SOLVED: Clogged passage - Kadron/Solex
atye
atye is offline
PostPosted: Tue Mar 09, 2010 6:13 am    Post subject: SOLVED: Clogged passage - Kadron/Solex Reply with quote
I have a clogged passage on a Kadron/Solex carb that I cannot get opened up. The carbs are almost new, low miles, but have been sitting for a while and the gas turned into gummy goop. I cleaned one, no problem, but the other is refusing to cooperate. I am new to Kadrons and need some help on what is the best way to fix this issue.
On the clean carb, if I squirt carb cleaner into "A", it comes out at "1", "2", and "3". On this carb, nothing. It just blows right back out of the hole. I was able to pull some of the gummy stuff out, and I have soaked the carb in the Berryman stuff from my FLAPS. Still no difference. Well, besides the Berryman carb cleaner turning a nice shiny carb into something that looks like it survived an engine fire...Thanks, Berryman!
Is it possible to remove the jet "2" to allow access to this area? Any other ideas on how to clean it?
Alex
1990 Audi 90q 20v sedan
1998 Suzuki Sport Sidekick
2002 Suzuki Grand Vitara
2005 Subaru Legacy GT wagon 5spd Turbo AWD
vwtaiwan
vwtaiwan is offline
PostPosted: Tue Mar 09, 2010 6:43 am    Post subject: Reply with quote
Hi, I always heat up the casting by Hot air gun( or hair dryer), after real hot like 180~200 degree, and you pull up air correction jet #2.
http://www.thesamba.com/vw/forum/viewtopic.php?t=364481&highlight=
atye
atye is offline
PostPosted: Tue Mar 09, 2010 6:48 am    Post subject: Reply with quote
I had thought of using a heat gun, but was scared that I might harden whatever was in the passages even more. I knew that there had to be a way to remove it, though.
Thanks for the tip. I will try it at lunchtime today.
Alex
Type 5 Joe
Banned
Type 5 Joe is offline
PostPosted: Tue Mar 09, 2010 7:02 am    Post subject: Reply with quote
A screw from a bug tail light lens (like a 1962 - 1967) should screw in there so you can pull it.
If you would like to contact me, just email through one of my ads on here...
I don't use the P.M. service on here.
atye
atye is offline
PostPosted: Tue Mar 09, 2010 7:31 am    Post subject: Reply with quote
Isn't there the possibility of changing the size of the opening that way?
Alex
nsracing
nsracing is offline
PostPosted: Tue Mar 09, 2010 7:33 am    Post subject: Reply with quote
Don't put any screw in there. Buy a ultrasonic cleaner or find someone who has one.
Type 5 Joe
Banned
PostPosted: Tue Mar 09, 2010 8:10 am    Post subject: Reply with quote
I'm talking about the brass #2 in your picture.
I am just going off memory here.... Isn't it internally threaded already?
If it is, I think a taillight lens screw will thread in there and help you "pull" it.
- Or just use the screw for comparison, and go down to the hardware store and get a similar screw.
You won't alter the size in any way.
Let us know if it worked for you.
atye
atye is offline
PostPosted: Tue Mar 09, 2010 8:52 am    Post subject: Reply with quote
No, it is not threaded that I can tell. It is not slotted at the top like the main jet is either. It appears to be press-fit, why, I don't know.
I am going to try vwtaiwan's idea and use a heat gun to expand the metal and allow it to (hopefully) fall out easier.
Alex
DarthWeber
DarthWeber is offline
PostPosted: Tue Mar 09, 2010 11:23 am    Post subject: Reply with quote
The Kadron carbs were designed for a narrow range of applications, basically to use on stock or almost stock 1600 motors. As such they weren't designed with 'tune-ability' in mind. Only the main and idle jets are easily changed. Yes, they can be modified to work with big motors as AJ Sims has sucessfully demonstrated over the years, but they weren't designed to be adaptable to many different sizes and types of motors like Webers and Dellortos. The emulsion tube was designed to cover performance ranges on stock or mild 1600 motors and never intended to be swapped out to modify the fuel flow characteristics so it was installed, more or less permanently, in the carb.
atye
atye is offline
PostPosted: Tue Mar 09, 2010 11:26 am    Post subject: Reply with quote
Well... Now I know!
Smile
Thanks for the info.
Alex
vwtaiwan
vwtaiwan is offline
PostPosted: Tue Mar 09, 2010 3:28 pm    Post subject: Reply with quote
You need to heat up, very hot more than 180 degree, the aircorrection jet should be very easy to pull up. If you can't pull it up, and it's not hot enough.
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Tue Mar 09, 2010 9:29 pm    Post subject: Reply with quote
I use a deluded solution of CLR for cleaning out the passages of old carbs.
Works well with out doing any damage. I only let them soak for a short period of time. At the most 1 hour in the solution then rinse in water.
It is something I learned from and old Corvair mechanic.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
atye
atye is offline
PostPosted: Wed Mar 10, 2010 6:04 am    Post subject: Reply with quote
Well, I was able to remove the air correction jet with the heat gun method. It took a few tries, but it eventually fell out... in TWO pieces!
It looked very similar to vwtaiwan's pic below, except mine wasn't cracked.
I put the two parts back together and it was a tight fit, but, just to be safe, I added a tiny amount of red loctite and made very sure that none got anywhere else in case I need to remove this again!
The passage was actually clean inside, it was the detached bottom half of the air correction jet that was blocking the passage. I am convinced that this is why the PO wasn't able to get the car running and it sat for all these years.
After this repair, the car idles and runs good, but the carbs still need some tuning. I am sure that the PO was turning all sorts of screws trying to figure out what was going on.
Chalk one more up to The Samba!
Thanks for all of the suggestions!
Very Happy
Alex
matthew henricks
matthew henricks is offline
PostPosted: Tue May 27, 2025 8:20 am    Post subject: Re: SOLVED: Clogged passage - Kadron/Solex Reply with quote
Super helpful post. My engine went from running good to not at all in a second. It took me a while to notice that one carb was blocked from the float bowl and the emulsion tube was the problem.
FWIW, i used a screw extractor to grab the top of the tube after heating the carb and was able to pull it out without much damage.
1964 Original Owner build Thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=702135&highlight=
Ambulance Fan's. https://www.thesamba.com/vw/forum/viewtopic.php?t=627707&highlight=
Parts i am looking for:
64 bug nice used front/rear Black LHD floor mat.
Brian_e Premium Member
Brian_e is offline
PostPosted: Tue May 27, 2025 8:51 am    Post subject: Re: SOLVED: Clogged passage - Kadron/Solex Reply with quote
A good easy way to test for a broken emulsion tube is to blow air through the smaller aux vent in the carb throat. Use an air compressor with a blow gun. If its all connected and working correctly, the fast moving air will pull fuel out of the bowl, and into the carb throat.
If it has come disconnected, nothing will happen.
Brian
So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts
