63karmanng Samba Member
Posted: Wed Jul 16, 2008 3:33 pm Post subject: Erco wheels..what studs/lug nuts? |
I just bought a set of Erco wheels. The holes in the wheels are tapered. I want to run stud/lug nut. I'm still running drum brakes so I can't use press in studs. Does anyone know where I can find a combo of the studs/lug nuts? Thanks in advance.
Mike _________________ I don't think that the voltage matters because the gauge is mechanical. |
Posted: Thu Jul 24, 2008 5:11 pm Post subject: |
BUMP _________________ I don't think that the voltage matters because the gauge is mechanical. |
MAYHEM Samba Member
Joined: January 30, 2006 Posts: 1813 Location: Warm and sunny coastal CT
Posted: Sat Jul 26, 2008 6:24 pm Post subject: |
I have convo pros (wide 5) that I believe have what you are talking about.
I run screw in studs. The washers and lugs are cup shaped not flat. I don't know an exact size or place to get them. Maybe try airkewld.
Hope that helps. _________________ Greg
Model Citizen
johnnypan wrote: |
I digitize myself in the privacy of my own home. |
JDGas Samba Member
Joined: June 23, 2004 Posts: 1233 Location: Escondido
Posted: Tue Jul 29, 2008 12:06 am Post subject: |
The set of Ercos I have are drilled for 12mm studs and are not cut for a ball seat or a 60 degree acorn style lug. First off you need to figure out what style lug they are cut for.
Center Lines are cut for a ball seat to accept the stock lug bolts.
Ok, so you'll need you standard 12mm screw in lug stud. That we know. A 12mm 60 degree acorn style lug you can get just about anywhere. Now, if it's a ball seat, you can either use the (ugly) stock lug bolts, or locate some chrome ones. If you are looking for the race look of a gold cad open end lug nut, you are in luck. So. Cal. Imports has them. They just started carrying them. I just picked up a set a few weeks ago.
From them a set of studs and the 12mm gold cad nut will run you about $60.
Here they are on a set of Center Lines.
_________________ 1959 Ragtop Beetle - sold
1958 Danish Beetle
1967 SO-42 West. - sold
1961 Sunroof Beetle - sold
1969 Sunroof Beetle |
JDGas Samba Member
Posted: Tue Jul 29, 2008 12:09 am Post subject: |
MAYHEM wrote: |
Hope that helps. |
Just viewed your gallery. Nice car, man! _________________ 1959 Ragtop Beetle - sold
1958 Danish Beetle
Posted: Tue Jul 29, 2008 6:06 pm Post subject: |
Thanks for all your help you guys. I think I'm going with Sway A Way 14mm press in studs I saw through CB Performance. Thanks again for all the help and advice!!  _________________ I don't think that the voltage matters because the gauge is mechanical. |
MAYHEM Samba Member
Posted: Wed Jul 30, 2008 4:37 am Post subject: |
JDGas wrote: |
MAYHEM wrote: |
Hope that helps. |
Just viewed your gallery. Nice car, man! |
Thanks and likewise  _________________ Greg
Model Citizen
johnnypan wrote: |
