Saggs Samba Member
Joined: December 23, 2003 Posts: 669 Location: Lincolnton, NC
Posted: Fri Jul 07, 2006 11:54 am Post subject: Ignition timing for a Bosch 019? |
I'm putting a Bosch 019 dist. in my 1600 dp single carb motor for my 67 westy. Anyone reccommend a timing setting for this dist? I think I'm running 7degs BTDC with the stock vacuum job. Thx _________________ "One man can make a difference...Jesus did." |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79276 Location: Sneaking up behind you
Posted: Fri Jul 07, 2006 11:57 am Post subject: |
Set it 28*-32* BTDC at 3000rpm.
You should never static time a mechanical distirbutor. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Saggs Samba Member
Posted: Fri Jul 07, 2006 12:26 pm Post subject: |
Glen, I have a stock vw pulley w/ no major timing marks, any suggestions where 28-33 degs BTDC would be? Maybe one of the press spokes on the pulley face? _________________ "One man can make a difference...Jesus did." |
oc63rag Samba Member
Joined: June 03, 2003 Posts: 2663 Location: Huntington Beach, CA
Posted: Fri Jul 07, 2006 12:36 pm Post subject: |
46mm from the TDC mark is 30 degrees. _________________ Designed for four soldiers and a machine gun...also for family use.
My food baby is crowning. |
Saggs Samba Member
Posted: Fri Jul 07, 2006 12:56 pm Post subject: |
oc, thx for the info-I assume that is 46mm along the top plane (edge) of the pulley? _________________ "One man can make a difference...Jesus did." |
Posted: Fri Jul 07, 2006 1:34 pm Post subject: |
Saggs wrote: |
oc, thx for the info-I assume that is 46mm along the top plane (edge) of the pulley? |
Correct. Once you measure the distance just mark it with a line of paint. _________________ Designed for four soldiers and a machine gun...also for family use.
GeorgeL Samba Member
Posted: Fri Jul 07, 2006 1:44 pm Post subject: |
Glenn wrote: |
You should never static time a mechanical distirbutor. |
Why? I've never had a problem with static timing mechanical, vacuum only, and SVDA distributors. I occasionally hook up the timing light to see if they are advancing properly to 30 degrees, but that is a diagnostic, not a setting method.
George |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Fri Jul 07, 2006 5:12 pm Post subject: |
GeorgeL wrote: |
Glenn wrote: |
George |
Because they vary in maximum advance (especially cheap 009s), and your advance at 3000 RPM is a hell of a lot more important than at 0 RPM.
Sounds like you've had good luck with distributors. |
Posted: Fri Jul 07, 2006 5:49 pm Post subject: |
Towel Rail wrote: |
GeorgeL wrote: |
Glenn wrote: |
George |
Not so much good luck as I've checked them at both ends of their advance curve. The only one I've had that didn't advance correctly is the worn-out DVDA that came in my bus. |
Glenn  Mr. 010
Posted: Fri Jul 07, 2006 6:53 pm Post subject: |
Saggs wrote: |
Glen, I have a stock vw pulley w/ no major timing marks, any suggestions where 28-33 degs BTDC would be? Maybe one of the press spokes on the pulley face? |
Print this degree wheel and use it to put a paint mark on the pulley.
Member #1009
#BlueSquare
Mark Samba Member
Joined: January 20, 2003 Posts: 1523 Location: Victoria, BC Canada
Posted: Fri Jul 07, 2006 9:33 pm Post subject: |
For what it's worth, with point-less pertronix, compufire, etc. systems, I find static timing to be useless. Besides, w/ the "quality control" of 009's I'd rather some comfort of knowing the total advance using a strobe. Yet another one of the Muir'isms that I strongly disagree with.
Having said that, I'm quite happy w/ my 009...so far.  _________________ www.zwerks.ca |
Posted: Fri Jul 07, 2006 10:22 pm Post subject: |
GeorgeL wrote: |
By luck, I meant that the ones you got had the correct advance. As 009s vary all over the map, would you feel right telling someone to just time theirs statically? I sure wouldn't. |
Randy in Maine Samba Member
Posted: Sat Jul 08, 2006 5:22 am Post subject: |
Glenn wrote: |
Excellent advice. |
Glenn  Mr. 010
Posted: Sat Jul 08, 2006 5:30 am Post subject: |
Randy in Maine wrote: |
Glenn wrote: |
Excellent advice. |
BTW... the 28*-32* needs to be "dialed in" due to the type of fuel, combustion chamber shape and compression. You want to have the most advance with out the engine "pinging". Start with 30 and if it pings, back down to 28. If it doesn't try 32. If you use Premium gas, then 32 will most likely be fine. _________________ Glenn
Member #1009
#BlueSquare
Posted: Sat Jul 08, 2006 11:16 am Post subject: |
Towel Rail wrote: |
GeorgeL wrote: |
I generally advise people to put the 009s on the shelf and use a better distributor!
I would be very leery of any distributor that varied from a reasonable advance curve. If it doesn't advance enough and you set 30 degrees at 3000 RPM you'll end up too far BTDC at idle. That isn't good either. |
saw2 Samba Member
Joined: November 06, 2008 Posts: 321 Location: nw Oregon
Posted: Sat Apr 30, 2011 6:51 am Post subject: |
My 019 advances to about 3200 rpms. Should I set timing at maximum advance. Or as most things I see about setting at 3000 rpm |
Glenn  Mr. 010
Posted: Sat Apr 30, 2011 7:11 am Post subject: |
Max advance, that's why I say to do it @ 3500rpm. _________________ Glenn
Member #1009
#BlueSquare
saw2 Samba Member
Posted: Sat Apr 30, 2011 7:23 am Post subject: |
Glenn wrote: |
Max advance, that's why I say to do it @ 3500rpm. |
Thanks, Glenn I was hoping for your answer. |
Boom Samba Member
Joined: September 29, 2007 Posts: 1119 Location: Houston by God Texas
Posted: Thu May 19, 2011 7:01 pm Post subject: |
just so I am sure, you always set the timing at full advance and it doesnt matter what the timing at idle ends up being.
mine idles @900 rpms and is @ 10 degrees _________________ Ovals are Overrated.....Click to view image
67 Chubby White Chic
Düg Büg
dLk |
Glenn  Mr. 010
Posted: Thu May 19, 2011 7:03 pm Post subject: |
You're fine.
019 only has 17* so at 28* total advance you'll have 11* initial. _________________ Glenn
Member #1009
#BlueSquare
