Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1760 Location: Niagara Region, CANADA
Posted: Wed May 25, 2011 6:36 am Post subject: Are Bosch W8AC Plugs Extinct? |
Local supply here in Canada seems to be drying up with the WR8AC being substituted. I'm not a fan of 'R' or resistor plugs as I've chased problems with them in the past. The NGK cross keeps coming back as a 'R' plug too.
Are we going to have to change over to higher output ignitions to run these or have I just had a bunch of Bad plugs?
Is the resistor there just to suppress ignition noise so your stereo is cleaner or is there some other function? |
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Wed May 25, 2011 6:56 am Post subject: |
i think they have discontinued the bosch plugs for our cars. i just cleaned, checked the gap, and threw mine back in.
don't know what a good replacement plug would be, im interested also. _________________ foam cowboy hats aren't good helmets. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79572 Location: Sneaking up behind you
Posted: Wed May 25, 2011 7:04 am Post subject: |
Just get NGK B5HS, they will work just fine. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
JSMskater Samba Grease Gorilla
Joined: February 01, 2006 Posts: 5362 Location: Murrieta California
Posted: Wed May 25, 2011 9:44 am Post subject: |
Glenn wrote: |
Just get NGK B5HS, they will work just fine. |
the ones I get are B6HS. i think they're a slightly hotter plug. _________________ 71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors |
Posted: Wed May 25, 2011 9:49 am Post subject: |
I've managed to locate some of the Bosch plugs thru an industry contact.
I'll be trying some of the NGK's when this source dries up.
I was wondering if Bosch W8AC availability is a local issue or a global thing??? |
Glenn  Mr. 010
Posted: Wed May 25, 2011 9:59 am Post subject: |
JSMskater wrote: |
Glenn wrote: |
the ones I get are B6HS. i think they're a slightly hotter plug. |
They're colder.
Member #1009
#BlueSquare
pupjoint Samba Member
Posted: Wed May 25, 2011 10:05 am Post subject: |
i wont even bother with bosch plugs, just get NGKs |
jbbugs Samba Member
Joined: September 16, 2002 Posts: 2180 Location: Behind the wheel
Posted: Wed May 25, 2011 3:39 pm Post subject: |
NGK BP6HS has worked well for me for the last 29 years. _________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket! |
Joined: May 17, 2003 Posts: 4876 Location: Harmony, PA
Posted: Wed May 25, 2011 8:06 pm Post subject: |
Not sure about the W8AC plugs, but the WR8AC plugs should still be readily available. Bosch has introduced this new metal into the mix called Yttrium (whatever the hell that is), and now labeled the plugs "Super Plus". They also have some new BS numbering system. A WR8AC is now crossed over as a #7902. The shop I work at uses the counterpart to the WR8BC, which is a #7903. The #7903 has a protruded electrode that the shop owner feels burns better. I think the resistor plugs have replaced the non-resistor ones. If you need/want the non-resistor ones go with the NGK B5HS (new #4210) Glenn mentioned, or a BP5HS (#4111) for the protruded electrode. |
Nirvana92 Samba Member
Joined: November 02, 2008 Posts: 295 Location: Waxhaw , North Carolina
Posted: Wed May 25, 2011 8:09 pm Post subject: |
where can i get the ngk B5HS plugs at?? all i can find at advance auto or autozone is BP6HS _________________ 1970 beetle 1600 SP with 019 distributor |
Bigmeat Samba Member
Posted: Wed May 25, 2011 8:11 pm Post subject: |
I by mine at napa. |
Posted: Wed May 25, 2011 8:14 pm Post subject: |
i always forget about that place  _________________ 1970 beetle 1600 SP with 019 distributor |
Posted: Wed May 25, 2011 8:19 pm Post subject: |
Nirvana92 wrote: |
where can i get the ngk B5HS plugs at?? all i can find at advance auto or autozone is BP6HS |
Autozone has them listed on their web site, but they're special order. You should be able to get them within a day, or two. Advance doesn't have a listing on their site, but I would imagine they could get them within a couple of days also. Look for them using NGK's new numbering system as #4210 |
leaker Samba Member
Joined: May 18, 2009 Posts: 348 Location: richmond,va
Posted: Thu May 26, 2011 1:59 pm Post subject: |
Sparkplugs.com shows the w8ac as being obsolete too,and I agree NGKs from Napa,they stock all the weird shit. |
The_Codeman Samba Member
Joined: April 05, 2007 Posts: 176 Location: Huntington Beach CA
Posted: Thu May 26, 2011 3:16 pm Post subject: |
Also check motorcycle shops they sell them also thats where i get mine
i use the BP5HS work great _________________ www.codemans-bug.com
www.808vwclub.net |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4941 Location: Raleigh, North Carolina
Posted: Sat May 28, 2011 8:56 pm Post subject: |
Nirvana92 wrote: |
Try Carquest; they bought WorldPac some years ago & usually have decent foreign car parts...
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Howard 111 Samba Member
Vw1600dellortoGR Samba Member
Posted: Fri Jun 07, 2013 6:50 am Post subject: |
Will w3ac spark plugs do the job? German bosch are hard to come by |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5669 Location: On an island in VA
Posted: Fri Jun 07, 2013 7:54 am Post subject: |
Are these the 14 or 12mm plugs? I need to get some 12mm for my new heads. |
Posted: Sat Aug 03, 2013 6:18 am Post subject: |
Bashr52 wrote: |
http://www.ngksparkplugs.com/docs/tech/design_symbols_plugs.pdf
First digit indicates thread size.
ie: 14mm is B.
12mm could be D, DC or J.
Length is the 'E' or 'H' digit which indicates "3/4" or "1/2". |
