1996 Golf GL Engine tapping at 2000rpm
Forum Index -> Water-cooled VW Share: Facebook Twitter
nurotek
nurotek is offline
PostPosted: Sun Dec 18, 2011 11:46 pm    Post subject: 1996 Golf GL Engine tapping at 2000rpm Reply with quote
so whats happening is when i rev the engine at around 1900-2100 rpms i get this tapping sound. i just noticed it so i havent actually gone down to see if there is something loose on the engine.
1996 vw golf
-eat moose , 10000 wolves cant be wrong-
86vwgti8v
86vwgti8v is offline
PostPosted: Mon Dec 19, 2011 9:32 am    Post subject: Reply with quote
Prob your lifters. Usually they tick at start ups and idle though. Make sure you have oil and oil pressure.
nurotek
nurotek is offline
PostPosted: Mon Dec 19, 2011 10:20 am    Post subject: Reply with quote
im waiting for my haynes to come in. but how would you sudjest troubleshooting this problem? and how much of a problem is it?
i read the thread:
"t's possible to have a bad cam follower('lifter'), but rare; after a dozen years in the VW parts business, I'd lay odds it's the classic wrong oil and filter syndrome that's causing the noise. I'll hazard a guess that the filter is an orange one, and the oil is either 10w30 or 10w40....Jessevw72 can confirm or deny these guesses.
Many people run the wrong filter and oil that's far too thin, and spend gobs of money on parts and repair they don't need. VW's watercooled engines(especially those with higher mileage) thrive on thicker oil, and most aftermarket filters have either the wrong pressure relief spring, or no spring at all.
The dealership I worked at had 15w40 in their bulk tank for standard 4-cylinder oil changes when the A3 cars were new. All of my A2 chassis Golfs and Jettas have been 150K+ mile cars, and I ran 15w40 in the winter/20w50 in the summer.
Change the oil to at least 15w40 or 20w50, and install a filter from Mann, Mahle or Hengst(the three primary OE suppliers to VW)...the results may be surprising."
1996 vw golf
nurotek
nurotek is offline
PostPosted: Mon Dec 19, 2011 10:22 am    Post subject: Reply with quote
also the ticking doesnt go away. ill be checking today when i get around to going out to my car. it doesnt exist before or after 2000rpms either. once its past 2000rpms it goes away... or atleast becomes un-audible.
1996 vw golf
86vwgti8v
PostPosted: Mon Dec 19, 2011 11:07 am    Post subject: Reply with quote
That information is truthful but I'm not sure I agree with the uncommonness of lifters ticking. Now it could be the wrong oil causing the lifters to tick.
I'd change the oil and definitely run a Mann filter. See what happens.
FYI. Bentley is 100times better then the Haynes manual. Also, check vwvortex for Gobbs of information.
http://forums.vwvortex.com/search.php?searchid=16052085
Just for starters.
86vwgti8v
PostPosted: Mon Dec 19, 2011 11:17 am    Post subject: Reply with quote
http://forums.vwvortex.com/showthread.php?5037308-Noise-Lifters&highlight=Lifters
Not a uncommon problem. And I don't believe putting a heavier oil will help
nurotek
nurotek is offline
PostPosted: Mon Dec 19, 2011 3:09 pm    Post subject: Reply with quote
the ticking doesnt stop once warmed up. it also ticks at 3500rpms. i checked the oil, the oil seems fine, clean and clear (and under control har har har)
1996 vw golf
nurotek
nurotek is offline
PostPosted: Mon Dec 19, 2011 3:12 pm    Post subject: Reply with quote
also i know, in hind site i should have gotten a bentley and not a haynes ... but i forgot about bentley Wink honestly
1996 vw golf
chazz79
chazz79 is offline
PostPosted: Mon Dec 19, 2011 9:14 pm    Post subject: Reply with quote
Most all 15w40 oils are rated as diesel use...theres no way I'd put that in a vehicle prepping for canadian winter. 20w50...more of the same flawed logic. Run 5w50 full synthetic no matter what the weather and you'll be fine. I've had 5 of these aba cars and they all rattle a bit, it's incredibly annoying those few times I cheaped out and used whatever crap oil I had laying around.
One day as a lion, or a lifetime as lamb
The green monster in bits and peices: http://www.thesamba.com/vw/forum/viewtopic.php?t=332556&highlight=green+monster
nurotek
nurotek is offline
PostPosted: Tue Dec 20, 2011 5:39 pm    Post subject: Reply with quote
i havent changed the oil cause it looks fairly new. what im planing is after this whole holiday crap, in the early new year, take it to a vw dealer, run a diagnostic, if its nothing major ( say oil change or what not) then ill do it. something major, sell the car lol. i also need to fix the horn, which is another reason i wanna have them look at it
1996 vw golf
plasticman1432
plasticman1432 is offline
PostPosted: Wed Dec 21, 2011 1:39 pm    Post subject: Reply with quote
Just had to log in and clarify: It was my info that was quoted from the previous thread, and I did NOT say that cam follower ticking was uncommon....in fact, it's quite common. What I said was that a bad/failed follower is the uncommon thing.
