914 Push Rod Tube Removal
pedrok
pedrok is offline
PostPosted: Sun Aug 24, 2008 9:01 am    Post subject: 914 Push Rod Tube Removal Reply with quote
Hi Guys!!
I been having a hard time pulling the push rod tubes with the engine in my car, I have twisted and pull with pliers with no good luck, bend it a little bit don't want to damage it, is there a special tool? did not found any tread here or at the web.
Thank you.
Pedro
gilbequick
gilbequick is offline
PostPosted: Sun Aug 24, 2008 11:13 am    Post subject: Reply with quote
Spray it with some kind of penetrating oil and let it soak in a bit and then try pulling and twisting again. There's no special tool that I know of, you could try using a strap wrench if you have one. If you damage them just order replacements.
Jacks
Jacks is offline
PostPosted: Sun Aug 24, 2008 11:19 am    Post subject: Reply with quote
Put a round piece of metal inside the tube so you don't crush it. I use a 12mm deep socket. Twist away!
pedrok
pedrok is offline
PostPosted: Sun Aug 24, 2008 11:20 am    Post subject: Reply with quote
hi Gilbequick, Thank you for your advice, I will try it this weekend, need to check the hydraulic lifters condition.
Pedro.
pedrok
pedrok is offline
PostPosted: Sun Aug 24, 2008 11:25 am    Post subject: Reply with quote
hi Jacks, I will also use a metal protector.
Thank you all for the fast response!!
Bleyseng
Bleyseng is offline
PostPosted: Sun Aug 24, 2008 8:26 pm    Post subject: Reply with quote
914's didn't come with hydraulic lifters!
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles
pedrok
pedrok is offline
PostPosted: Mon Aug 25, 2008 7:59 pm    Post subject: Reply with quote
Hi Bleyseng,
Some people change them to hydraulic, I wish a had solids.
Pedro
