Belt Guard Hits Alternator Nut
donmac
donmac is offline
PostPosted: Thu Jul 12, 2007 5:34 am    Post subject: Belt Guard Hits Alternator Nut Reply with quote
I'm installing the mesh type belt guard but the alternator spacer/acorn nut protrudes too far. I've seen several pictures where people have cut a hole to clear the nut. For example:
I'm wondering if the spacer/acorn nut can just be replaced with a regular nut for clearance or does the shaft itself have to be shortened? If just the nut has to be replaced, does any happen to know the shaft size so I can pick-up a new nut?
Thanks guys.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Jul 12, 2007 5:37 am    Post subject: Reply with quote
Just put a stock nut and spacer on.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
nomis
nomis is offline
PostPosted: Thu Jul 12, 2007 5:39 am    Post subject: Reply with quote
the stock nut should fit ok
i prefer the mesh guard as it looks good (imo), and you only have to snip out a couple of buts of wire to clear the tall pulley nut.
Any air cooled vw breaker will be able to send you a stock nut. You might struggle to find a metric nut of such a large size, but thin. (especcially in the US!). Smile
