jakepauldominguez Samba Member
Posted: Wed Oct 23, 2013 12:04 pm Post subject: Do i need to change my 68 bug to alternator??? |
SO i recently bought a 68 bug with a fresh motor. ive completely rewired the car with an oem harness.
I also replaced the ignition system. But i am not getting spark to the distributor.
The car was wired professionally & all lights work but i cant figure out why it is not getting spark!
I realized that 68 and on came stock with an alternator, but i have a generator. would that be the problem?  |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33410 Location: Hot Arizona
Posted: Wed Oct 23, 2013 12:12 pm Post subject: Re: Do i need to change my 68 bug to alternator??? |
| jakepauldominguez wrote: |
Well - you realized wrong !!!
These had generators until about 1974. No, you don't need to change to an alternator at all, I still run generators in mine.
I also replaced the ignition system. But i am not getting spark to the distributor. The car was wired professionally & all lights work but i cant figure out why it is not getting spark!
This issue has like nothing to do with the generator, unless the battery will not spin the engine at the correct speed. Assuming that you're correct about not getting spark (like you confirmed "no spark" using aerosol starting fluid), first check that distributor positive terminal #15 gets positive voltage when the key is on. Only the lead to the distributor should be on coil terminal #1.
Let us know if you have points ignition, and whether the points actually close and open the correct amount when the engine turns (correct 0.016 inch gap, or dwell between 44 and 50 degrees). That's the start. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
