Rear Bench Re-install, 7-Pass Non-Camp w/new interior panels
foreversepia
foreversepia is offline
PostPosted: Tue Jul 23, 2013 2:40 pm    Post subject: Rear Bench Re-install, 7-Pass Non-Camp w/new interior panels Reply with quote
Hi all-
Am in the process of replacing my interior panels with new ones sourced from sewfineproducts.com.
Installing in an '87 Syncro Vanagon, 7-Passenger, Non-camper.
Any tips, gleaned from prior experience, for re-installing the rear bench (without completely mangling the trapezoidal panels that sit parallel to the bench)?
Thus far, we've removed the middle bench to allow for more space to maneuver, removed the lower kick panel under the rear bench, and have covered parts of the rear bench and panels that make contact.
With the SewFine panels being slightly thicker than the original panels, however, the added thickness has effectively foiled our attempts at re-install.
I've also spoken with SewFine - and they cited little/no experience installing these panels and bench in a 7-Passenger, non-camper van.
Many thanks in advance for any info on this! Smile
tim_ha
tim_ha is offline
PostPosted: Tue Jul 23, 2013 3:39 pm    Post subject: Reply with quote
Did you remove the cushion parts of the bench? On my '86 it just takes four bolts on the seatback and seat-bottom to pull them off. Then it is much easier to maneuver the seat frame. I imagine with one person on each side, you should have an easier time squeezing the frame in without destroying your nice new panels.
1986 Syncro Sunroof EJ22
www.subagonsouth.com
foreversepia
PostPosted: Tue Jul 23, 2013 3:45 pm    Post subject: Reply with quote
Thanks Tim. Haven't tried that yet. I'll check this out and post my results. Smile
foreversepia
PostPosted: Tue Aug 06, 2013 9:50 pm    Post subject: Reply with quote
Removing the cushion parts did the trick. Thanks again for the tip. Smile
Robw_z
Robw_z is offline
PostPosted: Wed Aug 07, 2013 2:11 am    Post subject: Reply with quote
I just tried installing a rear bench solo without removing cushions. My interior panels are torn up and I cross threaded 3 out of 4 of the bolts that hold the z-bed frame to the body! I couldn't believe how quick the job got out of hand. Don't try and install a bench seat in a time crunch when it's 100 degrees outside!
I've removed both the back and bottom cushions now and am installing frame only as the first step. Banging my head on the wall for not doing it the first time.
Purchasing an M12 x 1.25 tap tomorrow, wish me luck on saving the threads!
-Rob
tim_ha
tim_ha is offline
PostPosted: Wed Aug 07, 2013 7:52 am    Post subject: Reply with quote
glad I could help! I have gleaned so much great info from thesamba and now I finally have contributed back Cool
