Boble Samba Member
Joined: November 13, 2005 Posts: 745 Location: Oslo, Norway
Posted: Fri Apr 23, 2010 3:33 pm Post subject: The alternator charges 13.8 volts. Is that OK? |
I measure 13.8 - 13.9 volts output from the alternator. It's a 1976 model with the latest type alternator with built-in charging relay.
Is 13.8 Volts OK, or should it be more? |
marklee Samba Member
Joined: March 24, 2009 Posts: 821 Location: Flintshire, North Wales
Posted: Fri Apr 23, 2010 3:35 pm Post subject: |
13.8 volts sounds good to me try with the headlights on at idle..... _________________ CGLI qualified body repair and refinish tech
CGLI qualified motor repair tech
Qualified automotive Glass installer
Motor Insurance Repair and Research Centre,Thatcham, Advanced Vehicle Damage Estimator.
Police qualified vehicle examiner
Police Class 1 High performance, pursuit trained Advanced driver |
Boble Samba Member
Posted: Fri Apr 23, 2010 3:55 pm Post subject: |
mpl2438 wrote: |
13.8 volts sounds good to me try with the headlights on at idle..... |
OK, good advice.
Reason I ask is that I'm in the process of identifying the reasons why my battery is dead after the car sits for a couple of days. I have measured that the stereo takes 0,5 amps, so I will fix that.
I believe 13.8 proves that it is actually charging the battery, but I have read somewhere about 14.5 Volts output from the alternator?
Just wondering what you guys read on yours. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33080 Location: Hot Arizona
Posted: Fri Apr 23, 2010 8:05 pm Post subject: |
13.8 volts while running means your charging system is working. So either bad battery or parasitic drain.
When battery is fully charged, disconnect the battery negative terminal while it sits those few days. Then install that back onto the battery, see if it starts. If not, battery issue. If it does, then parasitic drain.
If you mean 0.5 amp for the stereo "memory", that is a lot. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Boble Samba Member
Posted: Sat Apr 24, 2010 5:23 am Post subject: |
Cusser wrote: |
If you mean 0.5 amp for the stereo "memory", that is a lot. |
Yes, I believe it is a lot. I disconnected the stereo and the DAB radio antenna amplifier, and it dropped to 0.15. I guess that is OK, or should I consider 0.15 to be a drain too?
Also, I really want to be sure that the alternator is charging allright, so therefore i asked about the 13.8 volts.
[Feel free to think what you want about my basic level questions . I'm really better with metal than with electricity.] |
Paul Windisch Samba Member
Joined: September 02, 2009 Posts: 2546 Location: Clinton Township, Michigan
Posted: Tue Apr 27, 2010 5:18 am Post subject: |
In the dealer, our generally accepted limit is .040 amps, in a Cadillac, .15 amps is alot. If it doesn't kill the battery at .15, I guess I could live with it. As long as the alternator is putting out 13 volts or better, it is ok. A better way to check the alternator is with an inductive ammeter. Hook it around the large positive lead coming from the alternator, start the engine, turn on all the electrical functions in the car, (lights, stereo, etc.) and rev the engine to about 1500-2000 rpm. At this point the meter should indicate within about 10 percent of the amperage of the alternator; E.G. if it is a 50 amp alternator, it should put out 45 amps with a full electrical load. I have seen alternators put out 13-14 volts WITHOUT the proper amperage, and amperage is what actually charges the battery. _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-L3 Heads 35x32 valves 52cc chambers
-0.040" deck for about 9.1:1 Compression
-Engle W110 cam
-CB Super Stock 1.1:1 Rockers
-Stock Heat Exchangers w/ Tri-Mil Muffler
-Dual Weber IDF 40s w/ 26mm venturis
-034 SVDA Distributor
2013 Chevrolet Volt DD
2005 Pontiac Montana SV6
MAHLE Service Solutions
Applications Engineer |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1790 Location: Cleveland, Ohio
Posted: Tue Apr 27, 2010 8:04 am Post subject: |
I would find the source of the drain if it is still .15 amp, that's many times what it should be. Paul is correct with his charging voltage and parasitic draw info, the industry standard is .040a (40MA) parasitic but that is on a computerized car. VW's should have very little to zero parasitic, depending on the type of stereo and clock they have. I would consider .040a high (but acceptable) for a carburated VW. If the stereo (may have 2 power inputs) and clock are disconnected, VW's should be zero parasitic. If you still have .15A parasitic with your clock and stereo disconnected, try disconnecting your alternator and regulator, they are on the top of the hit list for parasitic drains.
Charging voltage is usually 13.5-14.5v at speed, perhaps lower at idle. Paul's amperage output test is mostly correct, but he forgot to mention applying a carbon pile load to the battery to create a demand for amperage. If amperage output is near capacity at 1500-200RPM without a load, either the battery is at a very low state of charge or bad. Sears sells a simple clamp-on DC ammeter for about $60 retail, perhaps in Norway someone sells something similar. Make sure it handles DCA as most are ACA only.
http://www.sears.com/shc/s/p_10153_12605_03482369000P?keyword=ammeter
Good Luck! _________________ '66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263 |
JasonBaker Samba Member
Joined: February 08, 2010 Posts: 1642 Location: Cleveland, TN
Posted: Tue Apr 27, 2010 11:27 am Post subject: |
Most modern cars charge @ 14.4 volts, but with very little amperage.
Your 13.8 is fine.
Pull all fuse's and put them back in 1 by 1 to find the drain. |
allsidius Samba Member
Joined: February 02, 2010 Posts: 1481 Location: Norway
Posted: Wed Apr 28, 2010 1:00 am Post subject: |
Like said earlier, a VW should have no drain when the ignition is off, with a good battery it should be able to stay for 6 months and still be able to pull the starter. The VW battery is normally 45 amp hours, that means that if you multiply the drain current by the hours standing idle, you will see if there is any juice left. For instance, it should be able to deliver 1 amp for 45 hours, or 0.1 amp for 450 hours. However, as the battery ages, the amp-hours decline, typically the car cannot stand with the parking lights on for more than 8 hours, and that is maybe 3 amps times 8 hours = 24 ah. If the battery is a few years old it may be only half the amp-hours it used to, and the capacity drops faster if the charging voltage is less. |
Boble Samba Member
Posted: Wed Apr 28, 2010 2:40 pm Post subject: |
Gentlemen, thanks a million for your comprehensive and instructive answers!
Anyone tried one of these? From what I hear, they have som difficulties reading values below 1 Ampere. |
Posted: Thu Apr 29, 2010 4:55 am Post subject: |
They aren't accurate under about 5-10 amps. Under that value, you use a digital multimeter in line. But don't use a multimeter in line with the alternator, you will damage the meter. _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-Engle W110 cam
