vdub8 Samba Member
Joined: February 24, 2007 Posts: 125 Location: SLC, UT
Posted: Sat Jan 04, 2014 5:14 pm Post subject: 54 luggage tray replacement |
I'm trying to source the correct sheet metal needed to repair the body on my baja'd 54 (I bought it that way ). I'm finding a lot of good information on the forum regarding the front and rear clips, but not much on the luggage tray area.
My question how much variation is there in the luggage trays sections (firewall and bottom) for all ovals? I've read that some had the luggage rail mounts 54 and older I believe, but other than that is the sheet metal the same?
There are some sections in the classifieds, but just want to make sure I get the correct replacement.
Thanks! _________________ My 67 build thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=448654 |
srm1956 Samba Member
Joined: February 18, 2008 Posts: 245 Location: Huntington Beach, CA.
Posted: Sun Jan 05, 2014 11:51 am Post subject: |
Hello vdub8.
There is a big difference between a early Oval and a late Oval luggage tray. I had to replace my luggage tray on the Baja'd 54 (Also bought it that way ) I restored. In a early Oval (True 55 and down) the luggage tray is shaped difference where it drops down towards the pan. Almost transitions from Horizontal to Vertical. Where on a 56+ Oval the transition is more of a sloping drop down to the pan (like a slide)
Here's a picture of a 56+ luggage tray that I found. Notice the differant shape.
_________________ Der
Blitzkrieg
Kafers
My VW motto is - Out with the OLD. In with the EVEN OLDER !!!!!!!!!! |
vdub8 Samba Member
Posted: Sun Jan 05, 2014 3:21 pm Post subject: |
That is very helpful...and great pictures to illustrate the difference...Thanks!
My package tray had aluminum reinforcement across the inner firewall similar to yours. Looks like swiss cheese with all the holes they put in it. The bottom has rust damage, so I'll be replacing the whole section as you did.
Now that know exactly what I'm looking for the trick is to find one in good shape. _________________ My 67 build thread:
