vw1964type1 Samba Member
Joined: May 29, 2008 Posts: 47 Location: South Africa
Posted: Thu Feb 12, 2009 12:30 pm Post subject: Gotech management system |
OK so Scott Novak has convinced me to go with a higher than stock energy ignition.
Please can some of you answer my questions if you don't mind
Questions:
I am replacing the stock ignition because a "computer" controlled advance curve will allow me to get maximum HP at all revs as opposed to a standard dizzy which is normally set for full advance at 3000 to 3500RPM ie. The stock dizzy might not have a perfect advance curve. Am I right in saying this?
Also, how would one go about installing a computer controlled ignition? I was thinking that coil packs might be the way to go as I don't understand how using a dizzy in conjunction with the Gotech will work? Can somebody please explain this in english?
I am also thinking that I may want to upgrade to F.I and turbo at a later stage. The Gotech system can be used to actuate injectors, thus I would think that a $1000.00 spent on the system now to only manage ignition will save me money should I wish to also at a later stage incorporate the F.I.
Sorry, but we don't have Jacobs in my country so I am basically stuck with using Gotech.
Their web address is www.gotech.co.za
Thank you for any replies.
Brandt Theunissen _________________ 2009 550 Spyder replica build in progress
2007 Mercedes ML550
2005 Mercedes SLK350 |
The Noof Samba Member
Posted: Thu Feb 12, 2009 12:39 pm Post subject: |
D.I.S. is by far the most acurrate format,using coil packs or c.o.p.
Miniman has engineered a setup for his car.Maybe he will see this post.If not,p.m. him and he can fill you in. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20834 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Feb 12, 2009 12:46 pm Post subject: |
Have you looked at Mega Jolt or Megs Squirt system for ignition control and Fuel injection?
http://www.bgsoflex.com/megasquirt.html
http://www.autosportlabs.net/Main_Page
Dale _________________ “Fear The Government That Wants To Take Your Guns"
Marv [UK] Samba Member
Posted: Thu Feb 12, 2009 3:14 pm Post subject: Re: Gotech management system |
vw1964type1 wrote: |
Questions:
Brandt Theunissen |
depends entirely on what you intend plugging it into.
If it's stock, you could spend $1000 better elsewhere.....
the stock dizzy is fine for almost every single application it has enough advance mechanically to put you in the power band on all motors and still let you idle without frying the heads and the 205 has the vacuum advance function as well for allowing more economical and possibly cooler running.... don't be under the false impression that the stock dizzy won't cut it cos it will. an 010 is better than a 009 and a 205 is an 009 with vac advance too basically
Going turbo however is a different matter. Spark mapping is crucial with a turbo or you will very quickly see parts of your engine out of the car and accelerating away in a shower of money.
Spark mapping and control needent be done with a $1000 system though, especially on an FI motor. |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Thu Feb 12, 2009 5:01 pm Post subject: |
The Noof wrote: |
D.I.S. is by far the most acurrate format,using coil packs or c.o.p. |
Ding ding ding, we have a winner! Crank triggered ignitions lay claim to having the most stable and accurate spark, period. I don't care what Scott says about lightning bolt coils and wide distributor spacing and all that stuff. Will a strong spark help your engine? Yes, but unless there's something seriously wrong with what you've already got, you're not likely to notice a difference.
vw1964type1: you are correct about distributors not having the correct curve to suit every application, but here's the caveat- you have to know what is best to get it to work. In other words, just because you may have the best ignition on the planet, doesn't mean squat if you don't know what to do with it. But it costs money, which explains why half the VW people out there slap an OO9 on their engine instead of actually making it run RIGHT. Not saying OO9's don't work because I've used them with success myself, I'm saying I've moved on to something immesurably better- Megasquirt with Ford EDIS crank fired ignition.
