EuroVan roof rack flying off?
patrickkidd
patrickkidd is offline
PostPosted: Wed Mar 05, 2008 11:48 am    Post subject: EuroVan roof rack flying off? Reply with quote
My from roof rack (the whole section of white plastic roof over the front seats) freakin flew off somewhere south of Jackpot, NV yesterday. It looks like it's held on by those two black racks, which are only riveted and glued to the roof!! I can't believe the construction is so dodgy for that part.
has that ever happened to anyone, and is it possible to get a new one, it doesn't look like a simple repair, and it also seems like it should be bolted to the steel when I do.
tds3pete
tds3pete is offline
PostPosted: Wed Mar 05, 2008 1:01 pm    Post subject: Reply with quote
I've never heard of this one before.
The rack is held on by four steel support brackets, which are each held on by two large pop rivets each. The luggage bars then bolt to the steel brackets, and sandwich the roof rack in place. There is also one sheet metal screw in the pan area at the front that screws into the body top.
These folks should have all of the parts you are missing:
http://www.winnebagoparts.com/
I wonder if a previous owner tied something large to the luggage bars that somehow broke some the pop rivets loose. If you are concerned about it, I guess you could scare up some heavier blind nuts to use instead of replacing the pop rivets.
'58 Westy camper-come and gone
'73 Westy-bought new in Holland,now gone
'86 Syncro weekender-come and gone
'79 Westy...Oscar
'95 Eurovan Camper/5 spd...Marsha Mellow
patrickkidd
PostPosted: Thu Apr 03, 2008 10:12 pm    Post subject: Reply with quote
I got the part yesterday from winnebagoparts.com, thanks for the link. They were very helpful and made the part to order. Funny thing is that they used black plastic instead of white. I'll just stick it on and see how it looks, maybe it will match the yakima box Smile
patrickkidd
tds3pete
tds3pete is offline
PostPosted: Fri Apr 04, 2008 4:55 pm    Post subject: Reply with quote
Seems like they ought to give you something off the price to allow for painting. The originals were all white.
'79 Westy...Oscar
