Quick question - Quick answer please a Torque figure
milflyer
milflyer is offline
PostPosted: Mon Dec 08, 2025 2:54 pm    Post subject: Re: Quick question - Quick answer please a Torque figure Reply with quote
Thank all for your fast responses.
Nut on and torqued up.
I'm mobile again Wink
John
Bug#1 "1200CC - BBN446L" / Bug#2 "1302S HUE472L" / Bug#3 "Karmann Cabroilet NFC798S"
redhot
redhot is offline
PostPosted: Mon Dec 08, 2025 1:03 pm    Post subject: Re: Quick question - Quick answer please a Torque figure Reply with quote
50 Nm, being close to 37 lbs-ft.
milflyer
milflyer is offline
PostPosted: Mon Dec 08, 2025 1:00 pm    Post subject: Re: Quick question - Quick answer please a Torque figure Reply with quote
Appreciate the answers folk ...
There is a spring washer under the nut.
Strange I can't find a figure in Clymer's Shop manual or Bentleys Type 1 (70-79)
KTPhil Premium Member
KTPhil is offline
PostPosted: Mon Dec 08, 2025 12:49 pm    Post subject: Re: Quick question - Quick answer please a Torque figure Reply with quote
From that document I would say 38.
Does it have a spring washer under it?
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
baldessariclan
baldessariclan is offline
PostPosted: Mon Dec 08, 2025 12:44 pm    Post subject: Re: Quick question - Quick answer please a Torque figure Reply with quote
You can try this manual -- only goes to 1973, but if the steering shaft end /steering wheel base size is the same for later years, listed tightening torque ought to be applicable: https://www.thesamba.com/vw/archives/manuals/witho...201972.pdf
milflyer
milflyer is offline
PostPosted: Mon Dec 08, 2025 12:05 pm    Post subject: Quick question - Quick answer please a Torque figure Reply with quote
Evening all
Please can someone advise the torque setting I need to tighten the steering wheel nut (24mm) on a 78 Karmann Cabriolet / 1303S.
The only answer I can find via AI is 36-48 Lb/Ft and I'm not happy with AI
Many thanks all
John