The Noof wrote: |
Miniman has engineered a setup for his car. |
Actually, I didn't really engineer anything. All the parts for my car were out there waiting to be used, it just took me (and my meddling) to place them in their current configuration. That said, check my build thread. The links in my signature have a lot of information. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Scott Novak Samba Member
Joined: October 12, 2004 Posts: 1586 Location: Minneapolis, Minnesota
Posted: Thu Feb 12, 2009 6:58 pm Post subject: |
Actually, using a the series connected dual terminal "Coil Packs" is a step backwards from a single ignition coil per cylinder. It fires one pair of spark plugs with reversed polarity that have a different arcover voltage. This will result in unequal ignition lag times and two of the cylinders will be running with slightly retarded ignition timing. It's a compromise economy ignition system.
Using a distributorless ignition system does NOT mean that you must forgo a high energy ignition system.
Jacobs made this ignition system for an 8 cylinder engine with 4 series connected coil paks in a wasted spark configuration.. However it can also be used on a 4 cylinder engine with 4 separate ignition coils in a non-wasted spark configuration for maximum performance. Or you can use two series connected coil paks in a wasted spark configuration.
But even if you don't use a Jacobs ignition system, there are a number of different ways that you can drive a separate ignition coil for each cylinder. It just depends on the ignition controller that you use.
The ignition coil that you use is extremely important to the performance of the ignition system, whether you are using one ignition coil per cylinder or one ignition coil pak for a pair of spark plugs in a series connected wasted spark configuration. A variable permeability ignition coil with an air gapped core is the only type of ignition coil that should be used, unless you just can't find them in your country.
While Miniman claims that high energy ignition systems won't make much improvement, he is also using an ignition system with a substantially higher energy output than the stock VW ignition system.
Distributorless means the voltage is not being distributed by a distributor. You can still use a conventional distributor as a trigger for an ignition system with electronic advance if you don't want to or aren't ready to set up a crank trigger. It is still a distributorless ignition system. You are just using the traditional distributor only as a timing device, not as a spark distributor. The distributor cap is only used as a cover to keep the elements out.
Some electronic ignition control units can be set up to use the distributor as a trigger. I don't think that the Go-Tech system can. You will need a multi-tooth reluctor wheel to trigger the GoTech.
The main advantages to using a distributorless ignition system is easy programming of the spark timing and the ability to use even larger spark plug gaps because you don't need to worry about crossfiring inside a distributor cap.
A good quality distributor can have the spark timing advance curve adjusted to be very close to ideal for full throttle acceleration. Adding a vacuum advance can have the spark timing curve very close to ideal at part throttle conditions.
A cold engine can run with more spark advance than a hot one. A good electronic advance system also has the capability to adjust the spark timing according to the engine temperature. It's also possible can also adjust for barometric pressure and altitude. You can also use a detonation sensor to adjust the spark timing. However, it is constantly hunting and varying the spark timing and isn't necessarily a better system.
There is a lot of extra complexity to using a programable electronic ignition control system. Unfortunately many of them also compromise the spark quality. I wouldn't consider using one unless I was also using a fuel injection system.
There are tradeoffs between using a distributor and an electronic ignition control system. It just depends on what features are more important to you.
Scott Novak |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79659 Location: Sneaking up behind you
Posted: Thu Feb 12, 2009 7:00 pm Post subject: |
Please pass the pop corn. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Thu Feb 12, 2009 10:51 pm Post subject: |
Thank you for the replies thus far.
I have a 2276 engine. At the moment it still has the carbs and stock ignition (009)dizzy We only get the 009 here.
Can the crank sensor be put onto the crank pully or must it be put onto the flywheel? Gotech states that you may use a distributor as a triggering device. Would this be sufficient?
Running individual coils sounds like a good idea. Has anyone got pictures to give me an idea as to how to install them. We don't have too many Ford vehicles here and those we do have are from England. However we do have lots of riceburners. Can anyone tell me which riceburner will have the coils I am looking for? _________________ 2009 550 Spyder replica build in progress
2007 Mercedes ML550
Posted: Fri Feb 13, 2009 2:39 am Post subject: |
Can the crank sensor be put onto the crank pully or must it be put onto the flywheel? |
From what I've seen you'll need to mount the trigger wheel to the crank pulley.