The dealer where I worked here in upstate NY**(from 1996 to late 1999) had 15w40 in their shop tanks for standard 4-cylinder changes. All of my A2-chassis VWs were 150K+ mile cars, and the senior VW tech in the shop recommended that I run 20w50 in the warmer months on my higher-mile cars.
**we're only about 2-1/2 hours south of the Canadian border, so our winters are not too much nicer than theirs.
I would recommend very highly that the OP change the oil and filter before having it looked at by anyone - it could save you a bunch of money on diagnostic time and/or unnecessary parts costs(like an oil pump)
Organized people are just too lazy to look for stuff
'68 Meyers Manx: M1689D815E
http://public.fotki.com/VWDave/
nurotek
nurotek is offline
PostPosted: Wed Dec 21, 2011 2:48 pm    Post subject: Reply with quote
im going to try changing the oil before anything. does the putting half a quart of ATF into the oil have any merit in fixing the lifter issue ?
1996 vw golf
86vwgti8v
PostPosted: Wed Dec 21, 2011 7:08 pm    Post subject: Reply with quote
I don't remember exact specs but bentleys and similar manuals state to take a object and attempt to press the lifter downward. If it moves .xxx" it's bad. I don't remember what that number was but I do remember it being very small. I haven't personally changed a lot of lifters but going by the book almost every one I have ever seen was bad. They didn't necassarily tick or need to be replaced but where out of spec.
I defiantly agree, try some simple stuff.
plasticman1432
PostPosted: Wed Dec 21, 2011 8:47 pm    Post subject: Reply with quote
I would just change the oil, and use an OEM filter....I've never heard of adding ATF, so I can't comment on the merit.
chazz79
chazz79 is offline
PostPosted: Fri Dec 23, 2011 4:45 pm    Post subject: Reply with quote
You are correct in recommending 20w50 in an a2......completely different head design on an aba 2.0. The 5w50 synthetic would be correct for you application. I too was an oil boy back in 1995 an and nothing required 15w40 unless it were diesel. I'm afraid you're getting a good deal of incorrect info here. Do some research on the vortex and you'll find I'm right. I've been doing this for twenty years and owned countless vws in that time.
plasticman1432
PostPosted: Sat Dec 24, 2011 6:41 pm    Post subject: Reply with quote
The internet is a wonderful place, I swear....try to give helpful advice, and stand accused of giving bad info.
chazz79 wrote:
You are correct in recommending 20w50 in an a2......completely different head design on an aba 2.0. .
When I originally posted the oil-related info quoted here, it was regarding an A2.....the current thread starter quoted me here, and I stick by my recommendation for higher-than-100K mile cars - the advice I got back then was given by a 30+year master tech, and it worked for me.
For your information, I was not an 'oil boy;' I prefer 'parts monkey.' Very Happy I've got about 16 years in the business as a VW/Audi/Porsche parts specialist, between the dealer and aftermarket level.
chazz79
chazz79 is offline
PostPosted: Sun Dec 25, 2011 9:20 am    Post subject: Reply with quote
Sorry but the topic says 1996 golf, therefore aba engine with a crossflow head. It is different and flows oil differently. No accusations from me at all I just choose to refute bad info wherever I see it. Simply said 20w50 in a2 vws is great...anything thinner will cause rattles and oftentimes an oil pressure light. 5w50 works best in a3 vws and this is only available as synthetic. I've personally owned both variations and know what works and what doesn't. I am a certified a1-9 auto and t1-8 truck technician. (Double master) I'd hate to see someone do the incorrect oil change and still have a rattle then tear down the engine believing something else is wrong.
My wife has a 1997 cabrio with 186,000 miles on it. If you want to hear it rattle let me go toss some 5w30 in it. If you want it to crank slow and possibly snap a timing belt this winter then I can fill it with 15w40. Many ways to do it wrong...one way to do it right. I'm not looking to pull the head on this engine until she cracks 300k miles so i'll keep doing things my way.
nurotek
nurotek is offline
PostPosted: Sun Dec 25, 2011 4:57 pm    Post subject: Reply with quote
so. im not master mechanic, and i do appreciate everyone that gives me advice on how to do stuff. My golf is what kinda engine ?
1996 vw golf
chazz79
chazz79 is offline
PostPosted: Mon Dec 26, 2011 7:16 pm    Post subject: Reply with quote
Aba 2.0l 4cyl. Tough as nails but really picky on oil type. Do the correct oil change and you'll be amazed at the difference.
nurotek
nurotek is offline
PostPosted: Tue Dec 27, 2011 12:43 am    Post subject: Reply with quote
thx... ill be doing the oil this weekend after i get back from my trip. Not using the car , rental. Wink
1996 vw golf
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
