buggin65 Samba Member
Joined: April 14, 2011 Posts: 70 Location: Conejo Valley
Posted: Sun Apr 17, 2011 6:17 pm Post subject: engine rebuilding theory - connecting rods |
do the bushings on the small end of the connecting rods need to be just reamed or reamed and honed. I reamed them to a great fit with the wrist pin but there are slight "ridges" on the inside of the bushing from the reaming. I could hone them perfectly round but i heard doing that leaves microscopic grit embeded in the bushings that would cause premature wear. What do you guys think? I would have to start all over because if i hone now, the wrist pin fit would be too sloppy. |
Eric Outland Samba Member
Posted: Sun Apr 17, 2011 9:37 pm Post subject: Eric (VMR) |
Play it safe have them Pressed out and replaced with either aftermarket or Nos. Sure you can do as you had mentioned, but to have several thousandths of differance can give you un- even where spots in the bushing and lubrication is comprimised if this happens and a host of unwanted outcomes may result. Again In my opinion PLay it safe and Replace them out right.  |
Posted: Sun Apr 17, 2011 10:20 pm Post subject: |
They are bran new bushings. i can press them in and out, but they have to be reamed and or honed to fit the wrist pin perfectly, but which one? Both? I know the big end of the connecting rod is resized by honing only for concentricity by a sunnen honing machine, mine are in good enough condition to not need that but how is the small end done? see question above. |
Posted: Sun Apr 17, 2011 10:36 pm Post subject: Eric (VMR) |
In my 30 + years of rebuilding/Restoration=I have only Lightly emery clothed the inside of a Rod bushing (If at all) to aid in a smother fit. I have read your post. Something is Truly wrong on your bushing deminsions. If you have to force a piston Pin thru your rod, or hammer it thru???? Good Luck! |
olspeed Samba Member
Joined: May 01, 2008 Posts: 489 Location: In the shadow of Denali, I still don't give a damn how they do it outside
Posted: Sun Apr 17, 2011 11:58 pm Post subject: |
Did you measure end to end length after replacing the bushings? this is normally set when the bushing is cut to size and is done on a special fixture or in a milling machine that is set to bore it to the correct measurement. If you just pressed them in and reamed then out without a fixture to hold your end to end size true then you will have problems. _________________ 66- Ghia
76-Beetle |
Posted: Mon Apr 18, 2011 8:17 pm Post subject: |
OK, sound advice from you all. I already got new bushings ready to be re pressed in (i can do it with a c-clamp and sockets). Your right about the center to center. How close does it have to be? I got it with in .005" ctc. It doesn't say in the mechanics handbook for VW it just says weighing within 5 grams (that's alot) and concentric within .001" which it is. How much woulf it cost for a mcahine shop to do this? |
OLD VW NUT Samba Member
Joined: February 23, 2011 Posts: 2776 Location: High Desert of Washington 98823
Posted: Mon Apr 18, 2011 8:57 pm Post subject: |
Clearance between the wrist pin and connecting rod (bushing) is .0004-.001". Allowable wear is .002". _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI |
Posted: Mon Apr 18, 2011 9:25 pm Post subject: |
Thanks. I got that close but it was only reamed, i have to start over and hone too because reaming is not a perfect circle on the inside there are highs and lows but luckily bushings are cheap, i will look for a pro. |
