Shell Rotella?
ludawg
ludawg is offline
PostPosted: Thu Aug 10, 2006 9:29 am    Post subject: Shell Rotella? Reply with quote
Sick is anyone using this oil on the car? how does it run? is the oil temp. cooler and does it drive better? is the oil still clean after oil change??
CAN YOU USE LUCAS OIL WITH SHELL ROTELLA? i personally use pennzoil HD30 and i have been getting great MPG compared to thicker oils like 20/50 and HD40.
bciesq
bciesq is offline
PostPosted: Thu Aug 10, 2006 10:51 am    Post subject: Reply with quote
I use 15/40 Rotella in my single port 1600 daily driver. Seems to handle the Fla. heat well and is better in the winter than the thick 20/50 Castrol that I used to use.
Can't tell you about Lucas as I don't have any experience with it.
'73 Thing -- making 45 mph exciting again.
PostPosted: Thu Aug 10, 2006 11:02 am    Post subject: Reply with quote
There was just another thread about this:
http://www.thesamba.com/vw/forum/viewtopic.php?t=187716
Micropassatman
Micropassatman is offline
PostPosted: Thu Aug 10, 2006 2:40 pm    Post subject: Reply with quote
I like the Chevron Delo400. Similar to the Rotella. I don't know which is cheaper though.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Aug 10, 2006 2:47 pm    Post subject: Reply with quote
Shell Rotella T 15W-40 is all I use in my aircooled engines.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
RIS
RIS is offline
PostPosted: Thu Aug 10, 2006 2:58 pm    Post subject: Reply with quote
I believe Rotella has a higher zinc content than most oils, so that is a BIG plus...
Richard Sedoris - VW Performance & Machine - Youngstown, OH
http://rismachine.tumblr.com/
YouTube: https://m.youtube.com/channel/UCfTBCG4I61iVm_ROc8OAuOQ
Instagram: @rismachine
mharney
mharney is offline
PostPosted: Thu Aug 10, 2006 3:21 pm    Post subject: Reply with quote
Oh jeez. I am changing oils.
LOL jk Glenn.. are you going to give the crowd the post mortem on what happened to cause your blow?
Stripped66
Stripped66 is offline
PostPosted: Thu Aug 10, 2006 3:31 pm    Post subject: Reply with quote
It's in the upper-end of the "average"...
...oils like Valvoline Race (dino), Mobil 1 Synth, Royal Purple and Amsoil synthetic all contain more zinc than Rotella.
Even oils that are in the lower end of the "average" are not too far off. We've been talking about zinc in oil for too long, possibly propagating more myth than fact, and ultimately trying to place blame on the composition of oil rather than the quality of the parts that are failing (e.g. cams and lifters). Nothing wrong with Rotella (I've run it in my VW)...
TinCanFab
TinCanFab is offline
PostPosted: Thu Aug 10, 2006 6:22 pm    Post subject: Reply with quote
i use lucas with rotella myself on a turbo 2017. i havent had to use the external cooler yet while running around town with 100 degree heat. it's approved for gas engines as well. i think delo is pretty much the same thing, but didn't have gas engine certifications on the labels. it's very cheap and a more "old school" type of oil that VW would have recomended over the new crap for modern overhead cam engines.
if it's good enough for 1,000,000 mile diesel engines it's good enough for my expensive stroker. Wink
Micropassatman
PostPosted: Thu Aug 10, 2006 6:47 pm    Post subject: Reply with quote
My thoughts exactly!
Alan_U
Alan_U is offline
PostPosted: Thu Aug 10, 2006 7:33 pm    Post subject: Reply with quote
Comp Cams likes Rotella T for their flat tappets
read!!
http://www.hotrod.com/techarticles/engine/flat_tappet_cam_tech/
I've used Rotella T and Petro Canada Duron which is another diesel oil.
I put GM EOS in my oils too so I probably have triple the amount zinc.
Use whatever you like.
11.92sec pump gas true daily driver. Who says it cant be done.
