Metallurgist Samba Member
Posted: Sat Aug 07, 2010 1:00 pm Post subject: Question About Antenna Placement |
I have heard that antenna placement was left up to the dealship. My question is where was the typical placement and how many and what size holes were required for the OEM antenna? I have a '66 bug in getting paint and body work and I'm having a lot of the "extra" holes filled in, but would like to keep holes for the OEM antenna open. Does anyone have a picture of the antenna holes on their '66 or have any info on the holes.
Also teaser for the car
Uploaded with ImageShack.us |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Sat Aug 07, 2010 1:03 pm Post subject: |
There was no "OEM" antenna. That too was left up to the dealer. _________________ Mother Nature is a Mean Evil Bitch! |
Hammarlund Samba Member
Joined: June 15, 2009 Posts: 1539 Location: Central Texas
Posted: Sat Aug 07, 2010 1:15 pm Post subject: |
As the Doc implies, there were so many choices and varieties that it really is up to you.
One suggestion I would strongly urge on you: keep the antenna as perfectly vertical as possible! Dealers liked to mount the antennas at an angle, to make them look streamlined; but your radio will work better on both FM and distant AM stations in daytime if it is vertical. It is especially helpful for fighting ''picket fencing,'' the rapid, fluttery fading that is often encountered on FM.
(After dark, when you're listening to the truly distant stations on AM, polarization isn't as important, as the waves get scrambled when they bounce off the F-layer of the ionosphere.) _________________ Trying to diagnose electrical problems without paying attention to what the red light is telling you is like trying to play the piano without using your hands. |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Sun Aug 08, 2010 7:58 am Post subject: |
Since I'm not an audiophile, I like the look of them swept back, regardless of performance.
I got lucky with the one on my '66, it's perfect in my opinion.
PSScoots  Samba Member
Joined: January 06, 2007 Posts: 505 Location: Chattanooga TN
Posted: Sun Aug 08, 2010 2:40 pm Post subject: |
My 66 was purchased with a Bendix Sapphire III. Like earlier posts say, radio was a dealer item, so the antenna set ups show slight variation (side of car, vertical or rake, etc.)
Mine was fitted with a Ward antenna with two mounting studs. The upper one is .5" Dia and carries the coax port, the lower is .25" dia, and they are separated 1.5" OC. My dealer installed it at a 10 degree rake.
Wolfsburg West makes a repro:
I've never seen it in person, so I can't vouch for the quality.
BTW, here's an ad from Ward, complete with T.V. 50's chick advertising for TV antennas straddling a badly vibrating rocket... talk about repressed.
_________________ Rebuilt to drive not decorate. -VOLKSWAGNUT
"Service the car and it will give you good service." |
Posted: Sun Aug 08, 2010 6:20 pm Post subject: |
That's pretty much how the one on my '66 looks, 61SNRF.
By the way, the Ward flyer is not an ad per se, it is what we used to call a ''sales'' circular in the days of print media, probably intended to be distributed at electronics shows, conventions, etc., where only men would see it. Note how the copy is aimed at retailers and distributors, not consumers.
That art would have been considered way too risque for publication in mainstream magazines, newspapers, or any other place women or children might see it, as late as the early sixties.
And, it's from the fifties or very early sixties, alright: note the bikini and way the address is given. ''Cleveland 15'' is a postal zone, what big cities used before zip codes were instituted, which was around 1962-65 IIRC. _________________ Trying to diagnose electrical problems without paying attention to what the red light is telling you is like trying to play the piano without using your hands. |
61SNRF Samba Member
Posted: Sun Aug 08, 2010 9:44 pm Post subject: |
Yeah, those ads must've ran in men's magazines of the times. Argosy, Popular Mechcanics and such. Pretty racy for antenna's!
I can add some perspective in that being an import auto tech since '74, I know what it's like in a dealership when a car get's sold. "The customers waiting and the car's gottta go!" Whichever mechanic that car got dispatched to had his own set of rules and was an individual. The dealership in general might have had no thought of where it was placed. I don't recall ever seeing any litrature or guidelines for mounting myself. It also comes down to local parts availability and subcontractors. I know of early '67 Beetles with a factory hole in the left A-pillar blanked off and the 1/4 panel drilled for a bolt on Ward type antenna, surely for availability issues.
What the heck, it has one speaker to the left of the driver. I think the scratchy sound of AM is part of the charm of an old car!  |
Posted: Mon Aug 09, 2010 6:56 am Post subject: |
In the early days of FM radio, stations were limited to the same power output as AM stations, fifty thousand watts (50 kW) if they were lucky, often much less.
