smokeykombi Samba Member
Joined: October 02, 2006 Posts: 44 Location: Carson City Nevada
Posted: Fri Nov 04, 2011 2:36 pm Post subject: strange new shifting problem |
I have a 58 kombi and have always had problems from really messed up fron shift rod to wrong hanger bracket with late style bushing. Now all replaced with ww early front shift rod and correct hanger with m spring.
Problem no is the ball of the shifter pops out of cup on front ww shift rod when trying to put it in 4th or 3rd.. any idea what it could be...thanks |
Barracudabrendon Samba Member
Joined: October 26, 2008 Posts: 299 Location: Kahuna Metal Works SoCal
Posted: Fri Nov 04, 2011 3:10 pm Post subject: |
Do you have the correct shifter, 58 is longer then say a 60-65 shifter?? _________________ Building quality HWE style racks for your Type 2 Kahuna Metal Works.
1957 Bus
Turbo Mini Single Cab
1964 N Model Squareback
Ruthless Fastback Drag car |
Posted: Fri Nov 04, 2011 3:13 pm Post subject: |
should be the right shifter (straight shaft) Right? Another really weird thing is it only seems to do it when i push the clutch in. Without clutch pushed in everything seems ok  |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Fri Nov 04, 2011 3:14 pm Post subject: |
The 1963 camper that I had bought started having problems when shifting. He had put an aftermarket front shifting shaft in it so I removed it and laid it upright on the garage floor next to a stock one I got at an autowrecker: the cup on the aftermarket one was about one-fourth of an inch lower than the cup on the stock one. I installed the stock shifting shaft and the sucker shifted fine. Get a stock shifting shaft and compare the two shafts. _________________ Don't worry; be happy. (Baba) |
Posted: Fri Nov 04, 2011 3:15 pm Post subject: |
| all gears seem to go from nice and smooth to really stiff when clutch is engaged |
Posted: Fri Nov 04, 2011 3:17 pm Post subject: |
it is a stock shifter and correct year...that is for sure  |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15461 Location: Casa de Oro, California
Posted: Fri Nov 04, 2011 3:58 pm Post subject: |
| Front mount busted? Your talking when the engine is off right? |
Posted: Fri Nov 04, 2011 4:01 pm Post subject: |
| yep ...you talkin front trans mount...cant check right now have no help to work clutch peddle to see what is going on under bus |
vwserphguy Samba Member
Joined: April 30, 2009 Posts: 176 Location: Vail Valley
Posted: Fri Nov 04, 2011 4:20 pm Post subject: |
I just got through working out my early 58 bus shifter issues. It had been sitting for 20+ years and everything was a basket case to say the least. After I put the rebuilt engine in, I went to hook up the shift rod/shifter/new rear coupler etc... and I found all 4 gears no problem, but NO Reverse.
Anyway... first thing to check is to make sure you put the new WW shift rod back in the correct scrub screw set on the rear shift rod (that goes from the middle of bus to rear coupler). I learned that there are two sets of scrub screw holes on the rear shift rod on both ends. I didn't have mine in the correct scrub screw hole set and I could never find Reverse. Once I tried the other set, I knew looking up from under the bus, everything lined up better. So make sure you put it back in correct.
Next, you need to play with getting the floor lock out plate lined up and that maybe your only problem (move it either side to side or front to back slightly). Since I could never find Reverse, I manually put it in reverse, started up the bus and made sure it was in reverse. Then played around with lining up the lock out plate/shifter and screwed the shifter back down. You will have to mess with it a bunch which can be frustrating so be patient. I found it trial and error at this point. I did mine here and there over a 10 day period! Hope it doesn't take you that long. Good luck... and also make sure everything is lubed very well. |
Posted: Fri Nov 04, 2011 9:40 pm Post subject: |
| Well after a very long day in the garage trying to pin point the problem...THE SHIFTER would move slightly when i pushed the the clutch in..finally realized that the two nose cone bolts two the tranny mount where a little loses.. Tighten up and all seems good. Could not see it moving but made a world of difference |
Posted: Fri Nov 04, 2011 9:41 pm Post subject: |
my bad.....goodandthight  |
