Many threads here documenting that. Spend the money you were going to use for the Pertronix and buy an original Bosch VW distributor restored by one of the pros here on the samba. You can't go wrong w/that combo.
I've had great success w/both of these restorers' original Bosch distributors.
https://www.thesamba.com/vw/classifieds/search.php?username=heimlich
https://www.thesamba.com/vw/classifieds/search.php?username=wcfvw69 _________________ "Men are qualified for civil liberty in exact proportion to their disposition
'75 Super Le Grande...we hardly knew ye. Sold 2025 for peanuts.
Click to view image
Save the Supers!! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33450 Location: Hot Arizona
Posted: Wed Nov 12, 2025 8:46 am Post subject: Re: my first vw |
I personally recommend and use distributors with contact points. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 873 Location: Eastern north carolina
Posted: Wed Nov 12, 2025 8:29 am Post subject: Re: my first vw |
Posted: Wed Nov 12, 2025 7:41 am Post subject: my first vw |
| I'm building a 1600 dual port with a stock crank , scat c 25 cam , stock heads , 85.5 pistons planning on running a pertronix stock look electronic distributor with vac advance and dune buggy exhaust . I'm looking for advice on witch carb to run . I would like it to idle and run smooth. Its in a short fiberglass dune buggy , so I don't think power will be an issue however it will be driven in a lot of parades in Florida heat. Don't want it to run hot |
