bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Mon Apr 07, 2008 5:03 pm Post subject: Replaced stablizer link |
Thanks to a post given by a fellow "Samba-nite", I was easily able to press the stablizer link on to the sway bar. I removed the sway bar from the vehicle (easy, removed the two horseshow clamps holding the sway bar to frame) and the other bolt of the non broken stablizer link.
I then brought the assembly inside the house, heated the new stablizer link (with new bushing) in a boiling pot of water, placed it on a piece of cardbord on the floor, then pressed the sway bar end into the bushing hole while twisting. It went in easily withing a few seconds.
Coated the bottom shafts of the two stablizer links with anti-sieze (to keep them from rusting in their sleaves), and bolted everything back up.
Good as new. Thanks for the boiling water trick to whomever suggested it in a previous post. _________________ Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181 |
