Dash Removal?
griest77
griest77 is offline
PostPosted: Mon May 17, 2010 12:27 pm    Post subject: Dash Removal? Reply with quote
Do I need to remove dash to get to all the wires under the dash? I'm looking for missing/dead wires/bad connections. If I don't remove the dash is there a easy way to get to them?
jtauxe Premium Member
jtauxe is offline
PostPosted: Mon May 17, 2010 1:04 pm    Post subject: Reply with quote
You should be able to get to everything easily enough by removing the instrument panel (or at least pulling it out a bit.)
To do that:
1. disconnect battery
2. remove steering wheel
3. remove heater/fresh air control levers
4. remove four screws that hold in the instrument panel
Lots of room to work, now!
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
busman78
busman78 is offline
PostPosted: Mon May 17, 2010 1:05 pm    Post subject: Reply with quote
Pull the Instrument cluster and remove the glove box, that will give semi easy access to just about every thing. I have found if a lot of work or searching needs to be done from below/under the dash then having the steering wheel off is handy.
Oh you are a fast typer, although i leave the battery connected, makes testing easier with power.
aeromech
aeromech is offline
PostPosted: Mon May 17, 2010 1:13 pm    Post subject: Reply with quote
It seems to me that if you totally removed the whole dash it would make the job harder because a lot of the wiring connects to the dash. Follow the advice already given and you should be fine. You might also remove the radio.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
chabanais
chabanais is offline
PostPosted: Mon May 17, 2010 1:35 pm    Post subject: Reply with quote
To answer your question, there are 2 or 3 bolts on each side of the dash and then 6-8 little bolts at the base of the windshield. They are a pain to get out. The dash itself is three pieces (not counting glove box and instrument pod). While it's out you can check for rust, re-do the top of the dash (sand, primer, paint, etc...) and of course get into electricals.
Just make sure you remember how to put it back together!
"I spud therefore I yam."
ikenalleenik
ikenalleenik is offline
PostPosted: Mon May 17, 2010 2:09 pm    Post subject: Reply with quote
I redid my wiring in the dash when my front windshield was out, also removed the plate between the dash and window. Then i could see everything perfect, it made the job pretty easy.
So if you suspect rust underneath your windshield, get it out and take care of that too Very Happy Makes the other job easier :p
View user's profile Send private message Visit poster's website MSN Messenger Facebook Classifieds Feedback
Desertbusman
Desertbusman is offline
PostPosted: Mon May 17, 2010 2:13 pm    Post subject: Reply with quote
Removing the steel top of the dash makes a lot of life nice and easy. Although it takes a while to remove that top panel.
71 Superbug
71 Westy
griest77
griest77 is offline
PostPosted: Tue May 18, 2010 5:34 am    Post subject: Reply with quote
But how do I remove heater/fresh air control levers?
Jody '71
Jody '71 is offline
PostPosted: Tue May 18, 2010 5:50 am    Post subject: Reply with quote
Take the glove box out and the radio. Figure out if the colored control knobs will come off. Some years are different I seem to think. Then look at where the levers are attached inside. A good time to evaluate your fresh air/heater control cables' function and ease of moblity.
'66 Beetle
2011 Hyundai Elantra Touring
ikenalleenik
PostPosted: Tue May 18, 2010 6:13 am    Post subject: Reply with quote
In my 1972 bay you just pull them out. If you remove the top steel plate, you will see how they are attached, just pushid in a lever actually.
420GOAT
Location: Wilmington, CA on a nice quiet street but still in the 'hood
420GOAT is offline
PostPosted: Tue May 18, 2010 8:20 am    Post subject: Reply with quote
only remove the steel plate and you should have plenty of acces, the cluster will be a bitch(sorta) to wire back up if totally removed, but the glove box is easy so id do that. and the metal speaker panel....no need to remove the levers from the face.
once you realize im not impressed we will get along just fine
Lil Lulu
Lil Lulu is offline
PostPosted: Tue May 18, 2010 8:51 am    Post subject: Reply with quote
This may seem like a Gizmo Gearloose thing but I just bent the ends of the heat/fresh air levers straight and slid the cluster out.
'65 Beetle "Lil' Lulu"- Ruby Red
1600 stock from '71 bus
'72 Deluxe - Niagara Blue w/pastelwiess Camper Special 2L dual 40 Webers 002
'74 Hightop Weekender "Dixie" 1800 34 Del singles
Desertbusman
PostPosted: Tue May 18, 2010 9:06 am    Post subject: Reply with quote
Have you read your service manual? Razz
71 Superbug
71 Westy
Rjthj1
Rjthj1 is offline
PostPosted: Sat Sep 05, 2020 9:00 am    Post subject: Re: Dash Removal and re attachment? Reply with quote
Hi New to the formum and to owning a bus.
I’ve just taken the instrument panel off my T2 1977 Import so I could re attach some lights. All good.
But there were only 2 clips ( 2 missing I think)holding the panel firm once screws went back on and I can’t see how these attach? Any guidance would be appreciated
Cheers
busdaddy
busdaddy is offline
PostPosted: Sat Sep 05, 2020 9:19 am    Post subject: Re: Dash Removal and re attachment? Reply with quote
Cheers
Welcome!
Good job on finding a relevant thread to post in too! Have a look at this, it may help: https://www.thesamba.com/vw/forum/search.php?searc..._chars=200
Слава Україні!
Wildthings
Wildthings is offline
PostPosted: Sat Sep 05, 2020 8:41 pm    Post subject: Re: Dash Removal and re attachment? Reply with quote
Cheers
The clips that hold the dash cluster tend to fall off when the cluster is removed, they may just be sitting on the bottom rim of the dash or are on the floor. You should be able to find some form of replacement at you local hardware store or a decent FLAPS.
When working under the dash an old towel laid on the floor and maybe even a second towel roll up for a pillow can make life a bit better.
Rjthj1
Rjthj1 is offline
PostPosted: Sun Sep 06, 2020 7:19 am    Post subject: Re: Dash Removal? Reply with quote
Thanks the suggestions. And best way to put a clip back in... doesn’t seem to be easy or logical?
busdaddy
busdaddy is offline
PostPosted: Sun Sep 06, 2020 8:41 am    Post subject: Re: Dash Removal? Reply with quote
Get it started on the screw a few turns with the cluster in your lap, then once the cluster is in place rotate the screw so the clip is over the lip of the dash and pull out on the screw, keep pulling out as you tighten.
Слава Україні!
Rjthj1
Rjthj1 is offline
PostPosted: Mon Sep 26, 2022 1:04 pm    Post subject: Re: Dash Removal? Reply with quote
Was just trying to figure out here how to reply to a specific reply. Couldn't
So thanks!
Rjthj1
Rjthj1 is offline
PostPosted: Mon Sep 26, 2022 1:05 pm    Post subject: Re: Dash Removal? Reply with quote
So thanks!
