What size engine to build with 94mm pistons and case to use
jcannut21
jcannut21 is offline
PostPosted: Sun Dec 09, 2012 9:50 pm    Post subject: What size engine to build with 94mm pistons and case to use Reply with quote
I am new to building air-cooled engines. I got pair of J&E 94mm piston kit as a gift. I was wondering what size engine I could build and what case I should use? I dont know if I should use a stock 1600 dp and have it machined or go buy a stronger case? I want to start buying parts to get this motor built by summer.
Ragman
The Sambinator
Ragman is offline
PostPosted: Sun Dec 09, 2012 10:01 pm    Post subject: Reply with quote
Piston/cylinders are either A or B. A's for stock stroke, B's are for larger stroke. So, the size engine you can build will depend on which ones you have. Chances are JE are most likely stroker pistons. Common 94 stoker sizes would be 2165, 2276 or 2332.
Stock cases are more than able to be built up to 2332 fairly easily provided you have a later case, dual relief. If you have an earlier single relief case, it is a lesser candidate for building the monster engine.
Check the engine code on the case, and share, we can tell you what you have based on the code.
jcannut21
PostPosted: Sun Dec 09, 2012 10:09 pm    Post subject: Reply with quote
Ok longer stroke motor I will go with and who has good cylinders to use and what should I do to cool the motor?
bugguy1967
bugguy1967 is offline
PostPosted: Sun Dec 09, 2012 10:20 pm    Post subject: Reply with quote
If the engine is built correctly, it will not need any special cooling. Some stroker engine have lower running temps than stock. An original German doghouse shroud and German tins will be all you need.
You still need to know what those pistons are for. Stroker/non stroker. It depends on the distance from the center of the wrist pin to the crown of the piston.
Any barrels will work as long as they are honed for those particular pistons. AA and Mahle both make good enough barrels for street use. There's plenty here on The Samba.
"A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine"
jfats808
jfats808 is offline
PostPosted: Mon Dec 10, 2012 12:21 am    Post subject: Reply with quote
2 sets of JE p/c? Nice. You got two so u cam use a set why not. They are high quality p/c set. Got a size in mind? 74-86 cranks will need clearancing. Put some mo.ey aside for a.fully machined case. What ot comes down to is what you want, how you want it to drive, and how much cash u got to budget. Concensus is usually budget 700-800$ on heads and build as big as you can afford with the remainder.
Edit noticed its just pistons. If it fits, AA cylinder sets run about 105$ + shipping, mahle are 175 + shipping.
2276 IDA's 86C 11-1 DD
Rockstar Suzuki wrote:
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick
You can always learn something new, even from a fool.
Check your oil levels routinely!
stevensj13
stevensj13 is offline
PostPosted: Mon Dec 10, 2012 5:26 am    Post subject: Reply with quote
Actually 74mm needs no clearancing, 76mm needs very little (can be done at home with dremel).
To the OP, do a 2056 motor if you don't want to have your cases clearanced (94mmx74mm) or if you don't mind doing a little clearancing go for a 76mm crank and build a 2110. Get a set of DRD L5 heads, dual weber 40s, 1 5/8 header, and you'll be set.
Current: '73 standard (yellow) '76 standard (rust/gold Laughing)
Sold:
1967 Baja Bug
1973 Super (x2)
1971 Super
1968 bug on CJ 5 chassis w/ super swampers
1970 Baja
turboblue
turboblue is offline
PostPosted: Mon Dec 10, 2012 9:59 am    Post subject: Reply with quote
Can't make that a blanket statement on a 74.
We've had to touch up a few cases with a 74.
Sometimes depends on which rod you use.
Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!"
mark tucker
mark tucker is offline
PostPosted: Mon Dec 10, 2012 10:06 am    Post subject: Reply with quote
you dont need the je pistons, those arnt the je pistons your looking for, you can pass on those.I have a used knotched set of 90.5 with total seal rings that you want to trade me for the je's..........is my jedi mind trick working??? with those pistons I would use no smaller than a 86 stroke probably bigger, 88,90,92 honda rod motor.
jcannut21
PostPosted: Mon Dec 10, 2012 11:24 am    Post subject: Reply with quote
Sorry Mark not looking to trade or sell. I am looking to build a nice size engine. I am still strugglin on what case to use. I want a strong case to handle the power and not crack on me.
[email protected]
john@aircooled.net is offline
PostPosted: Mon Dec 10, 2012 12:37 pm    Post subject: Reply with quote
use a dual relief case, and put case savers in it if they are not there. Use 8mm head studs.
Clearancing depends on the stroke and the rods used. Good rods will require less clearancing than the others.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
