doggerel Samba Member
Joined: July 04, 2007 Posts: 42 Location: North Pole, AK
Posted: Mon Sep 17, 2007 7:36 pm Post subject: 84 van - unknown hole in water pump housing |
There is a round 6 mm hole below and and down an inch down from my water pump drive shaft where it exits the housing. It has been leaking water; a steady drip drip. I don't see any threads for a zerk. Maybe one was pressed in during manufacture. The pump sez 'LASO' Made in W. Germany. I love the Samba.
Doggerel |
msinabottle Samba Member
Posted: Mon Sep 17, 2007 8:54 pm Post subject: The news could be better... |
As I recall, that's an indicator that your water pump is worn out. The wear on the parts inside exposes the hole and then you get the 'Saxon Water Torture' reminder to replace it.
Posted: Mon Sep 17, 2007 9:41 pm Post subject: |
you must be kidding me. The pump works well. There is zero wobble to the shaft and it spins freely. There is sign of what I would guess is dried out grease flakes in that hole. Small amounts of water have leaked in behind the impeller but I don't follow this mysterious hole. Saxon water torture. I needed a good laugh. Tell you were joking.
I can pit an awl 3/4 of an inch inside that hole before I hit any thing and it is not only a hole but a tiny shaft as it has sides all the way down.The more I think about tne dumber I feel. It has to be for a zerk fitting. |
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4570 Location: Cedar Falls, Iowa
Posted: Mon Sep 17, 2007 10:35 pm Post subject: |
doggerel wrote: |
Sorry, it is a weep hole. It relieves the water from the bearing when the seal fails, keeping the bearing from failing so soon.
Al _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
Posted: Mon Sep 17, 2007 11:27 pm Post subject: |
darn it..There it is. Thanks to both of you fellas. I'm fortunate to be able to mine the bottomless wealth of information here on the samba. Am lucky to that I have a new-used pump handy. Thank you, gentlemen. |
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Tue Sep 18, 2007 4:46 am Post subject: |
doggerel wrote: |
Now the "fun" in replacing it. If you plan to do it yourself, search here on "waterpump", and you will come to a couple of threads in your search about the "fun" folks go through in replacing it. Removing its pulley, getting at the water hose clamps, etc.
The good news is that once it is done, you're good to go for another 100K or so. _________________ Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181 |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10149 Location: Abiquiu, NM, USA
Posted: Tue Sep 18, 2007 9:08 am Post subject: |
Depends: 1.9 wbx; real bitch of a job. 2.1 wbx; easy-greasy.
Every water pump for all types of engines has a weep hole to relieve the seal. It works just as Al says it does. Sometimes a brand new pump will drip one or two drops from there when it is first run, as the seal packing absorbs some coolant, so don't be alarmed; it will stop. Depends on how long the part has been is storage. |
