Manual Transmission-DK-DP-DT
strawhouse
strawhouse is offline
PostPosted: Fri Feb 21, 2014 8:52 am    Post subject: Manual Transmission-DK-DP-DT Reply with quote
Need some help, looking for a DK transmission to buy me some time while I am getting taller gears installed in my original diesel transmission for the TDI. Doing some research it looks like the DK, DP and the DT transmission all have the same final drive of 4.57... so why is the DK the preferred transmission to switch to? Availability? or am I reading something wrong here?
Pacifist with a gun
johnnygreenham
johnnygreenham is offline
PostPosted: Fri Feb 21, 2014 9:07 am    Post subject: Reply with quote
Your right. the difference between DK, DP and DT are very similar in gearing. DK and DP are exactly the same in gearing.
Now the DT will have the gear linkage spline coming out of the transmission in a higher spot. It comes out more at the top, than the DK. Never seen a DP but pretty sure it has to be almost exactly the same as the DK. I'm guessing most of the aircooled vanagons came with DK so thats why people always mention that code. Its a direct plug and play into the Diesel vanagons with the diesel bell housing. If you get a transmission that was on a later model made for a gas engine then gear linkage problems are going to be your issue and maybe your transmission mount height. 'Issue' is the word as nearly all of them can be worked around.
1982 Diesel 1.9TD AAZ
Last edited by johnnygreenham on Fri Feb 21, 2014 11:16 am; edited 5 times in total
J Charlton Premium Member
J Charlton is offline
PostPosted: Fri Feb 21, 2014 9:07 am    Post subject: gearboxes Reply with quote
Sorry to hear of your gearbox woes. This link http://www.t3-infos.de/images/T3-Getriebe.pdf has data for every T3 gearbox. The DP had a 40% locker and I don't think I've heard of a DT being available this side ofthe pond.
Be aware too that the shift rod attachment is located in a different place on the DK than it is on the latter gearboxes.
NAHT hightop availability May 18 2023 -
Bend Oregon - for Oregon, California- (7 tot , 3 available), Kennewick Wa (6 tot, 1 available), Small Car Performance Fife Wa. (7 tot 4 avail ), Fairbanks Alaska (1 tot 0 avail)
Future availability TBD : Springfield Mass. Staunton Va, Florida, Colorado, Grand Junction Co., SLC probably late 2024
strawhouse
PostPosted: Fri Feb 21, 2014 9:10 am    Post subject: Reply with quote
So if the DT comes out of the higher spot it might work better for my application. The transmission in the Doka is a stock diesel transmission from 1988. It seems like the shifter is higher up on mine....
Pacifist with a gun
johnnygreenham
PostPosted: Fri Feb 21, 2014 9:18 am    Post subject: Reply with quote
DK transmission linkage spline comes out of the bottom with the two ball lever
What code is your original?
crazyvwvanman
crazyvwvanman is offline
PostPosted: Fri Feb 21, 2014 9:39 am    Post subject: Reply with quote
The 80-83 DK has the wrong linkage type for your 88.
The DK was used in aircooled vanagons from 80-83. In North America the most common diesel Vanagon by far was 82 and it used the same linkage type as the aircooled vans so the taller geared DK became the obvious choice for 82 diesel vans that got more powerful engine swaps. Diesel vans after 82 used the later style linkage and putting a DK into one of those 83+ vans means adapting the linkage.
Mark
strawhouse
PostPosted: Fri Feb 21, 2014 10:45 am    Post subject: Reply with quote
Is the shifter location different on a DT or a DP transmission?
Pacifist with a gun
crazyvwvanman
PostPosted: Fri Feb 21, 2014 11:05 am    Post subject: Reply with quote
The DT uses the same linkage as your 88 and any waterboxer.
The DP uses the 80-83 aircooled style linkage, and 81/82 diesel.
Mark
strawhouse
PostPosted: Fri Feb 21, 2014 11:35 am    Post subject: Reply with quote
So in an ideal world the DT is the transmission to use... I guess the availability is the issue?
Pacifist with a gun
hdenter
hdenter is offline
PostPosted: Fri Feb 21, 2014 4:10 pm    Post subject: Reply with quote
Since I plan on installing a later gas 5spd trans into my '82 diesel chasis along with other later systems can I be reasonably assured the later linkage can be easily adapted to the '82?
Hans
'79 triple white convertible bug
'84 sunroof vanagon
'85 weekender
crazyvwvanman
PostPosted: Fri Feb 21, 2014 4:30 pm    Post subject: Reply with quote
The 5 speed uses a different knob/lever, front shift box/guides, front shift rod than do any of the 4 speeds.
