hammered car and it isnt low enough
wanzer74
wanzer74 is offline
PostPosted: Wed Dec 08, 2004 9:20 pm    Post subject: Reply with quote
i just put the same kit on, and had no prob. i cant fit my pinky finger uder the car. just notch the notch and grind the plate over the plate.and dont forget to losen the flux conpasiter.[duh!!]
Slowlow
Slowlow is offline
PostPosted: Wed Dec 08, 2004 9:10 pm    Post subject: Reply with quote
vdubstar33 wrote:
I guess I wil be doing it because I want this thing to throw sparks at the old farts around here
Laughing Sounds good man! ( You could be a cheater and get some drag blocks... Confused) ...... Ahh hell, cut it!
• Metal Fab & Quality Suspensions, Type I-II-III. Since 2004 •
vdubstar33
vdubstar33 is offline
PostPosted: Wed Dec 08, 2004 8:46 pm    Post subject: Reply with quote
LIVIN ON THE REAL WEST COAST CLEARWATER BITCH
Slowlow
Slowlow is offline
PostPosted: Wed Dec 08, 2004 8:40 pm    Post subject: Reply with quote
Do you mean that the trailing arms are touching the stopper on the rear shock tower? If so then the only alternative I see is Notching the hell out of your plates and cutting the stop on the tower off to keep the trailing arm from stoping. Doing that should get you lower but I dont know about doing all that man... Theres nothing a sawzall can do that a welder and some time cant fix though!
Slowlow
Slowlow is offline
PostPosted: Wed Dec 08, 2004 8:38 pm    Post subject: Reply with quote
Unless there is something I dont know about Airkewlds kit, the lowest you will get the pan is about 2 inches from the ground. Of course thats how low my pan is with no body and no engine. Im pretty sure the engine will be laying on the pavement.
vdubstar33
PostPosted: Wed Dec 08, 2004 8:37 pm    Post subject: Reply with quote
I took the bump stops off and it is still touching there too so whats up with that. 1 INCH out of the spring plate isnt going to give me 3 inches of lowering height is it?
Slowlow
Slowlow is offline
PostPosted: Wed Dec 08, 2004 8:35 pm    Post subject: Reply with quote
Maybe this will help.
vdubstar33
PostPosted: Wed Dec 08, 2004 8:27 pm    Post subject: Reply with quote
My body is on my frame and it still not on the ground I dont care what it damages on the car I just what this thing to not fit a c hair under it
NorCalLowLife209
Mr. Saran Wrap
NorCalLowLife209 is offline
PostPosted: Wed Dec 08, 2004 8:17 pm    Post subject: Reply with quote
Adjusting the spring plates yo, make the car lower....... get it?
1967 VW type 1 (sold)
1963 VW type 1 (sold)
2011 VW GTI
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
Slowlow
Slowlow is offline
On an IRS there really is not much of a point to notch the spring plates. About all you can do to an IRS car after what you have already done is go about 1/2 lower. Its not really worth cutting the plates for that small of a drop. Actually, Airkewlds Ghia with the custom IRS pan is the only bagged VW ive seen lay rocker panels on the ground...Well, Except for the Kustom Koach Werks 51, but that car has a totally custom bag setup too. I thought about notching my plates but with the body back on and engine in, it will be much lower than any bug that isnt bagged. I should be close to laying Oil sump.
Ill post a pic of what a spring plate is
vdubstar33
PostPosted: Wed Dec 08, 2004 7:30 pm    Post subject: Reply with quote
I honestly have no clue what you mean.
oldbugs
oldbugs is offline
PostPosted: Wed Dec 08, 2004 7:28 pm    Post subject: Reply with quote
Notch your spring plates.
vdubstar33
PostPosted: Wed Dec 08, 2004 7:24 pm    Post subject: hammered car and it isnt low enough Reply with quote
I just took out the rear torsion bars and bump stops because I am doing a bag kit and it is not touching the ground in the rear like most of the pictures show WHY?? What else do I need to do I have plenty of clearance to go lower.
