Robertjm Samba Member
Joined: May 22, 2011 Posts: 261 Location: San Francisco Bay Area
Posted: Sat May 19, 2012 5:11 pm Post subject: Best cleaner for brake backing plate and spindles?? |
I went to examine my brake hoses on my 1967 Double Cab and the backing plate and spindles are filthy. Mostly gunked up with oils and Lord know what else. What is the best way to clean this crud up?
I've got some spray on engine degreaser and brake cleaner. However, don't want to use anything that's going to harm anything back there. _________________ 1967 VW Double Cab Pickup
2003 Mercedes ML-500
1995 Saab 900SE Turbo Convertible (Crossed over into Valhalla April 2014)
1972 VW Squareback (Autobahn in the Sky - July 1987) |
Soul Built Pimpin' Aint Easy
Posted: Sat May 19, 2012 5:24 pm Post subject: |
For general cleaning, I use either Super Clean or Greased Lightning, both available at Home Depot.
These are for mild to moderate cleaning that I usually use to soften crud before I power wash.
Good Luck. |
Posted: Sat May 19, 2012 5:28 pm Post subject: |
So you power wash the underside of your car??
Soul Built wrote: |
Good Luck. |
Posted: Sat May 19, 2012 5:30 pm Post subject: |
Oh yeah. I power wash every couple of months at the least. Fender wells, underside, all of that. |
joe56vw Samba Member
Joined: June 24, 2004 Posts: 3202 Location: Olympia wa
Posted: Sat May 19, 2012 5:31 pm Post subject: |
Brake clean and degreaser will not harm anything under there
But will probaly take alot you are better off with solvant, a brush and a bucket if its that bad _________________ '60 15 window walkthrough
why is there no sarcasism button on here? |
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2345 Location: Kelowna, BC. Canada.
Posted: Sat May 19, 2012 10:29 pm Post subject: |
Brake cleans.....in a well ventilated area, that stuff will separate your brain stem.
gordo. |
Clara  Samba Member
Posted: Mon May 21, 2012 9:14 am Post subject: |
if it is all gunked up into an amorphous blob, get some paint scrapers and scrape down the dirty grease crud, or cruddy greasey dirt. I like to use plastic or wood, it does not scrape the paint.
Then spray liberally with simple green or super clean, and let soak. Simple green is less aggressive, super clean does seem to affect paint slightly IMO.
I like to put down cardboard underneath to catch the gunk.
Then drive to the self serve car wash and wash the undercarriage. If you are doing it right, you will get soggy and dirty. wash that bus where the sun don't shine.
Leave the engine running while wash the engine compartment, avoid hitting the paper air hoses or dist cap.
It is nicer to work on a bus that is clean underneath. |