The 5 speed is longer than the 4 speed. When they came out with the longer 5 speed VW began building all the front radiator cooled vans with the engines pushed back closer to the rear bumper to make room for the longer 5 speed. They did this even in 4 speed vans so they could use the same hoses, cables, and pipes, linkage no matter which length tranny was installed. 82 diesel vans have the engine in the early position, closer to the front of the van.
There is more that can be said and things that can/must be done to make it work well. You may have a tough row to hoe if you were thinking you could simply bolt it into place in an 82 diesel. It came as a common option with 83 diesel vans so the various different parts from an 83 diesel van would make it a bolt in if you got them all. Otherwise you will need to fuss, fiddle, and fabricate.
Mark
Hans
hdenter
hdenter is offline
PostPosted: Fri Feb 21, 2014 4:48 pm    Post subject: Reply with quote
Is the frame member that the front trans mount bolts to
in a different position than the later models? I have a complete '85 weekender that is already set up with a 5speed trans to cannibalize. The '85 just has too much seam and window rust to be worth while to repair. The '82 chasis is rust free and registered. So, I can play with my turbo charged 1.9 ideas or go H6 and not worry about the smog nazis here in CA. Heaven forbid that I put in a cleaner burning and more fuel efficient engine/trans with Cat. than what originally came in '85.
Hans
'84 sunroof vanagon
'85 weekender
?Waldo?
?Waldo? is offline
PostPosted: Fri Feb 21, 2014 4:52 pm    Post subject: Reply with quote
The frame rail is the same. The '82 engine carrier bars are different and place the engine approx 1.5" closer to the front of the van. If your '85 is a WBX then you will still need to source the '83+ carrier bars if installing an inline-4.
hdenter
hdenter is offline
PostPosted: Fri Feb 21, 2014 5:16 pm    Post subject: Reply with quote
No I4. Trying to add a turbo and megasquirt to stock 1.9wbx and try it with a 2.1 longblock I also have. Then, If I can't achieve my goal of 130-150hp and an average of 24mpg on mixed city/hwy driving I might move on to subbie power. In the mean time I will start with wbx engines.
Hans
'84 sunroof vanagon
'85 weekender
strawhouse
PostPosted: Fri Feb 21, 2014 5:48 pm    Post subject: Reply with quote
Does anyone know what year and engine used the DT transmission?
Pacifist with a gun
PostPosted: Fri Feb 21, 2014 5:50 pm    Post subject: shifter etc Reply with quote
Or bite the bullet and move to a modern cable shift mechanism. http://www.cableshift.com/home.html
I'm retrofitting my military diesel van (originally 1.7na and 4 speed) with an AHU and ASS 5 speed. Haven't hooked up the shifter yet - I have a set of 5 speed diesel shifter rods as well - but when i do, if I have to fiddle and fart around for more than a day, I'm going to seriously consider a cable shift system, just for the crisp feel and surety of shifts.
hdenter
hdenter is offline
PostPosted: Fri Feb 21, 2014 5:55 pm    Post subject: Reply with quote
I have an ASS, too, as well as an APP. Depending on what tires I deside to run I will hoose which trans to work with. If only I could afford a 4.14 ring...
Hans
'84 sunroof vanagon
'85 weekender
PostPosted: Fri Feb 21, 2014 6:27 pm    Post subject: years etc Reply with quote
Its on the spread sheet link that I sent above.
strawhouse
PostPosted: Thu Oct 09, 2014 3:10 pm    Post subject: Reply with quote
I know this thread is a bit old but I thought I would post an update. I found a DT transmission and installed it into the doka today. The transmission is a complete bolt in, no modification required install ( less cutting back the input shaft ) The shift linkage hooked up and it shifts fine. Once I get the last few things finished I will let you guys know how the gearing is on the highway
Pacifist with a gun
noyan
noyan is offline
PostPosted: Sun Jun 14, 2015 5:44 am    Post subject: DK transmission swap Reply with quote
Hi all, we own a once air-cooled 1981 Westfalia now powered with a 1.8 Audi engine. We are planning to swap our DK transmission with a 5-gear 40% LSD AAS transmission. Our engine seems to not produce enough torque for 32:7 gear and the new transmission has 29:6, we hope to get a bit more speed uphill and reduce the frequent stuck in sand/meud when we get off the road by LSD. Any comments, do you think we can go for it?
