Mig Welding -- Can't clean backside of weld
dougrbutler
dougrbutler is offline
PostPosted: Fri Aug 15, 2003 4:08 pm    Post subject: Mig Welding -- Can't clean backside of weld Reply with quote
I'm going to be welding some repair pieces on the underside of my bus to both the outriggers and the belly pans. I have cut out the front 1 1/2" of the rusty belly pan and a few areas of the outriggers and the middle support. I can't get to the backside of all the areas I am welding and am wondering if I will have a hard time making good welds. I have mig welded before but in areas where I can access the back of the weld.
Thanks,
Doug
Kosmicride
Kosmicride is offline
PostPosted: Fri Aug 15, 2003 5:45 pm    Post subject: Reply with quote
If you can spray some weldthru primer on the back and front side of the welds then try and get as much primer as possible on the back sides it should be ok
Pay Up sooka!
If it don't make $dollars$ it don't make $sense$
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger Classifieds Feedback
dougrbutler
PostPosted: Fri Aug 15, 2003 6:06 pm    Post subject: Reply with quote
Kosmiride,
Thanks for the info. Never heard of that product. How does it work?
Doug
fjsantana
fjsantana is offline
PostPosted: Fri Aug 15, 2003 6:57 pm    Post subject: Reply with quote
Eastwood sells some weld thru primer that you can use. Also, there is a relatively new product Picklex20 that you can buy directly from the manufacturer. You will find more info on their websites.
www.eastwoodco.com
www.picklex20.com
Felix[/url]
VintageVulture
VintageVulture is offline
PostPosted: Fri Aug 15, 2003 10:50 pm    Post subject: rust proofing your welds Reply with quote
OK, weld thru primer does not truly protect against rust. Since weld thru is used just prior to welding, it is actually burned off anywhere near the weld where severe temperatures were achieved. Most modern shops that follow ICAR regulations use a material that coats the inner surfaces of the parts being welded wih a gooey, waxy substance much like cosmoline. Ask for it at your nearest bodyshop supply store. It comes with hoselike attachments for reaching into long rocker channels and even heater tubes. It is a more modern rustproofing material and the name of the before mentioned material as of now slips my mind. Good luck! Smile
Chillkoot
Chillkoot is offline
PostPosted: Sat Aug 16, 2003 7:49 am    Post subject: Reply with quote
YEah I use that ^^^ shit all the time.. #m Pruduct..I you do have to have about a 3/8" access hole.. Use a rbber plug when you are done.
While we all hate POH ... Don't be Apathitic to CURRENT owner hacks.
Fiberglass is for boats... Rustoleum is for your lawn mower!
