kfdf715 Samba Member
Posted: Tue May 10, 2005 4:08 am Post subject: Can I use this carb for dual port 1600 engine |
I have a Solex 30/31 Pict carb that I would like to use on a dual port 1600 engine. I see that most people use the 34 Pict 3 for this engine. Will the carb I have work? Any negatives? |
siigna Samba Member
Joined: August 17, 2004 Posts: 34 Location: [661] Antelope Valley
Posted: Tue May 10, 2005 9:10 am Post subject: |
That carb should work on a dual port, but you'll need to get an adapter to mount the 30/31.
I believe this would be the one:
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D113%2D129%2D029%2DKIT
I haven't used that carb, but from what I hear it's alittle simpler to deal with than the 34pict carbs.
Oh, and welcome to TheSamba.  _________________ getting back in the scene
Currently own:
Looking for a ride...
Formerly own:
1969 Beetle
1972 Super Beetle
1973 Super Beetle |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13947 Location: White Mountains Arizona
Posted: Tue May 10, 2005 12:26 pm Post subject: |
that carb will work jsut fine _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
dubtype1 Vdubn' Till I Die
Joined: April 13, 2005 Posts: 2298 Location: West Palm Beach, FL
Posted: Tue May 10, 2005 3:31 pm Post subject: |
Thats what I have on my 1600 dp, maybe I'm wrong but I think I'm loosing HP with this carb.
It does work though, you need the adapter. _________________ MIAMI V-DUBS
Caleb
'65 Beetle project |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Tue May 10, 2005 3:36 pm Post subject: |
They do work, but make sure the main jet is at least a 125 or a 127.5
Most of the ones I've ever checked that came with the adaptor were jetted already for the dual port.
Some that were sold as a replacement for the single port ( no adaptor, direct bolt on to replace single port 30 series carbs) may have been jetted smaller for that application. |
rayzor30 Samba Member
Joined: February 04, 2005 Posts: 177 Location: Western NY
Posted: Tue May 10, 2005 9:39 pm Post subject: Don't use that carb if you want decent performance |
I just had that carb removed from my 79 vert. The PO put it on when he replaced the FI. The car ran, even started nicely but was a dog for power. I replaced mine with dual Kadrons and could not be happier. HUGE difference.
rayzor30 |
Shane Samba Member
Joined: July 08, 2003 Posts: 399 Location: Pottsville, AR
Posted: Tue May 10, 2005 9:48 pm Post subject: |
Yeah, it'll work. Been there, done that. Mine had the 127.5 main jet and worked like a champ. Yes, you'll probably sacrifice some power, particularly under acceleration. I did notice a bit better mileage than I did with the 34 PICT 3.
I have heard of doing this as a possible fix for those folks with the 009 distributor due to the flat spot created when running a 009 with a 34 PICT 3. Don't know the truth to that though. _________________ 49 Deluxe -Family cruiser
59 Ragtop - Judson supercharged
79 Vert - Fuel injected and staying that way
Just say "NO" to trailer queens. |
Posted: Thu May 12, 2005 12:00 am Post subject: Thanks |
I thank all of you that responded to my question. |
VWLarry Samba Member
Joined: May 12, 2005 Posts: 104 Location: Bismarck, ND
Posted: Thu May 12, 2005 11:50 am Post subject: |
I'm running a 30/31 on my '72 and have been for years. It works fine but does require the adapter on a stock manifold. If you buy a new manifold from CB Performance it is drilled for both the 30 Pict and the 34, so no adapter needed. In fact CB Performance is selling this setup and calling it their Mileage Master Intake System (Part # 3152). As far as the flat spot with the 009, I've still got one right off idle. I'm replacing the 009 with an 034 and going to a 34/3 just to see if it makes much of a difference. That's the thing about VW's, you can always mix and match and play. Good luck. |
