Bellhousing for Bench Testing
Dangermouse
Dangermouse is offline
PostPosted: Tue Apr 03, 2007 7:17 pm    Post subject: Bellhousing for Bench Testing Reply with quote
Can anyone tell me if this transmission has the removeable bellhousing I've heard about that can commonly used to bolt up a starter motor to bench test Type I engines? Its for sale locally for not a lot of $$s...
"Early Kombi(?1959) gearbox rear axle assembly including reduction boxassembly etc & starter motor."
Lind
Lind is offline
PostPosted: Tue Apr 03, 2007 7:24 pm    Post subject: Reply with quote
that does not have the removeable bell housing. you can always take it apart and make a couple cuts to make it smaller.
Wanted:
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Tue Apr 03, 2007 7:47 pm    Post subject: Reply with quote
i have a bell housing cut for this i will sell you for 20 plus shipping
1958 custom camper
http://www.thesamba.com/vw/forum/viewtopic.php?t=483656
1957 oval
http://www.thesamba.com/vw/forum/viewtopic.php?t=426468&postdays=0&postorder=asc&start=0
1957 dd kombi
http://www.thesamba.com/vw/forum/viewtopic.php?t=186478&highlight=
Dangermouse
PostPosted: Tue Apr 03, 2007 8:01 pm    Post subject: Reply with quote
Thanks guys, I just thought it'd be handy as it was nearby. I'll keep looking...
Anyone know what particular year I should keep an eye out for?
Appreciate the offer but I suspect the cost of shipping a bellhousing to New Zealand could be a bit prohibitive...
Cheers Very Happy
///Mink
///Mink is offline
PostPosted: Tue Apr 03, 2007 8:11 pm    Post subject: Reply with quote
Cheers Very Happy
If it's cheap or free, why not just cut the bellhousing off of that one? That's what I have, works like a champ.
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Tue Apr 03, 2007 8:23 pm    Post subject: Reply with quote
yikes didn't catch the new zeland bit shipping would be 30$ tom mink has it chop the tranny you showed or for that matter just use it in neutral.
1958 custom camper
1957 oval
1957 dd kombi
sloans265
sloans265 is offline
PostPosted: Tue Apr 03, 2007 8:30 pm    Post subject: Reply with quote
Cheers Very Happy
Your looking for a '68 and later tranny. The bellhousing bolts up to the rear of the tranny. Slight difference between 68-71 and 72up. But both will work. That whats bolted to front of this stand
1970 Lotus White Panel
In search of any Pensacola Fla dealership items
Dangermouse
PostPosted: Tue Apr 03, 2007 8:32 pm    Post subject: Reply with quote
Partly because I’d be a bit reluctant to butcher what may be a perfectly good tranny that may be of use to someone else (parts aren’t all that plentiful down here), partly ‘cos I’ve got nothing to cut it with and partly ‘cos I’d then have to dispose of the remains Wink
I’m not in a desperate hurry for one, its just on my mental list of desirable bits to pick up if the opportunity presents itself...
BarryL Premium Member
BarryL is offline
PostPosted: Wed Apr 04, 2007 8:12 am    Post subject: Reply with quote
Partially because you don't want to spark the chips.
peaceful warrior
peaceful warrior is offline
PostPosted: Wed Apr 04, 2007 10:35 am    Post subject: Here is one for sale Reply with quote
http://cgi.ebay.com/ebaymotors/vw-bug-bus-ghia-eng...dZViewItem
"Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian
WideFive
SBS Hit Squad
WideFive is offline
PostPosted: Thu Apr 05, 2007 7:26 am    Post subject: Reply with quote
The bell housing you're looking for is a Bay Bus '68-'74 (maybe '75) Commonly referred to as a 3 or 5- rib. It'll have a 002 part number.
The later (6-rib) '75?-'79 bell housing is a 091 and takes a different starter. Much longer shaft, more expensive and harder to find used.
The 002 bell housing uses the same starter as any early Bug/Bus. The benefit being you can run a 6v or 12v flywheel/starter on it. With the 091 you can only run 12v flywheels.
Aaron D. Badertscher
Click here for ALL my links.
Dangermouse
PostPosted: Mon Oct 08, 2007 6:26 pm    Post subject: Reply with quote
How 'bout this one...?
Have no info on it sorry. Trying to get a part no...
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Oct 08, 2007 6:29 pm    Post subject: Reply with quote
Here's what a removable bell housing looks like.
Here's what a cut down bell housing looks like.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
BarryL is offline
PostPosted: Tue Oct 09, 2007 8:22 am    Post subject: Reply with quote
I thought they weren't removable until '72?
