Stuck seat belt fix?
Robw_z
Robw_z is offline
PostPosted: Fri May 07, 2010 2:09 am    Post subject: Stuck seat belt fix? Reply with quote
I have a seat belt that will pull out about one 6 inches before catches itself, as though it "thinks" it is being stressed to the point where it needs to lock. This is one of the rare-ish rear seat 3 point shoulder belts that came on later models so finding a replacement isn't a breeze. Thanks for any advice.
-Rob
spitsnrovers
spitsnrovers is offline
PostPosted: Fri May 07, 2010 4:54 am    Post subject: Reply with quote
I don't have any of those "rare-ish" type belts, but from experience with others:
is it possible that the retractor unit has become twisted from vertical?
this would force the little weight inside to cause the ratchet to latch up.
'88 VW Westfalia
'75 Triumph Spitfire 1500
Zero419
Zero419 is offline
PostPosted: Fri May 07, 2010 5:27 am    Post subject: Reply with quote
My driver side belt only retracts with help (taking wieght off belt while it sucks in)
anybody have luck rebuilding one of these?
Is it like a pull starter with a clock spring in it?
Thanks
1987 Westy Auto Bostig 2.0 Ztec
purplepeopleeater
purplepeopleeater is offline
PostPosted: Fri May 07, 2010 5:37 am    Post subject: Reply with quote
I took one apart and oiled it up, put it back together and it worked fine...but that was on a rabbit.
j_dirge
j_dirge is offline
PostPosted: Fri May 07, 2010 7:00 am    Post subject: Re: Stuck seat belt fix? Reply with quote
-Rob
Is it mounted in the van?
If not.. place the seat belt at the exact angle it would be if bolted in the van.
These release mechanisms are extroadinarily senstive to angle.
If that does not work, take the cover off.. You will need a 3point star bit.
Sometimes the belt winds loosely and binds on the interior.
One of mine did both.. once I freed up the belt inside (too much belt was allowed to wind up inside on the spool).. I was able to retract it when the bracket was at *JUST* the right angle. Has worked OK since.. 4 months.
-89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote:
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
