Durability of Stage 2 heads
biancovw
biancovw is offline
PostPosted: Fri Dec 12, 2008 6:35 am    Post subject: Durability of Stage 2 heads Reply with quote
Can Steve Tims stage 2 unwelded heads hold up with a 10.5:1 compression,and not crack?
grimace007
grimace007 is offline
PostPosted: Fri Dec 12, 2008 7:09 am    Post subject: Reply with quote
why dont you ask him?
steve is a very honest cat, him or greg ( his son i think? ) both will tell you whats up.
my personal opinion is that they should handle that and then more. to get some more replies you may want to change the title of the post.. i came here thinkin it would be a clutch topic.
maybe tims stage 2 heads.
Brian
68 sedan
Dallas Air Coolers
perrib wrote:
Hey It is The Samba where well thought out rational answers can take a while and getting side tracked is normal. I was just lucky this time. Smile
cr@M wrote:
No one has any personal responsibility these days. This country is sue happy. Intelligence is no longer a requirement, just an accessory.
perrib
perrib is offline
PostPosted: Fri Dec 12, 2008 9:56 pm    Post subject: Reply with quote
These Tims heads hold 14 to1 so 10-1 on smaller heads should be no problem.
EvolveES
EvolveES is offline
PostPosted: Fri Dec 12, 2008 9:58 pm    Post subject: Reply with quote
Which heads ae those, are they the stage 2's, i'm looking at a set for a 2110cc fair weather driver.
grimace007
PostPosted: Fri Dec 12, 2008 10:00 pm    Post subject: Reply with quote
those are his welded race heads.
Brian
68 sedan
Dallas Air Coolers
EvolveES
EvolveES is offline
PostPosted: Fri Dec 12, 2008 10:11 pm    Post subject: Reply with quote
Oh, Duh, i should have seen the huge welds right in front of me Very Happy those are nice but unfortunately out of my budget.
thanks man
biancovw
biancovw is offline
PostPosted: Sat Dec 13, 2008 12:53 am    Post subject: Reply with quote
yeah,bit I ment unwelded heads,Stage 2's which are on the special price now Smile
Stripped66
Stripped66 is offline
PostPosted: Sat Dec 13, 2008 1:00 am    Post subject: Reply with quote
The Stage 2's and Steve Tims' Signature race heads all start from the same casting.
66brm wrote:
Bodacious wrote:
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor.
I don't think electrickery works that way
biancovw
biancovw is offline
PostPosted: Sat Dec 13, 2008 1:24 am    Post subject: Reply with quote
but welded are much stronger,or?
Stripped66
PostPosted: Sat Dec 13, 2008 1:27 am    Post subject: Reply with quote
The weld is simply to build up material above the intake port wall to allow for a larger port. It contributes very little, if at all, to the strength of the combustion chamber.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Dec 13, 2008 5:43 am    Post subject: Reply with quote
I'm running 9.5:1 with Stage 2s.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
perrib
perrib is offline
PostPosted: Sat Dec 13, 2008 7:09 am    Post subject: Reply with quote
I meant if you can take that much out of a stock head and it remain durable the Stage Twos will be durable. Welding heads is just for being able to put the port where no aluminium was present in the stock casting.
Get the Stage Twos you won't be dissapointed.
craigman
craigman is offline
PostPosted: Sat Dec 13, 2008 11:28 am    Post subject: Re: Durability of Stage 2 heads Reply with quote
Just about ANY type 1 head will crack. It's a very common thing. The only place a type 1 head will crack is between the valves. Sometimes around the spark plug, but not as common.
People run with crack heads with no problems all the time. The only way to get a type 1 head not to crack between the valves is have the biggest valves you can put in them where the valve seats actually touch. But that not practical on most engines.
grimace007
PostPosted: Sat Dec 13, 2008 11:43 am    Post subject: Re: Durability of Stage 2 heads Reply with quote
craigman wrote:
Just about ANY cylinder head will crack. there. fixed that one for ya
It's a very common thing. yes
The only place a type 1 head will crack is between the valves. Sometimes around the spark plug, but not as common. sure why not.
People run with crack heads with no problems all the time. yes they do, doesnt mean its ideal.
The only way to get a type 1 head not to crack between the valves is have the biggest valves you can put in them where the valve seats actually touch. But that not practical on most engines. flat out period NO FALSE WRONG ANSWER
i have put about 30k on a set of heads without cracking them and have seen heads with over 100k without cracks.
its all about how your setup and how you take care of your engine. make sure you have proper cooling, and proper warmup.
i dont know where you got your info from craig but i disagree strongly.
Brian
68 sedan
Dallas Air Coolers
craigman
craigman is offline
PostPosted: Sat Dec 13, 2008 1:01 pm    Post subject: Reply with quote
Only you would think it's a clutch topic.. Rolling Eyes
grimace007
PostPosted: Sat Dec 13, 2008 1:15 pm    Post subject: Reply with quote
before he edited the topic all it said was stage 2 durability, way to go you got me.im a moron for thinking about a kennedy PP
Brian
68 sedan
Dallas Air Coolers
Bruce
Bruce is offline
PostPosted: Sat Dec 13, 2008 5:02 pm    Post subject: Re: Durability of Stage 2 heads Reply with quote
Cracking is caused by overheating.
Why are you so hung up on having 10.5:1 CR? What gas are you gonna use?
biancovw
biancovw is offline
PostPosted: Sun Dec 14, 2008 2:32 am    Post subject: Re: Durability of Stage 2 heads Reply with quote
Out here in Europe we have 98 octane fuel.
grimace007
PostPosted: Sun Dec 14, 2008 8:47 am    Post subject: Reply with quote
what method is your octane measured i know its different than here in the states. i cannot remember the differences offhand but im sure someone knows and will chime in with it.
the heads will handle but man that is ALOT of compression for a "fair weather" driver. im sure you could make it driveable.
but 9:1 with an engle fk-8 and those stage 2 heads from steve tims on a 2 liter make for a KILLER setup and 100% driveable
ask glenn lol
im not sure what his compression is exactly but its close to 9:1 im pretty sure.
Brian
68 sedan
Dallas Air Coolers
biancovw
biancovw is offline
PostPosted: Sun Dec 14, 2008 9:00 am    Post subject: Reply with quote
ask glenn lol
we have RON measurment for fuel,I think that is that.
