63 coupe parcel shelf trim removal
roadkingdoc
roadkingdoc is offline
PostPosted: Sun Nov 25, 2012 5:16 am    Post subject: 63 coupe parcel shelf trim removal Reply with quote
how is the aluminum trim on the rear parcel shelf of a 63 coupe removed? thanks
NWGhiaGuy Premium Member
NWGhiaGuy is offline
PostPosted: Sun Nov 25, 2012 8:03 am    Post subject: Reply with quote
I have never had one attached with screws or adhesive. They just hook around the top end of the parcel shelf. You should be able to pull gently with your hands at the curves and it should pop off.
smithers
smithers is offline
PostPosted: Sun Nov 25, 2012 8:45 am    Post subject: Reply with quote
Mine had a bit of glue. Pull the bottom a bit before the top. The top hooks on.
Altema
Altema is offline
PostPosted: Sun Nov 25, 2012 9:10 am    Post subject: Reply with quote
Mine had a few crimps on the bottom edge to secure it, which I bent out slightly to remove mine. Not sure if that was the original way in 1970, or if a PO did it.
Paul
roadkingdoc
PostPosted: Sun Nov 25, 2012 9:14 am    Post subject: Reply with quote
thanks guys. i will give it a try. didnt want to kink it.
