PHAT4 Samba Member
Posted: Sat Jun 25, 2005 4:40 am Post subject: Anyone here buy long plug wires and cut to length? |
I've always used Taylor spark plug wires and I'd like to carry on doing so.Problem is I don't see any Taylor wires listed for the ACVW application.
Aynone here buy their plug wires long and cut to length?
What boot style do you use and where and how did you handle the shroud seal deal? |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80410 Location: Sneaking up behind you
Posted: Sat Jun 25, 2005 4:42 am Post subject: |
I used to make my own wires using Mallory 7mm wire. Most hi-po speed shops sell bulk wire. The distributor cap ends are pretty standard and I used 36hp spark plug ends without the resistor.
When you get into the large 8mm and 8.5mm, getting the wires into the ends is a problem. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
PHAT4 Samba Member
Posted: Sat Jun 25, 2005 7:09 am Post subject: |
For other stuff I've always purchased Taylor wires with the spark plug ends on and then and cut to fit the cap end, nothing new for me.
Cap ends like you said are a normal deal.
The plug ends for a VW are a mystery to me though.
Where do you get non resister 36HP plug ends at?
Also you said you Used to make your own wires.
What are you using now?
I have always used Taylor because they have never given me one lick of trouble and have lasted an incredibly long time.I'm just not sure where to turn to get a really high quality, low resistence wire that won't interfere with the radio for my bug.
I plan on running a coulpe stereo amps and I don't want any of the ignition noise comming over the stereo.I don't plan on using a MSD ignition box or anything like that.
Just a Mallory Unilite and a good coil maybe a Bosch blue or better. |
Humanure Samba Member
Posted: Sat Jun 25, 2005 9:01 am Post subject: |
| http://www.cbperformance.com/catalog.asp?ProductID=350 Try those, I use'em. Great wires. Plus, get spark plugs that suppress RFI (radio frequency interference.) The sound of snap, crackle and pop in my speakers drove me crazy until I found out it was coming from my plugs. |
Glenn  Mr. 010
Posted: Sat Jun 25, 2005 9:28 am Post subject: |
| PHAT4 wrote: |
I'm using off the shelf Bosch silicone 7mm wires. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
PHAT4 Samba Member
Posted: Sat Jun 25, 2005 9:41 am Post subject: |
| Humanure wrote: |
Imagine that  |
PHAT4 Samba Member
Posted: Sat Jun 25, 2005 12:34 pm Post subject: |
| Humanure wrote: |
| Plus, get spark plugs that suppress RFI (radio frequency interference.) |
You mean resistor plugs? |
PHAT4 Samba Member
Posted: Sat Jun 25, 2005 12:36 pm Post subject: |
| Glenn wrote: |
I'm using off the shelf Bosch silicone 7mm wires. |
Why did you start using the Bosch plug wires? |
Glenn  Mr. 010
Posted: Sat Jun 25, 2005 1:24 pm Post subject: |
| PHAT4 wrote: |
| Glenn wrote: |
Because they work. _________________ Glenn
Member #1009
#BlueSquare
stevemariott Samba Member
Joined: November 09, 2003 Posts: 1118 Location: Portland, OR
Posted: Sat Jun 25, 2005 1:49 pm Post subject: |
Consider these wires from aircooled.net:
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=IGW0005&cartid=0620200570793181
I had Taylors for a year and a half and I liked them, but I didn't like cutting down the coil wire to fit my bus - the rest of the wires were cut to length for type 1. For whatever reason I had a heck of a time getting the end to crimp on nicely to the wire. I just got the ac.net's wires in the mail the other day and they are really nice. They give a solid snap onto the cap and plugs, and they have an air seal like the stock bosch wires. I personally like them better than the Taylors. _________________ 1963 Manx copy
1968 Bus |
Alan_U Samba Member
Joined: July 10, 2004 Posts: 1762 Location: Vancouver, BC Canada
Posted: Sun Jun 26, 2005 10:03 am Post subject: |
I recall taylor having an 8mm wireset custom cut for a type 1. I'm using that set right now. I did buy it aprox 2yrs ago.
works great for me and has a positive connection to the spark plug. _________________ 11.92sec pump gas true daily driver. Who says it cant be done.
No more time for VW's....... |
PHAT4 Samba Member
Posted: Sun Jun 26, 2005 10:58 am Post subject: |
| All of the Taylor wires I've used have gone straight on to plug, no need to remove screwed on tips. I've had to exert a lot of force to pull them off.A little dielectric grease smeared in the boot helps. |
volksguy Samba Member
Joined: November 24, 2003 Posts: 342 Location: Apple Valley, Ca.
Posted: Sun Jun 26, 2005 11:32 pm Post subject: |
There are a few places here in So. Cal. to buy Taylor wires already done for your VW. We sell the taylor 8mm at my job, and vwparts.net (veedub parts unlimited in Hunington beach CA., Moore parts in Anehiem CA, Pacific Customs in Corona CA all sell the taylor 409 10.4 MM wires for like $30 a set, all ready for the ACVW application. _________________ Suck It Easy High Performance Engines |
Muffler Mike Samba Member
Joined: October 10, 2002 Posts: 1054 Location: Lawndale Ca.
Posted: Mon Jun 27, 2005 12:00 pm Post subject: |
I recently switched to these too to solve a noise issue with my data logger. _________________ Muffler Mike
http://MufflerMike.com |
PHAT4 Samba Member
Posted: Tue Jun 28, 2005 10:58 pm Post subject: |
| Muffler Mike wrote: |
| I recently switched to these too to solve a noise issue with my data logger. |
What other wires did you try?
Did the SuperMag wires solve your problem? |
Posted: Wed Jun 29, 2005 6:26 am Post subject: |
| PHAT4 wrote: |
I was running an old set of Morroso Blue Max, generic v8 kit that one builds them selves. they were probably closing in on the 10 year old range. but very low mileage.
as for solving my problem. when i switched wires, my data logger went from not even gettings any sort of recording to making it out to 3rd and even 4 gear. a swap of the cap, rotor, and coil solved the rest.
guess the msd 7 is pretty loud (in terms of electrical noise) _________________ Muffler Mike
PHAT4 Samba Member
Posted: Fri Jul 01, 2005 12:38 am Post subject: |
So there were other sources that also lead to your problems.
Glad ya got it sorted out.. |
Bugzlife Samba Member
Posted: Fri Jul 01, 2005 5:53 am Post subject: |
I use the Magavolt Bugpack 8mm solid core with the 009, and pertronix 1 insert. Mallory coil.
the Taylor I bought from CB, 10mm I think didn't fit well and kept coming loose on the distributor cap(they need better ends on them)
the Bugpack $19.95, fit great. (but I have no radio)_ _________________ I'm looking for some rear wheels for my rail( 4lug), 8" wide up to 12" with or without tires, |
