MTDI Waste Gate Actuator
strawhouse
strawhouse is offline
PostPosted: Sun Jan 26, 2014 9:42 am    Post subject: MTDI Waste Gate Actuator Reply with quote
So I am hooking up the vacuum lines and the last little bits on my AHU TDI, and I just realized that I have an issue with the waste gate. What are you guys using? I was thinking about a manual boost controller from the turbo to the waste gate... any ideas? If so what psi are you setting it for?
Pacifist with a gun
strawhouse
PostPosted: Sun Jan 26, 2014 3:16 pm    Post subject: Reply with quote
So I put in a manual adjuster and set it around 10psi, works great and has a decent amount of power response even at highway speeds.
Pacifist with a gun
Jeff's Old Volks Home
Jeff's Old Volks Home is offline
PostPosted: Sun Jan 26, 2014 3:32 pm    Post subject: Reply with quote
Dawes device... Works like a charm. Cheap too.
Jeff
svenakela
svenakela is offline
PostPosted: Sun Jan 26, 2014 4:21 pm    Post subject: Reply with quote
That's how I do it, just a short hose from the intake to the waste gate, I have about 8 psi and it still runs great.
Bonus tip: New injectors are going to make a lot of good things. They don't have to be bigger, new injectors gives so much better spray. Here's some reading for ya:
http://switchamotor.blogspot.se/2012/06/injector-info.html
http://switchamotor.blogspot.se/2012/08/new-injectors-makes-difference.html
strawhouse
PostPosted: Sun Jan 26, 2014 8:57 pm    Post subject: Reply with quote
Thanks, Injectors are next on the list... but first I am going to wait till it warms up a bit.... maybe in the spring.
Pacifist with a gun
outwesty
outwesty is offline
PostPosted: Sun Jan 26, 2014 9:12 pm    Post subject: Reply with quote
http://www.kermatdi.com/servlet/the-176/Dawes-Device--dsh-The-Basic/Detail
or build your own.
http://forums.tdiclub.com/showthread.php?t=103279
