Class 11 Look-a-like
norris
norris is offline
PostPosted: Fri Mar 05, 2010 3:01 pm    Post subject: Class 11 Look-a-like Reply with quote
I have a 74 SB that is very good original condition. I live in West Texas and have access to several state park areas close to my house. I don't drive my VW on the street that much, but I would use it in the wilderness area if it had a little more ground clearance. What is the easiest way to lift the front and rear a bit so I could use 235 or even 9.50 tires? I do realize that the Super Beetle is not the best candidate for off-road racing, but that's not what I'll be using it for.
Anyway, any suggestions for an easy 2"-3" lift would be appreciated.
Thanks!
vindeta
vindeta is offline
PostPosted: Fri Mar 05, 2010 3:27 pm    Post subject: Reply with quote
i dont know much about the McPherson strut front.....
but with the back tho preloading the torsion bars just like a normal beetle is the easiest way to go without spending money and drastically changing things up.
75 baja in progress!
http://www.azbaja.com/ForumsPro/viewtopic/t=5767.html
build thread^^
View user's profile Send private message Facebook Classifieds Feedback
norris
norris is offline
PostPosted: Fri Mar 05, 2010 4:25 pm    Post subject: Reply with quote
Would some type of coil-over shocks work for the rear lift? Are there stiffer front struts that might work to gain a couple of inches of lift?
ottvw
ottvw is offline
PostPosted: Fri Mar 05, 2010 5:08 pm    Post subject: Reply with quote
I believe there are spacers for the front but that will only give you 2" of lift.The coil overs are junk and will just make it stiff.Do it right and get a standard.
Save a tree eat a beaver
rubsterob
rubsterob is offline
PostPosted: Fri Mar 05, 2010 7:48 pm    Post subject: Reply with quote
x2
but take a look in the baja super beetle thread they might tell you how to lift it
First car orange '72 class 11 lookalike
vindeta
vindeta is offline
PostPosted: Fri Mar 05, 2010 7:50 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=401200
Yea i have a 71 Sb , The biggest problem you will face is the front end needs to be higher and after a few jumps the struts will tend to bend. Which will cause the tires to rub on the springs. What i did to compensate for that is use Riviera rims that kick out the tires just enough to avoid rubbing on the springs. Another thing you can do if get a hold of some rear rabbit springs and place those springs in the stock SB springs that way you will raise the car about 3 inches and have duel springs. Oh and before i forget one problem that you might face down the road is the bolts the clamp the sway-bar to the pan tend to brake off. I remedied this by making a hole on the side of the pan head and put in thicker bolts and put a nut on the opposite end.[quote]
build thread^^
Win Or Break!
Win Or Break! is offline
PostPosted: Sat Mar 06, 2010 2:18 am    Post subject: Reply with quote
dam i'm already quoted yea duel springs was the best decision i ever did!Finally got the pics up so here you go
Win Or Break!
PostPosted: Sat Mar 06, 2010 2:29 am    Post subject: Reply with quote
Sorry first time posting pictures
[/img]
norris
norris is offline
PostPosted: Sat Mar 06, 2010 8:21 am    Post subject: Reply with quote
I'm not going to be jumping ANYTHING. All I need is enough clearance so I could run larger tires which would allow better ground clearance. The paths I'll be taking do not allow speeding or what you guys are thinking of when "off roading" is mentioned.
Just thought someone may have lifted a SB without cutting things up or screwing up the ride. All I need is a couple of inches lift.
earthquake
earthquake is offline
PostPosted: Sat Mar 06, 2010 5:35 pm    Post subject: Reply with quote
I don't see why you could not build a bracket to lower the control arms ane make some spacers to lower the top of the struts. I have seen it done on rally cars.
Casey
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
