Josiah Samba Member
Joined: April 04, 2004 Posts: 363 Location: riverside, ca
Posted: Thu Dec 23, 2004 6:59 pm Post subject: |
i have a 3" body lift ill sell u for 90 bucks + ship. in perfect cond. |
Desertdog Samba Member
Joined: August 17, 2004 Posts: 112 Location: Hesperia Ca.
Posted: Thu Dec 23, 2004 3:46 pm Post subject: |
They do come 3 inches longer, If no lift you have to cut 3 inches off of the main tubes. _________________ I used to think I had a drinking problem, So I quit thinking... |
Joined: April 12, 2003 Posts: 1839 Location: Englewood, FL
Posted: Thu Dec 23, 2004 6:22 am Post subject: |
not promoting the use of a body lift, but I think the class 11 cages are usually 3" longer out of the box to work with the body lift. _________________ Markus |
Baja Ben Samba Member
Joined: December 17, 2004 Posts: 634 Location: riverside
Posted: Wed Dec 22, 2004 5:39 pm Post subject: |
thats proble where I have seen you b4. I was there alot when I keep breaking my breaks or blowing up my engin. cool. i never forget a face. well thanks for all your help today. talk to you later.
Baja Ben _________________ Baja Ben.
Why do I try to wright some sort of banter down here. It doestnt mean anything |
HamburgerBrad Je suis Napoléon!
Joined: February 21, 2003 Posts: 6957 Location: SoCal
Posted: Wed Dec 22, 2004 5:36 pm Post subject: |
chino hills. as far as corona, there was a time where i was at pacific customs every weekend. _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Wanted: two beat up, ugly, curb rashed 6" phone dial wheels |
Posted: Wed Dec 22, 2004 5:35 pm Post subject: |
you look famillar. do you live in corona. I though maybe we went to high school together but I can be worng.? _________________ Baja Ben.
Posted: Wed Dec 22, 2004 5:30 pm Post subject: |
currently JC, but not soon enough Cal Poly Pomona _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Posted: Wed Dec 22, 2004 5:13 pm Post subject: |
Right on. thanks a ton. so I checked out your profile. mec eng hun? me too. what school are your going to. I am thinking about urc and cal poly pamona.
Posted: Wed Dec 22, 2004 5:10 pm Post subject: |
if you get the right spindles, you can still use discs. if you are going with longer trailing arms, adjustable beam. if you are going with stock arms, get lift spindles. (in my opinion) _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Posted: Wed Dec 22, 2004 4:54 pm Post subject: |
heck no on the ball joints. I went that rought with my last baja. it SUCKED. I am going with the irs in back and the link pin up front. in fact I have dessinged an adapter plate to hook a link pin beem to a ball joint front clip. I will post it when I get the plans on a cad file. so what would you recomend. an ajustible front beem or lifted spindels. and would i still be able to put a disc break kit in on lifted spindles.?[/quote] _________________ Baja Ben.
Posted: Wed Dec 22, 2004 4:48 pm Post subject: |
they will both work. i have a friend whos baja has been airborne on a few occasions with adjustable rear springplates, i they are pretty strong. however, i would do it the free way before buying new springplates. an adjustable beam is a good way to go unless you have balljoints and what alot of lift. _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Posted: Wed Dec 22, 2004 4:11 pm Post subject: |
COOL. THANKS FOR THE TIP. AS I READ UP ON THE LIFTS IT JUST SEEMED REALLY HARD TO PUT ONE IN AND DIDNT LOOK ALL THAT STABLE IN THE BACK WERE IT MOUNTS TO THE REAR TORRSTION ARMS. JUST ONE OTHER THING. WHAT ABOUT AN AJUSTABLE BEAM UP FRONT AND AJUSTABLE SPRING PLATES IN BACK. WILL THAT GIVE ME THE PRELOADING I NEED.( PARTICULALY IN BACK) _________________ Baja Ben.
Posted: Wed Dec 22, 2004 4:08 pm Post subject: |
body lift isnt really practical unless you are in excess of 6' tall. the lift spindles and preloading the rear torsion bars will give you ground clearance and the extra fender room you so desire _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Posted: Wed Dec 22, 2004 3:53 pm Post subject: 3" lift kit |
I have a delema. I like the thought of having the body 3" higher and thus allowing the whell's more travel without killing the fenders. but would a chenworth calls 11 cage still mount properly to the fire wall. also, would I get the same dessered effect if I just get lifted spindles in fornt and back _________________ Baja Ben.
