fuel pressure for a Weber carb?
bug-nuts
bug-nuts is offline
PostPosted: Thu Sep 25, 2008 1:38 pm    Post subject: fuel pressure for a Weber carb? Reply with quote
I bought my first bus awhile back (1978 Westfalia that the PO changed to a single Weber carb) and am slowly getting it road ready. I'm going to change the fuel lines, add a pressure regulator and try to get the carb. Adjusted this weekend. It has an electric fuel pump but I don't know if it's the OG or a replacement.
What should I set the pressure at for a carburetor, and do I need high pressure fuel line if I add the regulator directly after the pump? Reading about all the fires has me spooked, are these fuel line failures caused by the pressure, the heat or a combination of both? It seems like the fuel line available at most parts stores are rated for a pretty high temperature range but I don’t know at what pressure. I’m guessing the carb. Will only need 6-8 psi, and if so can I use standard fuel line?
Thanks,
Ken
Whoever smelt it, dealt it.
1973 Thing
1978 Westy
1998 Beetle
VDubTech
VDubTech is offline
PostPosted: Thu Sep 25, 2008 1:43 pm    Post subject: Reply with quote
Carb only needs about 3.5 psi max. Fires are caused by old, dry rotted fuel lines coming apart and spewing fuel all over hot engine components and/or engine components that spark (coil/distributor). Anything you can buy at your local FLAPS isn't the right stuff to use on your Bus. The fuel line is metric and very few places have it. German Supply carries a kit with all necessary lines already cut to fit and ready to roll. I would get it runnin and get the proper fuel injection back on that engine. The difference will be night and day.
Wildthings
Wildthings is offline
PostPosted: Thu Sep 25, 2008 1:45 pm    Post subject: Reply with quote
Your fuel pump should say on it somewhere what the output pressure is. You only need 4psi or so to feed the carb. Any new rubber fuel line should do you well enough for starters, but running as much rigid steel as you can and using SS braided AN line elsewhere will give you and extra margin of safety.
Randy in Maine
Randy in Maine is offline
PostPosted: Thu Sep 25, 2008 1:47 pm    Post subject: Reply with quote
You want your fuel pressure to be about 2.5-3.5 psi. Most $20 vacuum gauges will be able to check it.
Fuel lines just get tired and like to crack and split. It may have something to do with the fuel or the quality of the hose, but change them all out about ever 3-5 years so that you can sleep well at night. Use the good clamps that do not cut into the hose. A good grommet will also help keep the hose from getting chafed as it runs through the metal.
Regular fuel line will work in your application due to the low PSI involved, but nothing wrong with 7mm FI hose either if it fits this application.
Been here?
http://www.germansupply.com/home/customer/product.php?productid=17280&cat=300&page=4
Oil Phil-M
Oil Phil-M is offline
PostPosted: Thu Sep 25, 2008 5:45 pm    Post subject: Reply with quote
I have dual IDFs with a mechanical fuel pressure gauge permanantly mounted on one of the carb fuel line inlets. Set my pressure regulator at 1.5psi. I find after I stop the vehicle the fuel must soak up the heat and expand cuz after 5 -10 minutes the psi will go over the 3.5 recommended max.
bug-nuts
bug-nuts is offline
PostPosted: Fri Sep 26, 2008 5:33 am    Post subject: Reply with quote
I plan on using one with a bypass back to the tank which will keep this from happening.
1973 Thing
1978 Westy
1998 Beetle
Oil Phil-M
PostPosted: Sat Sep 27, 2008 10:00 am    Post subject: Reply with quote
How and where do you run the return line? Can you tee off the pump outlet line and feed it back to the inlet side of the pump so any excess pressure can flow back into the tank or will that just give you zero fuel pressure?
I think I could have used one of the outlets on the holley regulator as a return line. Instead I chose to install it in the engine bay as high up as possible as a means to curb gravitational gas flow out of the tank. I wasn't sure how i would run a return gas line from inside the engine bay so I used the two outlets as a tee for each of the carbs.
The pump itself is suppose to only produce 4psi so I didn't think excess pressure would be an issue but I didn't realize how much effect heat has on increasing the pressure in the line.
Oil Phil-M
bug-nuts
bug-nuts is offline
PostPosted: Sat Sep 27, 2008 11:37 am    Post subject: Reply with quote
I've not looked specifically into the VW system yet, but I have never seen a fuel system with an electric pump that did not have a return line back to the tank. As far as a mechnical pump, I've seen some with a return line and some without.
1973 Thing
1978 Westy
1998 Beetle
Wildthings
PostPosted: Sat Sep 27, 2008 11:46 am    Post subject: Reply with quote
Low pressure pumps for use with carburetors typically do not need a return line to the tank. The return line is for cooling the pump which is needed if you are pumping a large volume of excess fuel at high pressures for a FI system.
Oil Phil-M
PostPosted: Mon Sep 29, 2008 10:01 am    Post subject: Reply with quote
I was mistaken with my regulator, there is no by-pass return outlet option. It is available but its on a different regulator that is in the 4-8psi range which is no good. No return line option on the fuel pump I have either so I guess I'm leaving things the way they are.