No more time for VW's.......
67sleeper
67sleeper is offline
PostPosted: Thu Aug 10, 2006 8:19 pm    Post subject: Reply with quote
Thats all I use in my 2275 turbo efi/chargecooled squish street strip motor. I use the 20/50W flavor. Fully closed decklid .. oil temps 190F street driving.
ludawg
ludawg is offline
PostPosted: Thu Aug 10, 2006 9:26 pm    Post subject: Reply with quote
sounds like the oil is worth the try.
Banzai KG
Banzai KG is offline
PostPosted: Thu Aug 10, 2006 10:51 pm    Post subject: Reply with quote
I've been running the Shell Rotella-T for about 3 years now and I recommend it people I meet.
Jim Kikuchi
Sunnyvale (near San Jose), CA
1964 Karmann Ghia coupe
V.V.W.C.A. - Golden Gate Chapter: http://www.ggcvvwca.org/
B.L.T.N. (Better Late Than Never) late model VW Club (San Jose/Santa Clara, CA): https://www.facebook.com/groups/bltnvw/
NorCal Aircooled Group (NAG) Facebook Goup: https://www.facebook.com/groups/NAGVW/
Alan_U
Alan_U is offline
PostPosted: Fri Aug 11, 2006 8:10 am    Post subject: Reply with quote
Rotella T apparently has a good additive package. Besides a high dose of zinc and phosphorus it has other compliments to it.
The total base number TBN on the 15w40 is 11.6% so thats excellent for combating acid buildup in oil. .151% zinc is extremely high for an oil. That high even if you compare it to alot of synthetics.
A bottle of GM EOS has 1300 ppm!!!!!!!!!! of zinc. 1/3 the bottle will surpass all engine oils out there.
Rotella uses a good oil base but its probably a group 2 oil which is still dino oil (unless you buy the synthetic version)
We can all talk about how good an oil is but unless you do an oil analysis your just speculating. If your using a synthetic with PAO or Ester your more than likely gonna have good results.
If Comp Cams likes Rotella T thats good to know. I'll put blind faith just knowing a cam/lifter company uses it and recommends it.
Herby
Herby is offline
PostPosted: Fri Aug 11, 2006 8:15 am    Post subject: Reply with quote
Is the GM EOS an additive that you would put in at every oil change, or is it only for when you finish a motor build? The ladder is what seems to be what I'm getting from an article I read
62 Beetle
73 Super Beetle German Look project
03 TDI Jetta
Airspeed
www.airspeedvwclub.com
"Do not assume that there isn't room for improvement just because VW didn't do it."
Samba #34091
Mr. 010
Glenn is offline
PostPosted: Fri Aug 11, 2006 8:21 am    Post subject: Reply with quote
I use EOS only when first breaking in an engine and add it until there's 500 miles on the motor.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Loopole
Loopole is offline
PostPosted: Fri Aug 11, 2006 8:42 am    Post subject: Reply with quote
i run royal purple 5-30. the delo and rotella 15-40 are good oil, to heavy for cold weather running imo. when i switched to the royal puprple engine temps were noticeably cooler at freeway speeds
mharney
mharney is offline
PostPosted: Fri Aug 11, 2006 10:08 am    Post subject: Reply with quote
Yeah, that thinner oil will not bypass the cooler so much. I'd bet it is cooler. The RP that I used was 15-40, and it was cooler than 20-50 by about 20 degrees.
Oakley Diesel
Oakley Diesel is offline
PostPosted: Thu Sep 21, 2006 11:56 pm    Post subject: Reply with quote
I rebuid diesel engines profesionaly for a living most running rotela T and dello I have rebuit this with as many as 1,470,000 miles before needing rebuit and have seen no carbon buildup not even on the valves in the intake runners i dont think twice about running it in my 1776 diesel's are the best 600hp 2800ft pounds of torque and live this long pulling 80,000 lbs of cargo this is why i'm adidcted to torque
