512dude Samba Member
Posted: Tue Jul 21, 2009 4:26 pm Post subject: Fuel Tank Cross Over Pipe - My Fix |
Tired of the nylon fittings busting on the cross over tube (this is the 2nd time for me) and the fact that VW has discontinued them I decided to make my own fittings.
This took me a few hours on a lathe and got me what I needed.
I really was ready to just fabricate my own fuel tank and eliminate the whole cross-over equlization and venting non-sense but that was going to take a bit more time. I'd really like to thermo form a poly-tank but would have to price that out as well as the tooling. Maybe if I had a whole lot of youse guys commit to a bigger lighter poly tank we could make it a tank co-op effort and split the costs.
ProvoCyclist Samba Member
Joined: December 07, 2004 Posts: 642 Location: Murray, Utah
Posted: Tue Jul 21, 2009 5:15 pm Post subject: |
Sir, this is awesome! Welcome to the Samba! _________________ Clark
Current: 1986 Tintop GL 2wd, stock 2.1L, manual trans, Savanna Beige Metallic LH1V.
Past: 1985 Sunroof GL, 2wd, Subaru 3.3L, manual trans, resprayed to Diamond Silver L97A |
RCB Samba Member
Joined: September 05, 2005 Posts: 4143 Location: San Francisco-Bay Area
Posted: Tue Jul 21, 2009 5:22 pm Post subject: |
I must be a french fry shy of a Happy Meal but I dont see a few hours on a lathe.
I see a 90' brass angle piece and another brass piece sticking out of it.
Looks as if a drill bit could have accomplished the same thing.
Im interested so please explain. |
James 93SLC Samba Member
Joined: January 21, 2009 Posts: 937 Location: NE Ohio
Posted: Tue Jul 21, 2009 5:38 pm Post subject: |
Am I the only one not seeing the pictures ??
edit: seeing them now, but only after switching rendering in Firefox from IE back to Firefox. Weird  |
VisPacem Samba Member
Joined: July 15, 2007 Posts: 1143 Location: Las Vegas
Posted: Tue Jul 21, 2009 11:19 pm Post subject: |
| James 93SLC wrote: |
No, you are not the only one, count me in. I do not see the pictures either and... I use Safari. _________________ LG aka VisPacemPB, *The* party Pooper
No Regrets (Nothing to do with Vanagons) |
randywebb Samba Member
Posted: Tue Jul 21, 2009 11:35 pm Post subject: Re: Fuel Tank Cross Over Pipe - My Fix |
| 512dude wrote: |
| ... Maybe if I had a whole lot of youse guys commit to a bigger lighter poly tank we could make it a tank co-op effort and split the costs. ... |
I've often been told I should be committed. |
deprivation Samba Member
Joined: September 14, 2006 Posts: 1220 Location: Austin, Texas
Posted: Wed Jul 22, 2009 8:01 am Post subject: |
Maybe re-do the post. I'm not seeing the pictures, either. _________________ 1986 Westy 2WD auto a.k.a. "The Old Girl"
www.kittenfart.com |
shadetreemech Samba Member
Joined: October 05, 2005 Posts: 831 Location: Claremont, CA
Posted: Wed Jul 22, 2009 8:10 am Post subject: |
| deprivation wrote: |
| Maybe re-do the post. I'm not seeing the pictures, either. |
As above, I first opened the thread in Firefox, no pics. Then I opened it in IE, could see the pics, then when I came back to Firefox, pics visible!
I'm tryin' to figure out where the lathe comes into play. Did he turn that hose out of a rubber billet?
 _________________ '84 GL 1.9
'01 Volvo V70 T5
'88 Westy - "MZDRTHY" |
Posted: Wed Jul 22, 2009 10:33 am Post subject: |
Let me explain...
You are correct, the part you see is an off the shelf fitting but I did need to modify it by taking the barbs off the neck from one side so that it sealed well against the grommet. My tests showed that with the barbs in place it didn't retain itself as well and I figured I might as well do it right the first time. However. since I am an amateur machinist I had to figure out how to hold that fitting in the lathe so I could turn the neck down. That part took me the longest until I discovered a 4 jaw chuck hiding in the cabinet below the machine.
I turned down the two fittings and then drilled a hole 45 degrees to the corner of the elbow. I then found a 1/4" barbed fitting that also needed to be turned down to fit inside the hole I drilled.
