travis1488 Samba Member
Joined: July 19, 2005 Posts: 164 Location: Piedmont MO
Posted: Thu Feb 04, 2010 11:39 am Post subject: Weber Velocity stack |
CB sells some stacks that are 1'' tall. I need some short ones to clear unifilters i have. Will they still serve their purpose being that short? |
Eric_S Samba Member
Joined: August 12, 2007 Posts: 862 Location: Sparks (think Reno) NV
Posted: Fri Feb 05, 2010 2:34 am Post subject: |
Velocity stacks serve a couple purposes.
1. Funnel the air in. The air no longer has to turn a 90° corner which costs energy that could otherwise be used to draw in more fuel/air.
2. Contain fuel stand-off. The bigger the cam the more valve overlap and therefore the more stand-off. That's why you see the BIG stacks on the drag racers with the 51.5 IDA's.
So, you know your combo. Would you benefit? You would at least from point #1. _________________ --
Eric_S
What are all these extra parts? |
chambersc Samba Member
Posted: Fri Feb 05, 2010 5:20 am Post subject: |
I don't mean to Bogart your post here, but I am installing a set of original height velocity stacks on my 44IDF's right now and the damned studs aren't tall enough for the filter base plate and velocity stacks from CB Performance. Anyone else ever ran into this? I'm having to file down the base of my stacks in order to make them clear. Kind of frustrating on brand new parts to mess them up like that. _________________ "It's no accident that the word LISTEN and the word SILENT contain the same letters." |
Posted: Fri Feb 05, 2010 6:22 am Post subject: |
I had to back the studs out of the carb so they would be long enough. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20829 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Feb 05, 2010 6:57 am Post subject: |
chambersc wrote: |
I don't mean to Bogart your post here, but I am installing a set of original height velocity stacks on my 44IDF's right now and the damned studs aren't tall enough for the filter base plate and velocity stacks from CB Performance. Anyone else ever ran into this? I'm having to file down the base of my stacks in order to make them clear. Kind of frustrating on brand new parts to mess them up like that. |
Get longer studs....
http://www.nutsandbolts.com/stud-index-metric-sae-uss-metric-studs-c-30_131_132.html
OR some similar place...
Dale _________________ “Fear The Government That Wants To Take Your Guns"
nextgen Samba Member
Joined: August 19, 2004 Posts: 6149 Location: CONGERS, N.Y.
Posted: Fri Feb 05, 2010 7:10 am Post subject: |
Velocity stacks are not there to look pretty. If you have two engines drawing exactly the same amount of air, by changing the stacks height and shape you can increase the speed at which the air enters the carbs. Thus having a different effect on each engine. Short is usually good for quick response, tall are more for long runs at higher speeds which usually give better mileage.
The air at the mouth of the stack is compressed as it gets to the restricted area and picks up Velocity as it enters the carb. Without the stacks the air would be in chaos at the top of the carb. _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
