Vw to Powerglide trans
RJReynolds
RJReynolds is offline
PostPosted: Wed Jun 25, 2008 6:27 pm    Post subject: Vw to Powerglide trans Reply with quote
does anyone have information on putting a powerglide to a vw engine. Any help on this would be great. Smile This is going in a light weight 1/8 mile race car.
Dale M.
Dale M. is online now
PostPosted: Wed Jun 25, 2008 7:55 pm    Post subject: Reply with quote
You might give these people a try....
http://www.kennedyeng.com/
Dale
SRP1
SRP1 is offline
PostPosted: Thu Jun 26, 2008 8:00 pm    Post subject: Reply with quote
Here:
http://secure.chassisshop.com/partdetail/C12-300/
They have the crank adapter hub too.
Jimmy111
Jimmy111 is offline
PostPosted: Thu Jun 26, 2008 8:28 pm    Post subject: Reply with quote
I think that the VW motors rotation is not compatible with a powerglide.
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Thu Jun 26, 2008 9:53 pm    Post subject: Reply with quote
That makes sense, because you have to reverse the rotation of a Corvair to use it with VW transaxles.
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
SRP1
SRP1 is offline
PostPosted: Thu Jun 26, 2008 10:40 pm    Post subject: Reply with quote
Both VW engines and standard Chevy V-8 engines along with most other engines rotate clockwise, so running a VW on a glide, TH-350, 400, 700R4 etc, is no problem at all. The Corvair however rotates counterclockwise, its the black sheep.
miniman82
Samba Swamp Donkey
PostPosted: Fri Jun 27, 2008 2:38 am    Post subject: Reply with quote
Maybe that's why I like it. Razz
Dale M.
PostPosted: Fri Jun 27, 2008 9:48 am    Post subject: Reply with quote
And some HONDA motors.....
Dale
joescoolcustoms
joescoolcustoms is offline
PostPosted: Mon Jun 14, 2010 2:20 pm    Post subject: Reply with quote
Digging up a old thread.
I am looking at building a dragster with a VW engine mounted mid-ship, feeding power into a power glide hooked to a 12 bolt chevy rear end.
I have found the adapters from Chassis Shop for both the mating of the engine to the trans and the flywheel to the flexplate.
But I cannot find a way of mounting a starter.
Any ideas?
Bad News Racing 2018 NORRA 1000 3rd in Class
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
earthquake
earthquake is offline
PostPosted: Mon Jun 14, 2010 2:37 pm    Post subject: Reply with quote
I have been looking at this as well, I don't think a power-glide would be the first choice, I think I would use a turbo 350 instead. I think you would need more torque to pull a glide on the drag strip, I have heard that some are using turbo 200's now in some high horse power applications and they are lighter to boot. as for starting the motor, I haven't figured it out yet either.
Casey
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
nobuggybob
nobuggybob is offline
PostPosted: Mon Jun 14, 2010 6:06 pm    Post subject: Reply with quote
Just turn the vw trans upside down Laughing
You Can't Quit Poverty
Unkl Ian
Unkl Ian is offline
PostPosted: Mon Jun 14, 2010 6:20 pm    Post subject: Reply with quote
What does Marty use for a starter ?
Juice C
Juice C is offline
PostPosted: Mon Jun 14, 2010 6:35 pm    Post subject: Reply with quote
Any ideas?
If you can mount the vw crank to the Gm flexplate then it will use the GM starter.
drmiller100
drmiller100 is offline
PostPosted: Mon Jun 14, 2010 6:44 pm    Post subject: Reply with quote
Any ideas?
GM's usually mount the starter to the block, right about where number 3 cylinder is on a VW.
with a vw engine and a GM transmission, you have nothing to actually bolt the starter to, and no where for it to physically live.
exciter
exciter is offline
PostPosted: Mon Jun 14, 2010 8:18 pm    Post subject: Reply with quote
I had built a dragster with a glide about 15 yrs ago and i fabbed up a 1/4" aluminum plate for my rear engine mount and tranny belling housing mount the i install the gm starter under the #1 cylinder so that when it was bolted on it layed under the 1 2 cylinder banks? I hope this helps. good luck and post up pics as you go.
P.S. vw paradise can hook you up with the adapter i think.
Joe
MIsandshark
MIsandshark is offline
PostPosted: Tue Jun 15, 2010 5:28 am    Post subject: Reply with quote
theres companys that make ford bell housings to mate to a power glyde, cut the gm off and bolt the bell to the front pump housing. ford starters are mounted to the bell housing, teeth count might be an issue to use a ford starter on a gm flywheel but a spurgear is easy to fab or retrofit
joescoolcustoms
PostPosted: Tue Jun 15, 2010 8:46 am    Post subject: Reply with quote
Casey
At first I thought that too, but a record still stands from 1986 that was made with a glide. When mated up to a 12 bolt chevy rear or a ford 9 inch, ratios of the ring and pinion into the low 6's can be had off the shelf. Or if a quick change rear is used they can go into the 7's.
That was one of my first options, but like mentioned above, the starter hits the sump/# 3 cylinder area of the VW block.
I have picked up 2 converters for a glide. A 8 inch 6200 rpm and a 7 inch 6800 rpm. Both are ATI brand and each have had 4 passes put on them.
I talked extensively with my machinest about this yesterday and he does not see a problem setting up a cup/mount surface to weld into the glide bellhousing for a high torque VW starter to mount into. The gear teeth match up rather nicely on a GM 168 tooth flexplate.
Looks like I will be ordering the adapter from Chassis Shop today to get started.
sandhopper
sandhopper is offline
PostPosted: Tue Nov 21, 2017 9:33 am    Post subject: Re: Vw to Powerglide trans Reply with quote
Joescoolcustoms
Did this ever happen ? I too would like to do a powerglide and VW setup in a front engine 23 T bucket project
I have access to someone that can do the machine work just need some ideas / pictures and measurements
mark tucker
mark tucker is offline
PostPosted: Tue Nov 21, 2017 10:03 am    Post subject: Re: Vw to Powerglide trans Reply with quote
a more modern 4-5-or 6 speed auto would be best to stay in the power band,a pg with a vw engine on the street may be a hot running dog.I was thinking about doing it to my roadster and 904 race trans with 6500 stall converter witch should be about right for a vw motor.
joescoolcustoms
PostPosted: Tue Nov 21, 2017 10:21 am    Post subject: Re: Vw to Powerglide trans Reply with quote
sandhopper wrote:
Joescoolcustoms
I went a different direction entirely. Got into Fiberglass buggies and got stuck there. But I am re-building my Manx for April's NORRA 1000 race in Baja Mexico. So I am still into racing, just a different type where I can drive more than 6 seconds at a time.