Last step was to braze the two parts together to get a good seal.
dbo550 Samba Member
Joined: August 28, 2008 Posts: 365 Location: Kentucky
Posted: Wed Jul 22, 2009 10:40 am Post subject: |
I don't have access to a lathe so how much would you sell a set of those for? _________________ 1985 Westy
2001 Audi Allroad
1999 Volvo v70 xc
1995 Volvo T5-R, Yellow
1998 Jetta GLX |
randiego Samba Member
Joined: October 13, 2008 Posts: 75 Location: San Diego
Posted: Wed Jul 22, 2009 10:54 am Post subject: |
| Quote: |
| Tired of the nylon fittings busting on the cross over tube (this is the 2nd time for me) and the fact that VW has discontinued them I decided to make my own fittings. |
Does this happen often? How would I know - gas leaking all over?
I just replaced the crossover, using GW's aftermarket part... (which was too short but that's another story...) |
Posted: Wed Jul 22, 2009 11:06 am Post subject: |
Busted fittings result in gasoline leaking on to the top of the tank - especially when full - and a strong odor of fuel after filling the tank. If you jack up the front end of your vehicle you can reach thru the wheel well and check the fuel cross over line fittings to see if they are cracked. I can just weasel my arm thru the wheel well when my van is not jacked-up but it is tricky. I was doing this occasionally at the gas pump after filling up to check for leaks.
Re: costs for making a tube....I'm checking what it would cost in larger quantities with options to supply folks with them
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10153 Location: Abiquiu, NM, USA
Posted: Wed Jul 22, 2009 8:16 pm Post subject: |
Excellent solution. Well done. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
Experience is death to doctrine. |
westylife Samba Member
Joined: October 28, 2007 Posts: 410 Location: Anchorage, Alaska
Posted: Thu Jul 30, 2009 11:24 am Post subject: |
Nice Job! You better get a patent for this quick before someone steals your idea I can think of one person on here who is probably trying this out right now (its not me). Mail yourself a copy of your drawings and don’t ever open it, save that for a judge. I'm not sure how far you want to go with this but it’s just an idea.
And you got an EXCELLENT from tencent so you know you are golden
I would be interested in this as well.
Cheers, _________________ 1983.5 Westfalia Bostig RG1 |
RadioRental Samba Member
Posted: Thu Jul 30, 2009 12:00 pm Post subject: |
This is awesome work!
Very briefly.. on the 'patent' idea, I wouldnt rush out just yet. While not exactly quite like the design above, and not suitable for our petrol tanks I found this on the first search
"3/8" OD x 1/4" ID Reducing Tube Tee with 1/4" x 1 /8" Side Barb sized for the smaller Primer Line (as shown in picture with tubes attached). Price = $ 3.44 each"
http://www.lakeaviation.ca/accessories.html?CategoryID=102
I'm sure with a little more digging one could find a better match for our requirements.
I'm not trying to piss on anyone's parade, this is a great custom solution (especially machining off the upper barb) |
insyncro Banned
Posted: Tue Aug 18, 2009 6:03 am Post subject: |
I would highly recommend getting intouch with VanCafe.
They are looking for people such as yourself and great Vanagon specific fixes to sell for you.
They could sell many I'm sure.
Nice job.
Good price.
dylan |
Mr. Electric Wizard Samba Member
Joined: August 07, 2003 Posts: 2846 Location: Smyrna, TN
Posted: Tue Aug 18, 2009 6:37 am Post subject: |
Right on!
I knew somebody would step up...
 _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
(T)exas (C)oalition (B)uses
(H)eidenhammer (B)ully (B)oyz
--1966 De Luxe Camper |
newt909 Samba Member
goffoz Samba Member
Posted: Tue Aug 18, 2009 8:25 am Post subject: |
I've always wondered why VW used 2 expansion tanks in the system?
...with the cross over tube..wouldn't just one be enough?  |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19065 Location: Retired South Florida
Posted: Tue Aug 18, 2009 8:36 am Post subject: |
| The top of the fuel tank has a low spot down the center to accomodate I believe the heater tube on an air cooled vanagon and the shift linkage. This design left the fuel tank with two identical high spots. The engineers probably felt it necessary to vent both sides independently which included the two tanks. The cross over tube was neccessary to equalize the atmoshpere on both sides of the tank on fill up. Just a guess. |