Because of the line-of-sight nature of propagation at FM frequencies, this meant that FM signals did not travel as far as AM signals, which followed the curvature of the earth in daytime, and bounced off the ionosphere at night.
In addition, the FCC felt that FM was suitable only for large urban markets, not small towns and rural areas, due to its limited coverage. So they were reluctant to grant construction permits for much of the country.
As a result, we used to listen to FM some when driving around town, but on longer trips we HAD to put the radio on AM between big cities.
Then, about 1975 IIRC, the FCC allowed FM stations much greater power and antenna height; and greatly increased the number of licenses, allowing FM stations to be built in bedroom cities between towns. These two things combined to allow FM signals to travel much further, and it became common to listen to FM radio on longer trips.
But when your '66 model was new, FM was still useless outside of large urban areas, and there weren't nearly as urbanized areas in America as there are today. This is a big part of why Bendix sold so few AM/FM Sapphires in the old days. _________________ Trying to diagnose electrical problems without paying attention to what the red light is telling you is like trying to play the piano without using your hands. |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7801 Location: Big Wonderful WYO 82401
Posted: Mon Aug 09, 2010 9:19 am Post subject: |
RareAir wrote: |
Antennae on my '66 is the same spot as 61snrf has his. But the dealer mounted mine near vertical
No his is actually a little lower  |
hitest Samba Member
Joined: September 30, 2008 Posts: 10326 Location: Prime Meridian, ID
Posted: Mon Aug 09, 2010 9:58 am Post subject: |
The closer to the beltline- the more the antenna will lean inward- so the '66 hardtop above is likely the better position. Consider the head-on view of the antenna's straightness before drilling/filling.
Straight was the right way 50 years ago- but you can pull in any of today's FM stations with nothing more than a metal screw in the antenna port- no need to give your car the shaft (ask any fiberglass boat owner). _________________
EverettB wrote: |
FU#5 |
DIERNOSAJ Samba Member
Joined: February 09, 2010 Posts: 134 Location: Illinois
Posted: Mon Aug 09, 2010 10:51 am Post subject: |
Heres mine on my '63 for another reference. I need a longer antena cable though. It won't even reach the cd player in the glove box.
Posted: Mon Aug 09, 2010 11:22 am Post subject: |
Quote: |
but you can pull in any of today's FM stations with nothing more than a metal screw in the antenna port... |
It's only funny because it's true.
But it's only true if one lives in an urban area. Here in cotton/corn/cattle country, we still need good antennas to help fight multipath, especially if tropo is active, even though I can actually see the towers of the stations I am trying to receive, thirty miles away across the prarie!
But admittedly, few people live in as isolated an area as I do. That's why it's isolated... _________________ Trying to diagnose electrical problems without paying attention to what the red light is telling you is like trying to play the piano without using your hands. |
VWOVAL55 Samba Member
Posted: Sat Aug 09, 2025 8:02 pm Post subject: Re: Question About Antenna Placement |
Hi there all,
Looking at purchasing a 1962 beetle, low miles 46K.
Question: I haven't seen a radio antenna mounted on the fender, always on the body.
Hesitant on the purchase, please help.
Thank you,
Rick |
panicman Samba Member
Joined: December 18, 2011 Posts: 2657 Location: Canby, OR
Posted: Sun Aug 10, 2025 11:42 am Post subject: Re: Question About Antenna Placement |
You're looking at a 1962 beetle, and its antenna is mounted to the fender.
Do you have a picture? What do you need "help" with? |
Posted: Sun Aug 10, 2025 12:08 pm Post subject: Re: Question About Antenna Placement |
I've never seen anything like this, wondering if anyone else has. See pic.
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 492 Location: Eastern north carolina
Posted: Sun Aug 10, 2025 2:54 pm Post subject: Re: Question About Antenna Placement |
Well that looks like a nice bug. I can tell you that in 57 years of being around these cars I have never seen an antenna mounted there. It would not be too difficult to put one in a more " proper " location. |
far rider  Samba Member
Joined: August 30, 2005 Posts: 974 Location: Rutland, VT
Posted: Sun Aug 10, 2025 3:56 pm Post subject: Re: Question About Antenna Placement |
Here’s my 61. Decided to leave it in original location. Dual mount like Rare air but opposite side and considerably closer mounts.
_________________ 67 zenith blue sunroof
Contentment; when what you have is what you want. |
Posted: Sun Aug 10, 2025 5:21 pm Post subject: Re: Question About Antenna Placement |
That is pretty hilarious. I wouldn't put an antenna there.
It does look like a pretty nice bug. I don't know if that a deal breaker for you. You could pull the fender, weld the hole, and try to blend in matched paint. |
