breva1906 Samba Member
Joined: November 05, 2007 Posts: 55 Location: Indialantic, Florida
Posted: Fri Apr 04, 2008 1:33 pm Post subject: Alternator with DF, D+, D- tabs, Does it need ground? |
I have a '64 Beetle converted to 12V (40hp) with an alternator. The alternator has electric connection tabs labeled DF, D+, D-. I am not getting the charge light in the speedo when i turn the key, or when I start the engine. The only diagrams I can find suggest connecting the light to the D+ on the Alternator, and I have connected it and metered it. The readind show the 12V coming from the fuse (and the oil pressure light on the same feed does work). I confirmed the bulb is good.
Do I need to ground the Alternator?
Thanks. |
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6541 Location: Northern Illinois
Posted: Fri Apr 04, 2008 5:39 pm Post subject: |
The charge light (blue wire) should be spliced into the red wire at the voltage regulator. Where is your regulator mounted ? There is normally a secondary ground screw from regulator mounting screw to a threaded hole on the top of the alternator case. This ground wire is more of a "just in case" than manditory but the factory used it so I do too. _________________ Midwest Autosavers, Inc. Crystal Lake, IL |
Posted: Sat Apr 05, 2008 4:05 am Post subject: |
Thanks, DrDarby.
There is a voltage regulator under the car (under the back seat). It appears to have been disconected (maybe when the car was converted to 12V. Would I be correct in thinking I'll need to get a 12V voltage regulator? Could I mount it in the engine compartment?
There was another alternator with the car when I bought the car. The other alternator had only the battery connection and D+, there was not any DF, or D-. Am I safe in assuming that one was an internally regulated? and the one I installed is externally regulated?
Breva1906 |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Sat Apr 05, 2008 8:13 am Post subject: |
breva1906 wrote: |
Thanks, DrDarby.
There was another alternator with the car when I bought the car. The other alternator had only the battery connection and D+, there was not any DF, or D-. Am I safe in assuming that one was an internally regulated? and the one I installed is externally regulated?Breva1906 |
That is what it sounds like to me...
You will have to get a voltage regulator for that style... not the same as the generator style V reg.
http://www.thesamba.com/vw/classifieds/detail.php?id=567854
http://www.thesamba.com/vw/classifieds/detail.php?id=393097
http://www.thesamba.com/vw/classifieds/detail.php?id=567423 |
Posted: Sat Apr 05, 2008 11:41 am Post subject: |
Thanks for the help.
I ordered one. |
