Can a diesel fuel filter be used with gasoline?
TC/TeamEvil
TC/TeamEvil is offline
PostPosted: Sat Mar 05, 2011 10:16 am    Post subject: Can a diesel fuel filter be used with gasoline? Reply with quote
Just wondering if I could use a remote mount diesel fuel filter set-up, like this one:
http://www.thesamba.com/vw/classifieds/detail.php?id=1052181
but run gasoline through it?
It would seem like a neat solution. Larger, easily changeable, no clamps to undo. wear out, leak fuel when changing the filter, and the assembly could be remote mounted to get it farther away from the engine, reduce potential fire and fumes.
Think that it might work? Is a diesel filter element so very different from one used for gasoline?
I don't know, but sure wondering.
Thanks !
TC
Wetstuff
Wetstuff is offline
PostPosted: Sat Mar 05, 2011 11:21 am    Post subject: Reply with quote
I'm not really an engine guy ..but I've been around a number of diesels. Dirt is an issue, but water separation seems to be a major component of most 'diesel' fuel filters I have seen (and currently have on a J-D tractor) .. the one pictured does not seem to have that feature. (not obvious to me anyway...)
I'd also think F.I. needs a better filter than these crude little carbs we tend to have.. Why not add it tho'?! .. looks interesting.
Jim
TC/TeamEvil
PostPosted: Sat Mar 05, 2011 12:48 pm    Post subject: Reply with quote
That's kind of what I was thinking. Since the screw-on filter element would either have a water drain built in (cool if I got bad gas) or not (no biggie since most gas filters don't have a water separator anyway) I'd be ahead of things.
Plus, as you say, fuel injection (as in a diesel) requires a finer filter than the usual paper one in those clear plastic in-line filters that most VW guys use, so the diesel filter ought to work better.
I guess that I was most concerned with fuel pressure. Would the 3 PSI VW pump push the gas through the finer diesel filter?
bdkw1
bdkw1 is offline
PostPosted: Sat Mar 05, 2011 12:50 pm    Post subject: Reply with quote
I have been using these for years with really good results. Replacment filters available at just about any autoparts store.
http://www.summitracing.com/parts/FRM-HPG1/
HeidelbergJohn4.0
HeidelbergJohn4.0 is offline
PostPosted: Sat Mar 05, 2011 9:02 pm    Post subject: Reply with quote
that's what we use on boats where it's a big problem and even bigger problem to be stranded by crud in your fuel.
http://www.jamestowndistributors.com/userportal/se..._separator
71 LWB Manx style dunebuggy
71 Beetle
71 Volksrod
Machette Speedster
2012 Passat TDI SE (sadly sitting in a buyback parking lot somewhere waiting for it's heart to be ripped out.)
manxdavid
Location: David Jones, Anglesey, North Wales, UK. Manxclub #678.
manxdavid is offline
PostPosted: Sun Mar 06, 2011 12:56 am    Post subject: Reply with quote
The filter head that you picture, together with a spin-on diesel filter will work fine for gasoline. If you choose a filter with a water drain all the better but water ingress isn't really an issue using pump gas, not like it is for marine and for other users.
