need help with installing new ball joints
vicsvw
vicsvw is offline
PostPosted: Sat Dec 11, 2004 8:29 am    Post subject: No Press Needed Reply with quote
Use a welder. Buy a cheap welder and tap them out with a hammer with this information. ->Ball Joint Removing <> http://www.1800vw.bizhosting.com/qa_balljointrem.htm
then instead of having a new shinney tool on the shelf you will have a welder that can set in the corner unused. Vic
ScrapJunkie
(O\U|U/O)
ScrapJunkie is offline
PostPosted: Fri Dec 10, 2004 9:39 pm    Post subject: Reply with quote
Autozone rents some tools out for free. You just have to leave a deposit.
(O\U|U/O) Top Vw (o\UU/o)
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Dec 10, 2004 9:29 pm    Post subject: Reply with quote
Here's a ball joint tool made by OTC
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
tacky
tacky is offline
PostPosted: Fri Dec 10, 2004 6:47 pm    Post subject: Reply with quote
you can get a ball joint press for about 100.00 and do it yourself. it looks like a heavy duty c-clamp. you can also rent one for 25.00 for a day. i think it beats taking the front end apart and taking it to a shop and waiting and getting reemed and getting pissed and then wishing you took my advice. Rolling Eyes
"Everyone reading this is a PO."
Schmooey
Schmooey is offline
PostPosted: Thu Dec 09, 2004 9:41 am    Post subject: Reply with quote
Have a VW shop do them. They have the right tools that just any old shop will lack. It's a big improvement over worn joints!
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Thu Dec 09, 2004 9:32 am    Post subject: Reply with quote
not2bright wrote:
well if it is a 66' then you have a linkpin frontend. makingthe balljoints that you got useless
Not correct, 66 IS the first year for BALL JOINT front end.
not2bright
not2bright is offline
PostPosted: Thu Dec 09, 2004 9:28 am    Post subject: Reply with quote
green 69' bug
Pacific Coast Volks
keifernet
PostPosted: Thu Dec 09, 2004 9:20 am    Post subject: Reply with quote
Here are some old threads with all the info you need.
http://www.thesamba.com/vw/forum/viewtopic.php?t=71263&highlight=ball+joints
http://www.thesamba.com/vw/forum/viewtopic.php?t=80133&highlight=ball+joints
http://www.thesamba.com/vw/forum/viewtopic.php?t=79547&highlight=ball+joints
bluepunchbuggy
bluepunchbuggy is offline
PostPosted: Thu Dec 09, 2004 7:29 am    Post subject: New Ball Joints Reply with quote
You will have to have the old ones pressed out and the new ones pressed in. I had a friend do it for me and it taxed his 12 ton press almost to the limit. Check your book (whichever one you use) to make sure how they should be pressed in. There are alignment notches that you need to line up between the ball joint and the receiving arm.
Dana
Bug, Ghia, Bus - we got one of each - at least!
custom66
custom66 is offline
PostPosted: Wed Dec 08, 2004 5:47 pm    Post subject: need help with installing new ball joints Reply with quote
I just bought new ball joints for my 66, and Im having trouble figuring out how to install them. Is there a special tool to put these in with or do they have to go to a machine shop and be pressed in? If anyone can help please let me know. Thanks
View user's profile Send private message AIM Address MSN Messenger Classifieds Feedback
