AlteWagen Troll
Posted: Tue Nov 15, 2011 3:53 pm Post subject: Source for 10mm x 1.50 ID 12mm x 1.50 OD Case savers? |
Working on a customers engine and found a missing case saver. Case is bored for 94s already so the common 14mmx2.0 OD wont work.
I thought the original 10mm case savers were 10 id x 12 od from the factory but one local shop never heard of them while the other said they havent been made in oveer 10 years.
Other than pulling all the savers to install the common 8mm id x 12mm od and buying 8mm studs is there any other solution? Im sure the customer would prefer the $2 solution over the $100 one. |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23950 Location: SHALIMAR ,FLORIDA
Posted: Tue Nov 15, 2011 4:01 pm Post subject: |
not sure there is a $2 solition, but yes there are still some floating around,check with mofoco,larrys offroad,ebay,cb.etc. thanks for letting us know there like hens teeth, Ill be sure to keep track on mine.oops for got check on the samba I hear there is a lot of stuff in the classifides. |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Tue Nov 15, 2011 4:04 pm Post subject: |
Send me an e-mail to [email protected] so I remember and I will look in the morning. I'm 99% sure I have what you need. |
jsturtlebuggy Samba Member
Joined: August 24, 2005 Posts: 4607 Location: Fair Oaks/Orangevale, CA
Posted: Tue Nov 15, 2011 4:35 pm Post subject: |
BugPack sells 1/2in-20 OD, 10x1.5mm ID ones. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
AlteWagen Troll
Posted: Tue Nov 15, 2011 4:47 pm Post subject: |
mark tucker wrote: |
I didnt think it would be such a big deal either and the local shops didnt even want to help. I try to keep the locals open by stopping there first but them not even wanting to get one from a junk case (and they have stacks of them) shows why they will be out of business soon. When I was working at the shop I would go out of my way for the small stuff a customer needed, they would remember that and come back for the expensive stuff instead of going on line, seems like the writing is on the wall...
jsturtlebuggy wrote: |
BugPack sells 1/2in-20 OD, 10x1.5mm ID ones. |
Not much room to retap the case and use these.
THANKS!!
email sent |
modok Samba Member
Joined: October 30, 2009 Posts: 27687 Location: Colorado Springs
Posted: Tue Nov 15, 2011 6:40 pm Post subject: |
Time-sert |
Posted: Tue Nov 15, 2011 7:16 pm Post subject: |
no it,s a 10x14 mm insert, not 10x12, there isant enough material for what you want.the 12mm thread depth would exceed toe 10 mm dia. so you just need a reg ole 10x14.easy.but if you mesure the hole you will find it is about 12 mm but you are not messuring the od of the threads but the small dia.so it may be a $2.00 fix. I got to thenken (smoke signals)and went and checked my kit. then the light went off, or rather on. |
modok Samba Member
Posted: Tue Nov 15, 2011 7:17 pm Post subject: |
I think maybe Mark has never seen a time-sert  |
Posted: Tue Nov 15, 2011 7:25 pm Post subject: |
modok wrote: |
yup I seen them and used them,but I dont think vw did. we even have time sert condos hear!!! |
I forgot about the TimeSerts until I was looking at an 043 cylinder head today with them in it for the rocker studs. 12x 1.5 OD, 10x1.5 ID
Yes the TimeSerts work excellent. _________________ Joseph
Elrod Motorsports
AlteWagen Troll
Posted: Mon Dec 05, 2011 2:48 pm Post subject: |
Yes the TimeSerts work excellent. |
Roy didnt have any so wondering if anyone has the part number for the Time sert mentioned above. Ive searched but could not find the 12mm OD x 10mm ID needed.
Thanks |
Bill271 Samba Member
Posted: Mon Dec 05, 2011 6:00 pm Post subject: |
Try century dist in Visalia |
modok Samba Member
Posted: Mon Dec 05, 2011 6:35 pm Post subject: |
ask Rimco
Timesert does not tell you the OD, (secret )
But the regular 10 x1.5 inserts has the same OD as 12mm, and you know it has the same thread pitch by definition..... 99% sure there is no mystery, it is 12x1.5, that is the good news
Bad news: you have to buy the kit anyway to get the installer/expander tool, unless a local shop has a kit you can use.
http://www.amazon.com/Time-Sert-M10x1-5-24-5mm-Length-Metric/dp/B001JK5YPQ |
AlteWagen Troll
Posted: Tue Dec 06, 2011 4:01 pm Post subject: |
Bill271 wrote: |
When I moved from CA I closed my resale permit so cant buy from them anymore as they are wholesale distributor only
modok wrote: |
ask Rimco
Thanks thats just what I needed to know.
T |
Posted: Tue Dec 06, 2011 7:07 pm Post subject: |
Call Time Fastener Company Inc., They make Time-Serts.
They are in Reno, NV
5301-G Longley Lane
Reno, Nevada, 89511
(775) 829-1026
(800) 423-4070
I did when I needed some inserts, and since there is not someone who sells them close to me. I was able to buy directly from them.
As for setting them to keep them from unscrewing, I just use a bolt, screw in until I felt it reach the area that locks and it worked.
Also they come in different lengths.
10x1.50mm are .370, .433, .550, .669, .800, .866, and .960in in lengths.
Get a catalog from them, they have all kinds of kits for repairing threads. _________________ Joseph
Elrod Motorsports
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2373 Location: Mount Airy, Maryland
Posted: Wed Dec 07, 2011 11:50 am Post subject: |
Are you sure they are 12mm OD? 12mm OD is for the 8mm studs.
The current standard for 10mm studs is a 14mm OD but the smaller harder to find ones used for 94's are the Scat 1/2" ~13MM others make them as well.
I just bought a set in the classified from the early 80's.You could also offset drill the hole in a pinch. _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
AlteWagen Troll
Posted: Wed Dec 07, 2011 2:02 pm Post subject: |
yamaducci wrote: |
I just bought a set in the classified from the early 80's.You could also offset drill the hole in a pinch. |
Yes 12mm OD. They are stock 71-72 10mm stud case savers. If I could just find a junk case I would just pull the one I need out but no luck locally. The 14mm savers are the oversize to repair a pulled 12mm saver. There is not enough meat in the case to offset either. I saw the set in the classifieds and emailed the seller but they are repair savers also and he said the OD was a standard measurement so no use to me.
The customer is in no hurry and has more time than money so I will just wait to get the time sert and install.
turtlebuggy, thanks for the info |
RockCrusher Samba Member
Joined: August 03, 2010 Posts: 4596 Location: Parkesburg, PA
Posted: Wed Dec 07, 2011 6:43 pm Post subject: |
Do you REALLY need one? I have a set but have to search for them. If you email me at [email protected] I can print out the request or I'll never remember to look for them.
RC _________________ [email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly. |
AlteWagen Troll
Posted: Sat Dec 10, 2011 1:44 pm Post subject: |
As usual didnt get the notify of response,
RC thanks for the offer! email sent. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20826 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Dec 10, 2011 2:01 pm Post subject: |
Ahem...
http://www.timesert.com/html/engineeringdataM.html
Dale _________________ “Fear The Government That Wants To Take Your Guns"
