		Jabberjaw2  Samba Member
  Joined: January 16, 2012 Posts: 4 Location: Valencia, CA
				 Posted: Sat Mar 22, 2014 10:37 am    Post subject: Zwitter dome light |
				| Can anyone tell me what is unique about the Zwitter dome light? I keep hearing this but I can't seem to find a pic or an explanation of why it is considered unique. Also, what are the additional Zwitter only options and accessories that you may know of? |
		73sports  Samba Member
  Joined: September 26, 2004 Posts: 2107 Location: Warrington, PA
				 Posted: Sat Mar 22, 2014 10:43 am    Post subject:  |
				The light is similar to an oval dome light, except there is no switch built into the light.  The switch is on (under) the dash.  The ash tray is also unique, no handle on it like later versions. _________________ I will never lie, but sometimes the truth changes.
Central Jersey VW Society |
		fatbeetle  Samba Member
  Joined: August 23, 2011 Posts: 85 Location: Richmond VA
				 Posted: Sat Mar 22, 2014 2:08 pm    Post subject:  |
				I thought at one time brezelwerks had a limited run of repro zwitter/53 oval dome lights? _________________ 1953 OVAL |
		joel55bug  Samba Member
				 Posted: Sat Mar 22, 2014 5:43 pm    Post subject:  |
	  | fatbeetle wrote: |
	  |  I thought at one time brezelwerks had a limited run of repro zwitter/53 oval dome lights? |
I hope you are correct as this is the only piece I'm missing minus the motor and motor parts which I won't even bother myself with since it's going to be a cal looker.
Already got:  small mouth bread box gas tank, dual arrow speedo in km, ashtray, switch under the dash and starter button.
Please inform me if I'm missing something from this list.  I already know brezelwerks repros the A-Z heater knob and I'll be acquiring one of those soon enough. |
		D. Haviland  Samba Member
  Joined: October 30, 2009 Posts: 536 Location: Burlington, Vermont
				 Posted: Sat Mar 22, 2014 8:36 pm    Post subject:  |
				| That switch does two things. It turns on your dome light to the left. Center is off. Right is speedo lights. If you're getting really anal, the headlight switch is rectangular with terminals on top instead of the round ones used on ovals |
				 Posted: Sat Mar 22, 2014 9:31 pm    Post subject:  |
	  | D. Haviland wrote: |
Is this visual from the cab or just under the hood?  Any pictures of what your talking about? |
		laszlo805  Samba Member
  Joined: December 15, 2011 Posts: 114 Location: oxnard
				 Posted: Sat Mar 22, 2014 11:19 pm    Post subject:  |
				| i have a picture in my picks if you look it up you will see how it is different |
				 Posted: Sat Mar 22, 2014 11:24 pm    Post subject:  |
	  | joel55bug wrote: |
	  | fatbeetle wrote: |
also Zwitter has a soled vw emblem on the hood and the pull handle on the hood is made out of a soled peace of aluminum also zwitter only trim in the rear split windows hope that helps |
		gorlininc1  Samba Member
  Joined: July 25, 2011 Posts: 38 Location: MERRITT ISLAND, FL
				 Posted: Mon Feb 01, 2016 12:30 am    Post subject: Re: Zwitter dome light |
				The a-z heater control is used on the zwitter and 1953 ovals.  The zwitter also has a push button start that continued to the end of 1953 on the ovals. The windshield wiper switch with the open back also ended in 1953, when the rear of the switch was enclosed. _________________ 1952 zwitter
1971 Toyota FJ40
1997 Jaguar XK8 vert
2006 Lexus SC430
RVA MEMBER |
		bwaz  Samba Member
				 Posted: Tue Feb 02, 2016 9:48 am    Post subject: Re: Zwitter dome light |
				Headlight switch
Zwitter dome light
The problem with the dome light is that it needs to be released from both sides when removing it. Many just yank on one side with a screwdriver and crack or break the lens. (as in above) |
		einsperren  Samba Member
  Joined: July 09, 2006 Posts: 61 Location: down by the river
				 Posted: Thu Feb 11, 2016 6:40 pm    Post subject: Re: Zwitter dome light |
				| I am wondering about this supposedly '53 discontinued "open back" wiper switch mentioned in this thread earlier. Was this change documented in progressive refinements or in car of the century or else where. anyone know? |