Gotech states that you may use a distributor as a triggering device. Would this be sufficient? |
You might need to use the type of distributor that VW used on the newer Mexican fuel injected Beetles. I don't think that you can easily configure it to trigger from a 009. GOTECH doesn't appear to be a configureable as other DIS FI systems that I have seen. Maybe Miniman can shed more light on this.
The GOTECH doesn't have any adaptive spark control in the ECU itself. They do appear to sell optional ignition modules with some form of dwell control that can be used with the ECU.
Running individual coils sounds like a good idea. Has anyone got pictures to give me an idea as to how to install them. We don't have too many Ford vehicles here and those we do have are from England. However we do have lots of riceburners. Can anyone tell me which riceburner will have the coils I am looking for? |
Sorry. I'm not sure which, if any, rice burners are using variable permeability ignition coils.
BTW, ANY series connected coil pak can be operated as a single coil per spark plug by connecting the positive high voltage terminal to ground. You would need 4 dual high voltage terminal coil paks.
Scott Novak
RUI FARIA Samba Member
Joined: July 23, 2004 Posts: 176 Location: Johannesburg, South Africa
Posted: Fri Feb 13, 2009 2:54 am Post subject: |
Go to www.aircooledvwsa.co.za there is some info on Gotech, one of the members "4agedub" sells the system as well as installations done on aircooled motors. _________________ 42 year old technology & still kicking butt. |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3509 Location: Charleston, SC
Posted: Fri Feb 13, 2009 6:46 am Post subject: |
I gave a monkey a squirt bottle and trained him to squirt fuel into the intake ports...voila, fuel injection.
Currently, I'm training another monkey to strike a flint in the direction of the combustion chamber. If I get 3 more monkeys to do it, I should have the equivalent of coil-on-plug ignition.
You all suck. _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Posted: Fri Feb 13, 2009 6:52 am Post subject: |
Stripped66 wrote: |
You all suck. |
succinct and informative, please let us know how you get on |
Posted: Fri Feb 13, 2009 7:01 am Post subject: |
Marv [UK] wrote: |
Stripped66 wrote: |
You all suck. |
My engine management system flings poo on the competition. _________________
66brm wrote: |
Bodacious wrote: |
Posted: Fri Feb 13, 2009 7:09 am Post subject: |
Stripped66 wrote: |
Marv [UK] wrote: |
Stripped66 wrote: |
You all suck. |
My engine management system flings poo on the competition. |
So they use both hands then, what about their feet and tails...
Are you sure it's cost effective employing 4 lazy monkeys instead of the one multitasker.... i mean, if he can fling poo, squirt gas and knock flints together fast enough..... you might be able to get him to cook some eggs too.. |
Posted: Fri Feb 13, 2009 7:18 am Post subject: |
Marv [UK] wrote: |
You can eat eggs cooked by a poo flinging monkey if you want...I don't. _________________
66brm wrote: |
Bodacious wrote: |
Posted: Fri Feb 13, 2009 7:28 am Post subject: |
deleted
Posted: Fri Feb 13, 2009 7:29 am Post subject: |
Thanks for the reply Scott, I will be seeing an expert on Gotech tommorrow morning
Stripped66, who shook your cage this morning? Maybe it was the monkey sleeping next to you(You know the one with the squirt bottle)?
Your uncalled for remarks really doesn't tell me much apart from the type of character you have.
Now piss off and go and feed your monkey. _________________ 2009 550 Spyder replica build in progress
2007 Mercedes ML550
Posted: Fri Feb 13, 2009 7:37 am Post subject: |
Now piss off and go and feed your monkey. |
I've got one trained for vengeance.
On another note, since you've handcuffed your choices to gotech, I don't see any ignition-only products. The only thing on their website are full EMS. Were you planning on using one of their full EMS just to control ignition, or was there another product you were interested in that Gotech doesn't list on their website? _________________
66brm wrote: |
Bodacious wrote: |
