deprivation Samba Member
Joined: September 14, 2006 Posts: 1220 Location: Austin, Texas
Posted: Tue Jun 03, 2008 1:59 pm Post subject: Powering fan right off alternator? |
I added an oil cooler recently, including a fan. The whole shebang is in the hollow by the passenger-side tail light.
I haven't powerd the fan up yet because I'm not sure exactly where I'm going to draw the power. Is it okay to get it right off the alternator or should I run power all they way back from the battery or fuse block?
THANKS! _________________ 1986 Westy 2WD auto a.k.a. "The Old Girl"
www.kittenfart.com |
GWTWTLW Samba Member
Joined: April 22, 2008 Posts: 2174 Location: Portland, OR
Posted: Tue Jun 03, 2008 2:04 pm Post subject: |
I wouldn't wire anything directly to the alternator. Seems like that would be a good way to fry things. I would tap into the fuse box personally. I've wired things directly to my aux batteries but not the primary one. Just my $0.02 _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
FNGRUVN Samba Member
Joined: October 27, 2007 Posts: 2237 Location: Fort Collins, CO
Posted: Tue Jun 03, 2008 9:53 pm Post subject: |
The battery wire on the alternator goes directly to the battery. What's the difference between the connection there and the connection at the battery? Nothing. I would put an inline fuse near the alternator, though. |
Posted: Tue Jun 03, 2008 10:11 pm Post subject: |
You can power it from the alternator or starter, but you need a way to turn it on and off that is 100% dependable. |
Posted: Tue Jun 03, 2008 10:34 pm Post subject: |
FNGRUVN wrote: |
That's what I was thinking. THANKS!!!! _________________ 1986 Westy 2WD auto a.k.a. "The Old Girl"
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Wed Jun 04, 2008 4:00 am Post subject: |
Any time you install an electrical device, it should be fused. This is the cause for many electrical fires in vehicles; owners that install boom box radios, and other electrical accessories without them being properly protected, with a correctly rated fuse for the device.
Don't connect directly to the alternator without installing a fuse. _________________ Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181 |
Captain Pike Samba Member
Joined: December 30, 2003 Posts: 3437 Location: Talos IV, Piedmont Arizona
Posted: Wed Jun 04, 2008 5:53 am Post subject: |
bucko wrote: |
Don't connect directly to the alternator without installing a fuse. |
Bet your bippy, that's sound advice. Use a relay to controll it. _________________ LEARN TO SELF RESCUE
....Bad Sneakers.... |
Posted: Wed Jun 04, 2008 6:24 am Post subject: |
bucko wrote: |
Yep, you betcha. Got the fuse and a relay already wired in. Just wasn't sure about where to get the power!
Again, THANKS!!!!! _________________ 1986 Westy 2WD auto a.k.a. "The Old Girl"
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10147 Location: Abiquiu, NM, USA
Posted: Wed Jun 04, 2008 10:57 am Post subject: |
So how is your relay triggered? I'm assuming you have a thermoswitch to turn on the fan, but what control are you using so the fan only runs with ignition on? Or are you going to let it do the VW radiator-fan mambo, where the fan can run at any time until it does enough cooling to open its thermoswitch? _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
Experience is death to doctrine. |
Posted: Wed Jun 04, 2008 12:49 pm Post subject: |
tencentlife wrote: |
So how is your relay triggered? I'm assuming you have a thermoswitch to turn on the fan, but what control are you using so the fan only runs with ignition on? Or are you going to let it do the VW radiator-fan mambo, where the fan can run at any time until it does enough cooling to open its thermoswitch? |
Theremoswitch? Oh, you wish I was that smart. So do I.
The relay is powered off of - what is it - P or G? Whatever one is hot when the engine is keyed on. Sitting here right now I can't remember. And the thermo switch is typing right now.
The cooler as-is without the fan engaged seems to be doing good. At extended highway speeds across the Texas hellscape I am getting 40psi at 4k rpm even on a mild climb or better. On the biggest extended hill climb it may have dropped a bit below 40psi. There are no major, major climbs near me so I don't know how it will do going from Phoenix to Flagstaff at high noon. I'll find out in a few weeks. In the city it does 40-50psi or so at 4k or better.
So the fan will be triggered by me until I get one of those thermo-switches. It ain't fancy but budget-wise, that's where I am. _________________ 1986 Westy 2WD auto a.k.a. "The Old Girl"
kayakwesty Samba Member
Joined: February 15, 2007 Posts: 687 Location: East Tennessee
Posted: Wed Jun 04, 2008 1:03 pm Post subject: |
I have mine with a thermo-switch AND a relay that is controlled off the front radiator switch, if it comes on(front radiator) , the fan on the cooler comes on., or the thermo-switch turns it on.
I also have an over-ride switch on the dash that turns on the cooler fan and the stock radiator fan.
I'm a control freak...I'll admit
my power is comes from an auxillary fuse box I made, that is mounted beside the factory fuse box , and I use AGC glass fuses.
http://www.kayakwesty.com/oilcooler.html _________________ 1984 Westy 2.0 Jetta ABA Motor/1.8 head converted to auto tranny, with 180,000 on body, 55K on engine and transmission
B.5.5 Passat Wagen with 30v V6-67000 Miles
DAS AUTO
CHANGE YOUR FUEL LINES!
A post without pictures is useless
http://www.waldensridgewhitewater.com/
dr. no Samba Member
Joined: August 06, 2004 Posts: 579 Location: Santa Fe
Use a relay with primary power from the alternator (with a fuse ) and switching power from the coil (Or a thermoswitch). _________________ Scott
http://lungehphoto.com
'83.5 Westy s/p 1.6td JX and 4sp DK transplant
'09 Jetta SportWagen TDI
'06 MB Sprinter
'86 Iltis
'89 Isuzu Trooper
PAST VWs:
'82 NA diesel Vanagon
'86 7-passenger Vanagon
'77 Bay
'71 Bay
'74 Things (2)
'69 Karmann Ghia (the only one I miss--in nice weather, anyway...)
'91 Fox |
Posted: Wed Jun 04, 2008 6:20 pm Post subject: |
Inline oil thermostats look like this:
http://www.cbperformance.com/catalog.asp?ProductID=1330
They suggest installing it on the inlet side of the cooler, but it's better to put it on the return side. No point in overcooling the oil. You do want it hot, just not too hot.
You could come off the alternator + pole for power if you want, as a supply for the relay. As signal, I don't favor coming off #15 on the coil, as it lowers the voltage there and tends to cause problems with the ignition. Instead, and closer to your application, test the two wires on the power steering pump switch: one of them goes hot when ignition is on. This one is safe to use as a switched signal source. Tee onto that, route it to the inline thermoswitch, and finally to the coil of your relay, the other side of the coil going to ground. Or run the signal power from the PS switch to one side of the relay coil, and ground the other side via the thermoswitch. Either way will work.
Glad you're going to oil cooling. I think it's an essential mod for engine longevity and peace of mind. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
