rail weight
MarkZee
MarkZee is offline
PostPosted: Thu Dec 08, 2011 9:26 pm    Post subject: rail weight Reply with quote
about what will the average 4 seat sand rail weigh. how much on front and how much weight in rear - with vw suspension and trans and engine.
The Phil
The Phil is offline
PostPosted: Fri Dec 09, 2011 3:28 am    Post subject: Reply with quote
It depends. Width, length. Ball joint, link pin. size of wheels, size of tires. size of gas tank. weight of seats. Also, a dune car, or a desert car. If the rear end is stock irs, swing, or if it has extended arms.
This rail weighs in at about 2500 lbs. It has a twin turbo northstar engine, full suspension fox king shocks, 5x5 rear end, huge a arm front end. this one is a desert car.
"In case I don't see you, good afternoon , good evening, and goodnight."
My '66 Baja Build Page http://www.thesamba.com/vw/forum/viewtopic.php?t=456365
Free from the evils of facebook Dec 2012. No other Social Media.
SamT
SamT is offline
PostPosted: Fri Dec 09, 2011 8:01 am    Post subject: Reply with quote
VW style, stock suspension will be in tHe 1200-1600 range.
Mal evolent
Mal evolent is offline
PostPosted: Fri Dec 09, 2011 8:33 am    Post subject: Reply with quote
my 2 seat rail, 1200 CC, split case trans with RGBs and 35" rear tires, weighed 1300 with me in it. lady at the truck stop laughed herself silly while weighing it. I could pick the front end up by myself, two people could hold it up.
73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index
MarkZee
MarkZee is offline
PostPosted: Fri Dec 09, 2011 12:58 pm    Post subject: rail weight Reply with quote
To be more precise: I was thinking / asking about the basic older type rail with longer arms to give about 10 inch travel. 235-15 tires. A mild mannered machine for a family expedition car. From the replies, it sounds like I coud expect a weight of around 1500.
SamT
SamT is offline
PostPosted: Fri Dec 09, 2011 1:32 pm    Post subject: Reply with quote
if it is 1500, front will be 500- rear will be 1000+ Depending on rear trailing arms.
Mr. Unpopular
Mr. Unpopular is offline
PostPosted: Fri Dec 09, 2011 2:16 pm    Post subject: Reply with quote
A friend of mine has a Hi-Jumper frame stretched to 120" wb and widened 7" (room for 4 suspension seats). He runs coilovers all around, bus trans, Honda V6, fiberglass hood and sides, aluminum roof, no spare. He said his weighs 1900 lbs drivable.
"In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
-Keith Duckworth, creator of the Ford/Cosworth DFV
manther
manther is offline
PostPosted: Fri Dec 09, 2011 3:28 pm    Post subject: Reply with quote
My 2 seater ball join bug trans stock arms weighed 1200#
yfz450
yfz450 is offline
PostPosted: Fri Dec 09, 2011 3:46 pm    Post subject: Reply with quote
sounds nice
Mr. Unpopular
PostPosted: Fri Dec 09, 2011 3:48 pm    Post subject: Reply with quote
sounds nice
Yeah, it works very well where we ride. I'm building a pretty similar buggy but with a 4 cylinder GM ecotec which I want to turbocharge later on.
77charger
77charger is offline
PostPosted: Fri Dec 09, 2011 10:36 pm    Post subject: Reply with quote
1350 as it sits fueled up and with the paddles .Vw powered alm case.
Click to view image
Bugpack 4 seater rail
2275 built by me
Auto linea alm case,82 dpr crank wedgemated by DK machine
cb 5.4 h beams,12 pound DPR f/w,Slr xv294cam,cb straight cuts,hpmx 44s,40x35 heads ported by brothers machine
Mr. Unpopular
PostPosted: Sat Dec 10, 2011 6:46 am    Post subject: Reply with quote
That's a sweet looking buggy!
lostinbaja
lostinbaja is offline
PostPosted: Sat Dec 10, 2011 9:02 am    Post subject: Reply with quote
It doesn't have VW suspension but weighs in at 790lbs. ready to go.
Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92
mondodestructo
mondodestructo is offline
PostPosted: Sat Dec 10, 2011 11:02 pm    Post subject: Wow Reply with quote
That's a great looking buggy! What kind of frame is that?
Building my first rail. Good times.
http://www.thesamba.com/vw/forum/viewtopic.php?p=5464220#5464220
joescoolcustoms
joescoolcustoms is offline
PostPosted: Sat Dec 10, 2011 11:44 pm    Post subject: Reply with quote
Wow lostinbaja! I thought my 2 seater was light at 804 pounds. 790 is really light for a 4 seater.
Bad News Racing 2018 NORRA 1000 3rd in Class
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
lostinbaja
PostPosted: Sun Dec 11, 2011 6:30 am    Post subject: Re: Wow Reply with quote
It's a short cage Appletree frame built from .055 chromoly. I put the bare minimum on the buggy. It does have coil over rear suspension as well.
Jerry...
RIP Morgan
My photos
