Doghouse Tin
BIG-O
BIG-O is offline
PostPosted: Fri Sep 17, 2010 8:00 am    Post subject: Doghouse Tin Reply with quote
I'm installing the doghouse tin (2 piece), all is going well but I noticed that my fuel filter is sitting right where the hot air exit is. Would this be a problem?
Would the disconected heater box touching the filter be a problem?
19super73
Hardcore Stock Nazi
19super73 is offline
PostPosted: Fri Sep 17, 2010 8:04 am    Post subject: Reply with quote
Move your filter to underneath your gas tank or where the hard line exits by the left rear wheel.
1970 Campmobile [url=https://www.vw-mplate.com/mplate-47260.png]Click to view image[/URL]
1970 Fastback 1600 TL
1971 Doka [url=https://www.vw-mplate.com/mplate-14845.png]Click to view image[/URL]
1973 Super Beetle
1973 Westfalia [url=https://www.vw-mplate.com/mplate-31892.png]Click to view image[/URL]
1974 412 Variant
1975 La Grande Bug
1984 Vanagon
BIG-O
BIG-O is offline
PostPosted: Fri Sep 17, 2010 8:13 am    Post subject: Reply with quote
By move it i would need a new hose?
I didnt want to put it too close to the cv joints, so thats why i put close to firewall tin.
I guess i could buy a pipe to cover where it is now.
kburg12
kburg12 is offline
PostPosted: Fri Sep 17, 2010 8:50 am    Post subject: Reply with quote
You do not want the filter in the engine compartment at all! That is how most of the engine fires happen in a VW. Put it on the other side of the firewall where the metal line comes through, and yes you will have to buy another piece of $3 hose and a couple of clamps to do that.
A terrible mind is a beautiful thing to waste!!!
68 Convertible Beetle
09 Tiguan
09 Beetle
BIG-O
BIG-O is offline
PostPosted: Fri Sep 17, 2010 8:52 am    Post subject: Reply with quote
I also had a hard time slipping the filter in the hose.....Is there a secret? i almost broke the plastic filter.
69 Jim
69 Jim is offline
PostPosted: Fri Sep 17, 2010 8:57 am    Post subject: Reply with quote
What filter into what type of hose?
BIG-O
BIG-O is offline
PostPosted: Fri Sep 17, 2010 9:06 am    Post subject: Reply with quote
the plastic filter everyone buys for bugs....into factory hose.
VeedubPastor
VeedubPastor is offline
PostPosted: Fri Sep 17, 2010 9:07 am    Post subject: Re: Doghouse Tin Reply with quote
Strange. The fuel line should be well above the oil cooler hot air exit chute. Maybe the hard line that exits the front tin is not bent at the correct angle? Pics might help. Even if you change the fuel filter location, the line itself shouldn't be running below the hot air exit; that's asking for trouble.
1971 Super Beetle - Daily Driver
Solex H30/31 & 034 distributor (yeah, I know)
Stock thermostat & flaps
Stock air cleaner and emissions equipment
VeedubPastor
PostPosted: Fri Sep 17, 2010 9:09 am    Post subject: Reply with quote
Put a little grease on the hose and the filter before you shove it in.
69 Jim
69 Jim is offline
PostPosted: Fri Sep 17, 2010 9:11 am    Post subject: Reply with quote
A squirt of WD-40 will work.
